Amateur Restoration of a 1960 Morris Mini
Started by scalpel_ninja, October 19, 2024, 12:10:41 PM
I have done the engine in/out on my panel Van in the same manner as skmini described.
I use the outermost exhaust studs (at each end) as my attachment points for similar brackets.
scalpel_ninja
Quote from: skmini on August 19, 2025, 02:24:28 PMI've been pulling mine with the radiator attached.  I've been taking the alternator and distributor cap off, as well as taking the starter off.  I haven't needed to take the oil filter off.
The axles are the biggest pain.
Lot's of carefulling.
Thank you for the information. I've seen other owners pull their motors with the radiator still attached. That's why I pre-installed mine. Hope it works out...
The alternator isn't installed yet, starter motor still needs to ordered, so that should just leave the distributor to be removed for clearance. The axles and hubs are still sitting in boxes.
Quote from: MPlayle on August 19, 2025, 05:06:58 PMI have done the engine in/out on my panel Van in the same manner as skmini described.
Thanks! Honestly I would feel better if I didn't have to disturb the head bolts unless absolutely necessary. Using the exhaust studs sounds better to me. Though wouldn't this potentially tip the engine forward (exhaust side canted up) instead of the usually recommended tipping it backward (exhaust side canted down)?
I would have to look in the garage to be certain, but now I think about it I recall using three mounting points.  The two outer exhaust studs and one of the alternator bracket bolts (on the front of the engine).
This kept it fairly level and still allowed me to tilt it enough to swing the final drive under.
scalpel_ninja
Welp, the engine is in the bay!
That looks terrific!
Should be running and driving late this afternoon then?   :grin:
scalpel_ninja
Quote from: MiniDave on August 25, 2025, 08:53:23 AMThat looks terrific!
One can dream... 😂
scalpel_ninja
Got the outer CVs installed along with the hub and associated connections made.
Also dry fitted this front shock. Not sure if there's supposed to be any bushings for it on the studs? Seems to just slip on to be bolted down.
And just for fun, I dry fitted the wheel. I think it's gonna look pretty good!
Nice wheel!  I like the flat rim on it.
Don't forget the Mr. Kotter pins on the big axle nuts......no bushings on the shock mounts, just big thin flat washers. I think the extra length is there because they used nylock nuts....
scalpel_ninja
Quote from: MiniDave on September 30, 2025, 08:55:16 AMDon't forget the Mr. Kotter pins on the big axle nuts......no bushings on the shock mounts, just big thin flat washers. I think the extra length is there because they used nylock nuts....
Thank you! That's what I figured judging by how the shock just slips on. The manual that comes with the shock is just photos and quite confusing because they seem to illustrate installation of all different kinds of shocks (like coil overs) made by KYB, and not just this specific model.
Once I get tires on the wheel and the car on the ground, I'll make sure to torque to spec and install the cotter pins.
I was also reading a torque spec of caliper retaining bolts to hub should be 35-40 ft-lbs. Might be just in my head, but I was torquing with the torque wrench, but it started to feel plasticky around 25 ft-lbs and didn't go any further...
They're 3/8-24 bolts, so unless you're using hardware store grade 2 bolts they should easily tighten to 35-40. I used grade 8 on all suspension and brake hardware.
scalpel_ninja
Thanks for the info. They are assembled with grade 8 bolts. I'll go back and check again this weekend. I had a bad experience with using a torque wrench in a Subaru suspension when swapping out a sway bar. Ended stripping the hole at just 25 ft-lbs.
In this case, the bolt isn't what I'm worried about. I'm afraid to strip the threads in the hub, if that's even possible.
I've always just made them good and tight. A lock washer and a bolt long enough to use up all the threads but short enough it  doesn't hit the disc.
Is it possible your torque wrench is out of whack?  Do you have a second torque wrench to check with?
scalpel_ninja
Quote from: BruceK on September 30, 2025, 04:20:20 PMIs it possible your torque wrench is out of whack?  Do you have a second torque wrench to check with?
I thought about that possibility, but I do test that it clicks by putting the square head in a bench vise and set it at a lower torque before I use it on the car. I was able to torque other bolts to 22-25 ft-lbs without issues. I wonder if it's just the angle at which I'm holding it makes the feeling a bit different...
scalpel_ninja
I've been trying to figure out which starter motor to get, as well as which ignition coil would be correct.
This is what I have now:
I saw this starter that seems promising.
Also, I can't seem to figure out what coil I need? Ballasted, non-ballasted?
Again, a huge thank you to all the experts on this site!
scalpel_ninja
I figured out it was me holding the wrench at an odd angle that felt like I was using much more force than normal. I borrowed a Snap-On torque wrench from a friend to ensure I had the right torque and got it to 40 ft-lbs.
#92
Since you've upgraded to a newer motor, what clutch does it use, that will tell which starter you need. Is it a Verto or pre-verto? Does it have the long or short clutch arm?
Edit: I went back thru your photos, you have a pre-verto clutch, so the starter you posted is the right one
This one for a pre-Verto (long clutch arm)  https://www.minispares.com/gxe4404-inertia-starter-motor-outright-sale-9-tooth
As for coil, it depends on the dizzy, are you running points? If so you need a ballast resistor and a 1 ohm coil, if running Pertronix or the pointless distributor, then you need NO ballast and a 3 ohm coil.
scalpel_ninja
Quote from: MiniDave on October 09, 2025, 08:40:23 AMSince you've upgraded to a newer motor, what clutch does it use, that will tell which starter you need. Is it a Verto or pre-verto? Does it have the long or short clutch arm?
Thanks for the info! Looks like I'll be getting a 1 ohm ballasted coil?
The coil won't have a ballast in it, but with points you want a 1 ohm coil. The car may already have a ballast - either mounted on the fender or firewall, or sometimes it was in the wire from the ign switch. The only way to know is to turn on the key and put a voltmeter on the + side of the coil - well the wire that is and see if the voltage falls off after a minute or so. It should drop down to about 9 volts.
If you're getting 12V consistently, then you can buy a ballast and just put it in the wiring between the coil + wire and the coil. If it's not built into the wire, it will look like this......
https://mossmotors.com/47222-ballast-resistor?gad_source=1&gad_campaignid=11593776446&gbraid=0AAAAADxl9Sj-Wj9OVeJDny3S7Wk8JCzkq&gclid=Cj0KCQjw3aLHBhDTARIsAIRij5-hFsh3-SGvL6A1ALl08WsEheB3nyVuxAU7I0t6dV5oLgg3QM8boI8aAqXJEALw_wcB
The 998 in my panel Van had points ignition but did NOT use any ballast resister or wire.  Not all points based systems were ballasted.  Mine used the "blue" sliding points and a 3 ohm coil without any ballast.  I now use a 3 ohm coil with an AccuSpark module instead of points.
When the condenser went out on mine, I had to research the manuals and online to determine the troubleshooting and how to determine which I had.  The first step was checking the supply to the coil as Dave outlined.
The ballasted systems also had a "bypass" wire from the solenoid to provide a full 12 volts to the coil during cranking for a stronger spark during start and then dropped to the 9 volt feed for normal running.
scalpel_ninja
Quote from: MiniDave on October 10, 2025, 05:34:31 AMThe coil won't have a ballast in it, but with points you want a 1 ohm coil. The car may already have a ballast - either mounted on the fender or firewall, or sometimes it was in the wire from the ign switch. The only way to know is to turn on the key and put a voltmeter on the + side of the coil - well the wire that is and see if the voltage falls off after a minute or so. It should drop down to about 9 volts.
Quote from: MPlayle on October 10, 2025, 06:42:07 AMThe 998 in my panel Van had points ignition but did NOT use any ballast resister or wire.  Not all points based systems were ballasted.  Mine used the "blue" sliding points and a 3 ohm coil without any ballast.  I now use a 3 ohm coil with an AccuSpark module instead of points.
Many thanks for the information! The car has no wiring and as far as I've inspected, there's no ballast mounted anywhere as the shell was near bare when I got it. I'm planning to install a new wiring loom soon.
This coil kit is what I'm now considering since it appears to include all possible parts needed? The listings don't seem to indicate how many ohms though...
I just took another look at your picture of the distributor and that is an electronic module instead of points. You have two wires (red and black) coming out of the distributor.  Red goes to the + side of the coil and black goes to the - side of the coil.
You need a 3 ohm coil and NO ballast.  Also, make sure your new wiring harness does NOT have the built-in ballast resistor.  You will absolutely need 12 volts at the coil as that is also where the + connection (red wire) from the distributor goes.
scalpel_ninja
Quote from: MPlayle on October 10, 2025, 09:24:38 AMI just took another look at your picture of the distributor and that is an electronic module instead of points. You have two wires (red and black) coming out of the distributor.  Red goes to the + side of the coil and black goes to the - side of the coil.
Here's a better view of the distributor.
This coil looks to be right. 3 ohms and non-ballast.
Dan Moffet
#99
From what I recall/understand, on a ballasted system, the coil produces enough spark charge from 9V supply while the car is running, and when cranking, the by-pass wire (only charged when the key is in the "start" position) by-passes the ballast and provides 12V to the coil, producing an extra-strong charge to the plugs to aid starting.
The ballast is really just an in-line resistor or resistance wire.
If you use a non-ballast coil on a ballasted car, you'd just get weak spark. Vice-versa and you'd get a overly warm coil.
If your car was built with a ballasted system, there's an extra wire feeding the coil and your Haynes manual will show the white/purple ballast wire coming from the hot side of the top fuse (1-2) and a white/yellow wire coming from the ignition switch. Both wires go to the same coil terminal.
The hot side of the top fuse of a 4 fuse box is fed from the ignition switch in the "run" position.
