Wanted : New Project- Few parts needed
Started by jedduh01, April 20, 2013, 08:00:11 PM
I like to have parts ready to install when its time! Kinda putting the cart before the horse
Big item needed- LHD Steering Rack. Needed ( with Tie Rod Ends Preferred)
Mk 1 - Turn Signal Stalk + Mk 1 column Covers if possible.
Any reasonable 998 Engine options out there? Running? Needing rebuild Close to Charlotte NC?
Please let me know- Email in Contact info area!
I have a 998. Was running when I pulled it from the car about a month ago. I'm not sure what it needs, but I'm fairly certain the transmission needs to be pulled off and checked out. The engine was pulled because shifting wasn't easy and the forum specialists diagnosed it as a throwout bearing. Easy fi if it's the problem. But I make no claim that that is the problem. I decided to just go ahead and build my new motor instead of going through this one.
The head and piston tops were cleaned of all carbon months ago, and a new copper head gasket was fitted. Didn't have any leaks, but it's an original 998. Might want to just rebuild it if you're going to dig into the transmission anyway.
I don't know what it's "worth" to everyone else, but it has the alternator, distributor, fuel pump, engine mounts. I would think it could bring at least $650 for all of that.
Mouse...   Thanks for the reply-  I also saw the post on MM about it. Ill shoot you an Email offline about my questions.
