Noisy belt with headlamps
Started by ADRay, Today at 03:54:42 AM
Any ideas why my belt screeches like a bat out of hell when I turn on my headlamps? Usually only when starting off and stops when I'm up to speed in 4th. Not a new problem since the alternator replacement.
@andyray998
Turning on the headlights adds to the load on the alternator, increasing the effort needed to turn it.  The belt may need just a bit more tension to not slip due to the increased effort needed by the alternator.  You may also need to clean/scuff the alternator pulley as it has possibly glazed as well.
Make note of the current position of the belt adjuster(s).  Loosen the belt enough to hand spin the pulley.  put some brake cleaner on a rag and rub in the groove of the pulley while hand turning it to clean the pulley.  Retighten the belt to the original position or just a fraction tighter.
Dan Moffet
Check the belt for glazing (shiny) or cracking. If your belt has stretched or is wearing out, it is time to replace it. Clean all the pulleys if you can. Make sure the water pump and alternator (or generator) turn freely - a seizing bearing can wreak havoc.
Don't over-tighten a belt or it will break some dark night. It should have some flex (about 1/4") when pressed firmly at it longest span between pulleys.
In the "old days" when V-belts were common, you could get belt dressing (a bit like ski wax) which improved grip. An old trick to quickly quiet a noisy belt was a couple of drops of auto transmission fluid, conveniently applied from the transmission dipstick.
