79 Canadian Mini
So the new door sill does not have the button unique to Canadian Minis that ties the door to the sill when closed.  I'm guessing that is an unobtainable part now?
skmini
Quote from: BruceK on January 16, 2021, 10:39:50 PM
Yes, although it was missing on the left side anyway.  Sometime before my wife bought the car, the driver's door was replaced with an earlier one that didn't have the matching receiver in the door (or the Canadian Mini door reinforcement) and the captive nut that the button screws into was filled with Bondo.
skmini
Got the left rear quarter panel welded on.  Mainly happy with the way it fits, although the way the rear valence, boot floor and quarter panel come together is not the neatest.  Once the seam trim and seam sealer is on, it should be fine.
skmini
Quote from: Willie_B on January 17, 2021, 08:38:38 PM
Very impressive work.
Thanks!  All the time spent looking at restoration threads here and on The Mini Forum has given me a good idea of how things fit together and the confidence to do it.
skmini
Met my match on the mk1 taillight adapter plates.  Hopefully I've learned lessons on the left side that will make the right side go a bit more smoothly.  I'll have to see how close I can get it with the hammer and dolly and then filler.  Kind of regretting not getting the full rear panel with the mk1 taillight pressing.
I would have welded that from the back just to not have to grind the welds down.  If you have to do the other side still it will save you some time.
skmini
Quote from: 94touring on January 20, 2021, 08:46:14 PM
That's a good idea.  I haven't done the right side yet.  Need to let the experience percolate first.
skmini
Right side done.  I did weld it from the back, and then filled some pin holes from the front.  I also took my time, so there's not as much heat distortion.  Not perfect, but quite a bit better than the left side.
skmini
Onto the right side.  I welded a couple of guide pieces to my brace to help locate the A pillar.  Just like on the left side, the little brace between the parcel shelf and the inner fended was spot welded to the inner fender, but not to the parcel shelf.  The end of the parcel shelf wasn't spot welded to the dash rail either, so that end of things was likely a bit floppier than necessary.
That side-by-side look at Mk I vs Mk II taillights is great.  Really shows how much better the Mk I one is IMO.
skmini
Quote from: BruceK on January 25, 2021, 07:10:11 AM
I think so too.   ;D
Not sure I agree, I like the bigger lights......
Quote from: MiniDave on January 25, 2021, 10:45:53 AM
I am not against the early bigger MK II lights but I dislike the later ones with the reverse light built in.
I like both, maybe he should have left it one of each  :D
skmini
Right side welded.  This side had some collision damage, and the quarter panel took a bit more persuasion to fit.
To see the shell coming together like that HAS to make you feel good! Really making progress   77.gif
skmini
Thanks.  It is extremely satisfying, and there's usually a big smile on my face (except with the taillight adapter plates).  I regret not figuring out how to weld and do this kind of body work sooner.  Someone asked me if I've sat in it and made "vroom" noises yet.  Maybe when the front end panels are installed.   ;D
skmini
Scuttle welded in.  Also welded up some holes and a crack in the firewall.
I've had the fenders and front panel fitted/clamped a few times now.  As per the advice on the front panel fitting article, I made sure the scuttle/fender/hood fit was good before welding it.  The order of clamping that seems to work is fender to inner fender by the cross member support and scuttle, then bottom of A panel to fender, then top of A panel to fender, then fenders to front panel making sure the hood fits with OK gaps. Going in the opposite order doesn't work at all.
skmini
Spent some more time clamping, checking gaps, double checking and then welding everything.  There are still quite a few miscellaneous bits to weld like the seam welds at the rear closing panels, the reinforcements at the A-panel to fender, etc.  Rebuilding the doors is next.  The body hasn't been this complete for five years, and it hasn't been this solid in over 30.
Once I got myself cleaned up,  I poured some of the better stuff to celebrate.
skmini
Quote from: 94touring on February 08, 2021, 11:10:40 PM
I welded in the little reinforcements between the A panel and fender.  I was surprised how much rigidity they add.
That's an often overlooked piece.
skmini
Started working on the right door, which is Canadian-specific.  The left door is from an older Mini, so doesn't have the Canadian-specifc crash bar and "button catcher".  Since the left door doesn't have these features, and the door step no longer has the button, I'm going to remove them.  The crash bar is heavy and makes getting the glass in and out a pain.  Interestingly, it looks like it's plug welded to the door frame, not spot welded.  The button catcher no one would ever see, but it seems like a dirt/moisture catcher.  I've already done some rust repair on the lower front corner, and I'm going to replace a bit more of the metal where the skin folds over.
The left door is in much worse shape rust wise.
skmini
Right door frame repaired and inside painted.  Now, working on getting it shimmed/fitted and then the skin.  How much does that crash bar weigh?  11 pounds.  How much does the frame weigh without it?  11 pounds.
