Leaky fuel pump (?)
Started by ADRay, June 29, 2024, 11:49:13 AM
I finally got a new battery and was able to fire up my mini for the first time in almost 5 years. Problem is, I'm getting a fuel leak at the top of my mechanical fuel pump. I've replaced and refitted the hoses and clamps several times to no avail. I can't tell from watching it where it might be leaking from.
Looking around, they don't seem to be rebuildable, so I guess my question is, is there any where else it could leak from?
It's the old unit that had been left on the block while it was off line. The inlet and outlet fittings seem to be a little loose - is that normal?
@andyray998
As far as I know, the fittings should not be loose.  I will try to get out to the garages and see if I still have the mechanical pump I removed from my Van to be sure.
Thanks for looking. also, it only seems to be leaking while it's running. I dried it off completely and it has been sitting for about 90 minutes
@andyray998
The fittings should not be loose, try tightening them if they are threaded, otherwise what I've seen is the diaphragm just under the lid dries out and shrinks, then it leaks.
I don't know if you can get a rebuild kit for it or not, but new ones aren't that expensive. Be sure to get the gaskets for where it bolts onto the block....sometimes they come with the new pump, sometimes they don't and you would hate to have it off and not be able to bolt it back on again.
#4
I found my leftover mechanical fuel pump.  All of the fittings are tight.  I did a manual test and it still seems to work fine.
There is a tiny breather hole underneath for the pressure changes of the diaphram and mine pushes a small puff of air when I move the cam lever.
If you send me you address, I will send you my pump.  I can have it in the mail later today.  I don't think I have the gasket, but I will look.
Edit: I do not have the gasket.  Let me know if you want the pump.  We can settle up on postage at a later time.
Thanks, I ended up picking up a new unit.
Now that the dust has settled from my "vacation", I'm picking up where I left off with this.
Question though - I have to replace this fuel pump after I have filled the engine with fresh oil. How much oil should I expect to loose when I remove the fuel pump?
@andyray998
You really should not lose much if any oil.  The fuel pump is driven by the camshaft in the block and I believe it sits high enough to be above the oil level sinc emost of it is in the gearbox/sump.
I wouldn't think you'd lose any oil.
Yes, as long as you use new gaskets, then it should stay dry!   :great:
I'm kidding, like they said, it sits way above the oil level, so no worries....
thanks again everyone.
this is where I go to get clear, concise and experienced answers to all of my odd (Mini related anyway) questions  that I can't get anywhere else.
I really appreciate it.
@andyray998
