Mini compatible Parts
Started by mini_fly, March 25, 2009, 05:26:45 PM
MG Midget rear brakes fit a Mini rear brake back plate. There are two sizes the smaller ones are the ones that work i have not looked into the wheel cylinders though.
A Dodge Dakota by pass hose will work for a 1275 top radiator hose.
Red Riley
I've got it from a reputable source that a D16Z6 VTEC Honda motor will fit into a Riley Elf.  71.gif 77.gif
Quote from: Red Riley on August 24, 2020, 11:15:25 AM
:D
But the trick is to remove the A-series first!
Good info on oil filter quality.  Unfortunately I just bought a fram filter.  Looks like I'll switch over to wix or Napa gold.
#29
Quote from: 94touring on March 25, 2021, 05:53:50 AM
This is the NAPA (Wix) one I use in my Mini.  It's nice and tall for extra filter material and slightly more oil capacity.
I just went on the ebay and got a box of 12 wix 51374 at $6.60 each.  My tundra uses the same filters too so they'll get used up between that and the minis.
Quote from: 94touring on March 25, 2021, 09:43:41 AM
Always nice when one filter fits multiple cars in your garage!  My wife's Infiniti (gone now) and my Triumph bike both used the same oil filter.
#32
Used my last new set of NGK BP6ES/733 the other day. It seems that NGK has discontinued this plug. Buy em if you can find em till they are gone if you like em. Guess I need to try something else now.
What's special about the 733? I can still get BP6ES plugs....£2.20 ea. on MiniSpares.....
#34
I'll send you a pack.
Edit. Would appear they are discontinued per NKG.  Here's a chart also explaining what the new replacement BPR6ES plug may be.
#35
And also worth noting some info I dug up on another mini forum.  Interesting enough my mini will scramble the neighbors TV.  More pondering I'm wondering if my aldon amethyst issues of random ignition breakup weren't related to the electronic dizzy but rather the plugs  8.gif
"If you have resistor spark plug wires, use "regular" plugs. If you have solid core (non-resistive) spark plug wires, use resistor plugs.
Do not use resistor plugs with resistor wires as this may reduce the spark energy. Do not use regular plugs with solid core wires if you like listening to the radio and respect your neighbors."
I'll buy a few sets from you if you can spare them..............
I'm sure I can spare a few.  I don't even run heat range 6 anymore and certainly won't once the turbo goes on.
Quote from: 94touring on March 27, 2021, 04:43:42 PM
If you a set or two extra I would be willing to buy them from you.
Thanks
I was doing some more research and found you can take the resistor out of resistor plugs and put in a piece of solid copper wire and convert it to non resistor.  I'll try to find time to try this experiment in my shop when I'm home next month.  Might be an easy enough work around once these NKG's dry up and can't be found.
Well on NGK and Bosch plugs I was unsuccessful on taking the resistor out.  Youtube showed autolight plugs being unscrewed and the resistor replaced but on NGK and Bosch it doesn't screw out, but rather bust a shaft off internally. Perhaps the shaft has resistance. Either way it wouldn't go back together without some doubt on how well it would hold up.
Yeah, so just use the regular plugs then?
Quote from: MiniDave on April 13, 2021, 01:56:53 PM
As of now unless I can figure out a trick I'm missing.
Resistor plugs and non-resistor wires?
You are already using an extra-high voltage coil that should more than compensate for the reduction due to the resistor plugs.
Quote from: MPlayle on April 13, 2021, 06:33:02 PM
No, there's some plugs you can remove the resistor to make a non resistor plug.  I was hoping it was easily done on NGK plugs but it's not the case.  But yes, resistor plugs in my case shouldn't be a big deal, although I'm going for maximum spark too.
I guess one option is to buy Champion N9YC non-resister plugs (instead of Champion RN9YC plugs).  Champions may not be as highly regarded as Bosch and NGK, but they readily available to use without having to attempt any modification if you want to try a non-resister plug and see how they work out.
https://www.amazon.com/Champion-N9YC-300-Copper-Spark/dp/B000CSNODA
#46
Here's a heat range chart for reference.
#47
Brisk D14YC is the same as a heat range 6-7 in NGK, non resistor, and a few bucks a plug. I had used their gapless plugs experimenting around a couple years ago with decent results.
Anyone know a cross reference for the radiator cap on a standard Mini (998) radiator?
The one on my recently acquired blue 1983 Mini Van is in poor condition and I am trying to see what may be available locally.  I tried a search on this site, but came up empty.
I tried searching for a cross reference using the part number from a couple of our favorite Mini parts suppliers, also to no avail.
Any help would be appreciated.
It's a very common size, but you might try the local Autozone or  OReilys for one for a Sprite.
