Dan Moffet
scalpel_ninja
Got some more work done today. Installed the wiring loom, but no connections made yet. The previous owner welded a flat blank plate to the bulk head without any holes, so I had to bore a hole to feed the wires into the engine bay.
Also installed whatever coolant hoses I had on hand.
Lastly, I test fitted the intake and carb. Because of that flat bulkhead plate, the intake manifold couldn't really sit flush against the block without tipping the engine forward. So I used a fender hammer and made a bit more clearance; however, the air filter doesn't fit. I was thinking of getting a foam filter so it can deform a bit as needed.
#104
Yeah, the bottom of that HIF carb usually seems to have some clearance problems with the firewall on all Minis, whether the firewall has been modified or not. On my Mini, I installed an adjustable "dog bone" engine steady bracket so I could extend the length and tilt the engine forward just a little bit to gain that needed clearance between the carb and the firewall.
The other trick is to try to work with different thickness of the Phenolic spacer on the carb to manifold interface to move the carb closer to the engine to gain clearance.
I ended up tackling the problem both ways.
scalpel_ninja
I installed new track-rod ends but when I torqued them to the existing steering arms (I kept the originals), it seems they don't sit correctly as the new parts have a lip but the arms don't have a matching cut out. I'm guessing I'll need to get updated steering arms?
#106
You have it installed upside down so the taper isn't matching is the problem.
scalpel_ninja
Quote from: 94touring on December 08, 2025, 01:21:02 AMYou have it installed upside down so the taper isn't matching is the problem.
Well that would explain my problem!  :cheesy:
Thank you sir!
scalpel_ninja
Got a few more bits in today including the upper engine steady, connected a few wires, and installed the HEL Performance clutch line to the secondary cylinder.
I got this anchor tab for the clutch arm return spring. I think diagrams show it sitting on the bleed valve... not sure how this might be correct with so much slop?
Also test fitted the throttle cable and don't really know how the cable sheath and this ferrule are all supposed to stay in place?
I believe there's a clip that goes over the top of the accelerator pedal and holds the cable in place.
scalpel_ninja
I think I did order the clip and will see if it's in the pile of parts that need to be installed.
Sorry I didn't clarify: I wanted to know how that silver barrel in the back where the cable pokes through stays attached to the bulkhead? Is it supposed to stay there? Also, how does the cable sheath on the other side stay put?
Seems these should be there to prevent the cable from sawing into the bulkhead metal...
I believe the ferrule goes over the end of the cable sheath and then pokes into the firewall from the other side.  That guides the cable through the firewall and then the clip others have mentioned holds the end of the cable to the pedal arm.
Tension on the sheath between the firewall and the support clip at the carb keeps the cable sheath and ferrule in place in the engine bay.
There is a ferrule already built into the firewall on most of the cars I've seen that the sheath fits right into.
You have to insert the sheath from the engine side of the firewall into the ferrule, then from inside the car you feed the new cable thru the tiny hole and locate the ball in the fork on the pedal, then slip the clip over it to hold it in place.
The ferrule in the pic might be made to slip over the sheath and the locating ferrule already on the firewall, I'm not sure but as Michael says, once you have it all hooked up properly it stays in place. Don't forget to pull all the slack out of the cable before you tighten the little cable pivot thingy on the carb, but leave just a tiny bit of slack to allow you to adjust the idle.
And verify your throttle is actually open 100% with the pedal on the floor.
scalpel_ninja
Thank you all. I'll take a look again this weekend and shuffle parts around as instructed.
I'm also studying wiring diagrams and they call for a starter solenoid to be connected; in my case, I have a floor starter button, would that be the solenoid?
Yes, the floor starter is your solenoid.  Your manual(s) "should" also have a wiring diagram for the early systems that used the floor starter button.
With many "bitsa" cars (bits of this model, bits of that model), you end up referencing back-and-forth between different diagrams for different circuits.
scalpel_ninja
Quote from: MPlayle on December 10, 2025, 09:40:50 AMYes, the floor starter is your solenoid.  Your manual(s) "should" also have a wiring diagram for the early systems that used the floor starter button.
Thank you. That's exactly what I've been doing: jumping between 2 diagrams to get the basics sorted out.
Years ago I had a Mini that was like that - early floor starter with a 1275 and alternator plus other stuff.
Once you figure out which diagrams are most appropriate, the jumping back-and-forth starts to become second nature.
scalpel_ninja
Got new stub axles pressed in by a local automotive shop. They said they couldn't reuse the old circlips and put new ones in. The fit looks weird, will this be an issue?
scalpel_ninja
Edit: the shop really messed up. I'm going back to discuss a refund or more.
scalpel_ninja
On my electronic distributor, there two wires: black and red. Does this diagram look right for how to wire it to the coil?
That looks right to me based on past experience with the Ignitor modules from 123 as well as the recent experience with installing the AccuSpark version in my current Mini.
