Aluminum 5 main A series Block!
Started by MiniDave, January 30, 2021, 01:39:12 PM
Did they happen to give a price?  I didn't listen to the whole video.
No...... I think it's one of those "if you have to ask you can't afford it" deals!
It's interesting that it was designed to take either the BMW 4 valve motorcycle head or the 12G940
The space between #2 & #3 where the headgasket would go looked razor thin to me......
Of course, you also need the crank and connecting rods for the 5 main crank setup.
They talked about up to 600 HP and 10K+ RPM! And of course there are NO mini transmissions capable of handling that sort of power.....so I guess that's next?
Quote from: MiniDave on January 30, 2021, 02:45:01 PM
It's a little hard to tell but it did not look like it had been sleeved yet so perhaps that will thicken up a bit depending on how they go about that part of it, either a traditional sleeve or the newer plasma sprayed coatings some use.
10,000 RPM!  Wow.
They didn't really talk capacity either.  I wonder what size the prototypes will be built as?
#5
Stock 1275 + 40 over is what I'm reading.
Early engines "only" 350 hp!
If you scroll down their Facebook page they have an interesting take on the 5 main crank, using a tapered and splined end for the flywheel, and a pressure fed thrust washer on the rear main instead of the center mains. They also have  a unique design for the con rods that they claim are in fact good for 10K RPM and 350 hp.
Oh, and the main caps are 4 bolt.
All the stuff Honda and Chevy already do.....
https://www.facebook.com/Ascaso-Engineering-111874667308270/
