73 Mini Innocenti 1300 Export
#825
It was a dead coil. But also a dead fuel pump?   Unless it was the quietest fuel pump ever made.  I'll have to test it and see. :embarrassed:  :017:
Spinning off from my 5 speed post in the performance section...  pretty sure I'm going to make the leap and do it on this car.  Once the current customer car is done anyway. Motivation.  I was thinking the other day I never really paid much attention to what tunnel the inno had. Originally for the year it would have been a remote tunnel shell to go with it's current remote shifter, but the car was reshelled using a new shell sometime in the 80s. Yesterday verified it is indeed a square tunnel for rod change.  Since 5 speeds are all rod change, the conversion will bolt right up.
I never could hear the fuel pump run except when in the garage with no other noise sources.....and then it was only a quiet buzz hummmmm sort of noise
Quote from: MiniDave on November 08, 2024, 03:09:39 PMI never could hear the fuel pump run except when in the garage with no other noise sources.....and then it was only a quiet buzz hummmmm sort of noise
I haven't gotten around to bench testing it yet. It probably works, just made 0 noise.
With the temps out of 100 and back into the 80s I decided to give the inno a wash and bring it downtown for the weekend. Stopped at a gas station to top it off and on shut down got a billowing of smoke coming from the dash on the left hand side. Got the dash off enough to peak at the wires, since some harness goes through that side, but couldn't find any culprit.  Kept on driving and didn't smoke again.  No clue.
It's always exciting when you own a Mini!
It didn't even smell smokey. But there sure was a lot coming out. A real mystery.
Did we ever shrink the wrap on the wires up under the scuttle? Maybe one slid off and shorted momentarily?
Today's mishap.  Another dead coil.  Happened in the parking lot so at least I was off the road.  Since this is the 2nd 1.5 ohm coil I've burnt up, I'm going to assume it needs a 3 ohm, even though minispares said the distributor was a 1.5ohm unit. Took me all of 2 minutes to diagnose and fix.  The easiest way to tell was the engine turned over quicker than usual, indicating no spark.  I had a spare  3 ohm in the boot and swapped them out in record time.
The engine turning over faster than usual is what mine did when the coil and condenser went out.
The electronic module I went to uses a 3 ohm coil as does non-ballasted points (what I originally had) so I did not have to change from the replacement coil when I first got it running again on the points.
Instantly died, not a slow sputter like fuel was being starved as the floats go empty. Then turned over as if all 4 plugs were removed.
Mine was actually a combination of both: died when ran out of fuel due to vacuum lock at the tank, then while trying to restart it the coil and condenser went and it cranked fast like you describe.
I had to fix the fuel issue before finding the ignition issue.  Mine is all happy now.
More electrical gremlins, which might explain the dash smoke.  No fuses on the box ever blew.  Tonight on a drive turned the headlight dash switch on for driving lights and got headlights when using the column stalk. On these Innocentis there's another switch on the dash that turns on the gauge lights. Flipped the gauge light switch and nothing, but the speedo light was on regardless. Got back home and with the headlights off the gauges light up, but the speedo light stays on. In fact it stayed on with the ignition off.  We installed a quick disconnect on the negative terminal of the battery which turned off the lights once and for all.  I'll have to dig into the dash once I get time.
Can't catch a break this week. Another fuel pump shit the bed.  2nd one in about a year.  It works if you hit it with something for a moment or two. Happened at  the shop at least shuffling cars around.
Had some time yesterday evening to dive into the dash to try and solve the dash lights not shutting off problem.  It was evident quick what the problem was. Something touched something which melted wires.  Explains the smoke.  I got to rewiring it and voila lights and no fires.  The fuel and speedo lights had never worked however. Neither were burnt up and they're wired in series to the other bulbs.  Come to find out the harness just didn't have a good connection where they crimped the wire to the female ends.  Redid that and it all works. Still need to dig into the stock water temp gauge that also doesn't work.  I might have time this afternoon to look into it.
I hate it when that happens......such a mess. I'm glad it was simple to sort out at least.
Fully functional water temp gauge again.  As a bonus installed an aux fan on the back of the inner wing since it tends to run hot at idle on a hot day.
