Coil Resistance
Started by notabmw, May 13, 2009, 07:36:46 AM
notabmw
I am using a Lumenition Magnetrinix MTK007 electronic ignition.
What resistance coil should I be using?  I was told 1.5 ohm?  Is this correct?
The car is 12 Volt, Chasis Ground.
notabmw
Wait, did you just answer your own question?  ;D
notabmw
Quote from: 94touring on May 13, 2009, 02:58:54 PM
LOL... I could not wait, so I called the mgf. and got the answer..
Hey you should ask more questions!
notabmw
Quote from: 94touring on May 14, 2009, 07:08:18 PM
I will.  But patience is not one of my stong points :)
d-m
Ok i need to be let out of the dark here.If a Lumenition is referance to a type of optical triger whay the consern for the coil resistence?
Dave
mascher
The Luminition Magnatronic is a magnetic trigger, yes the name is confusing. The significance of the coil impedence is related to the electronics built into the Magnatronic after the trigger. There are transistors most likely fabricated on an integrated circuit that drive current into the low voltage side of the coil and quickly disconnect it. This causes the magnetic field inside the coil to collapse and generate a high voltage spark.
Hope that helps,
Kelley
