Gyraline Alignment Tool
Started by scalpel_ninja, December 05, 2025, 09:24:06 AM
scalpel_ninja
Saw this ad pop up in one of my accounts. It uses the sensors in a smartphone and a 3D printed bracket to take measurements; allegedly accurate and repeatable results.
Any thoughts?
I saw those a couple years ago. At the time I don't believe they worked with android.
Pretty sure the android option is a pretty recent addition. Have always been curious how well they actually work.
The guys on GRM tried this with mixed results, it looked like a great way to check alignment at the track but like I said - mixed results. $190 bux is about what a 4 wheel alignment costs these days too......so in theory it should pay for itself.
Yeah alignments are crazy expensive these days it seems, which is why it has always piqued my curiosity. Of course I have never had an iPhone so until recently its never really been a real option anyway.
I still just use my toe plates and camber tool. Which works great.
There are YouTube videos showing people using this tool. Most of the ones I've seen are generally positive.
Yeah, it's expensive, but on the other hand, some Mini owners have found it to be quite a hassle trying to find a local alignment shop that either has equipment that can fit 10 or 12 inch wheels and/or is willing to put in the work to get a Mini set up right.
This is what I use. I don't recall paying this much for the Joes camber/caster tool years ago. There are cheaper versions. I use the toe plates against the tires when the car's flat on the ground and the suspension has settled to set the camber gauge against for an accurate reading.  I have a boatload of miles on minis doing my own alignments on fully adjustable suspension, as well as my Vw Bus and have experienced no abnormal tire wear.  The minis have always handled tip top the way I set them up. It's very easy to do them yourself and I would recommend buying these tools. It's important when setting toe to allow the car to settle and give it a full turn left and right on the wheel, and a roll forward and backwards on your garage floor to have everything settled in before you take final measurements. If you set one thing you must check the others. It all shifts around when making adjustments on one or the other.
