Dan Moffet
scalpel_ninja
Got some more work done today. Installed the wiring loom, but no connections made yet. The previous owner welded a flat blank plate to the bulk head without any holes, so I had to bore a hole to feed the wires into the engine bay.
Also installed whatever coolant hoses I had on hand.
Lastly, I test fitted the intake and carb. Because of that flat bulkhead plate, the intake manifold couldn't really sit flush against the block without tipping the engine forward. So I used a fender hammer and made a bit more clearance; however, the air filter doesn't fit. I was thinking of getting a foam filter so it can deform a bit as needed.
#104
Yeah, the bottom of that HIF carb usually seems to have some clearance problems with the firewall on all Minis, whether the firewall has been modified or not. On my Mini, I installed an adjustable "dog bone" engine steady bracket so I could extend the length and tilt the engine forward just a little bit to gain that needed clearance between the carb and the firewall.
The other trick is to try to work with different thickness of the Phenolic spacer on the carb to manifold interface to move the carb closer to the engine to gain clearance.
I ended up tackling the problem both ways.
scalpel_ninja
I installed new track-rod ends but when I torqued them to the existing steering arms (I kept the originals), it seems they don't sit correctly as the new parts have a lip but the arms don't have a matching cut out. I'm guessing I'll need to get updated steering arms?
#106
You have it installed upside down so the taper isn't matching is the problem.
scalpel_ninja
Quote from: 94touring on Today at 01:21:02 AMYou have it installed upside down so the taper isn't matching is the problem.
Well that would explain my problem!  :cheesy:
Thank you sir!
