WANTED - CV Joints for rolling setup
Started by ADRay, May 16, 2021, 04:48:44 AM
I'm looking for a used set of cv joints that someone might have kicking around. I want to set up my mini as a rolling chassis without having to take apart my drive shafts.
They would need to work with this disc brake setup:
https://www.7ent.com/products/cooper-s-disc-brake-conversion-kit-reproduction-sbr0059e.html
thanks
@andyray998
bikewiz
I may have a set. I think I kept the old set. I'll look tonight.
@andyray998
bikewiz
Sorry Andy I guess I chucked them, I found pretty much everything else for a front end just not CV's.
Mine are for drum brakes, if I still even have them. I also tend to chuck out stuff like this that I don't need anymore.....
Pretty sure I just tossed a pair of old axles out of a drum brake MK2 front end into the scrap pile the other day. They definitely were not pot/CV joint style but the old rubber u-joint style. If I understand what your trying to do I don't think you care about the inbound motor side, you just want the outer axle so you can bolt on the hubs?
Seems like the axle nut is a different size between the drum and disc brakes though, so not sure if they would work for your situation.
Quote from: MiniDave on May 19, 2021, 07:01:11 AM
Those will work if they are off the later pot joint style set up.
Quote from: cstudep on May 19, 2021, 08:27:22 AM
Yes. I'm looking to be able to set up the front hubs without driveshafts without taking mine apart. They could even be a pair that are damaged as far as where the drive shaft bolts on.
Thanks for looking George
@andyray998
­čí▒ ­čí│
