5/16-18 Time Sert Kit
Started by MiniDave, August 09, 2017, 12:04:08 PM
Anyone have one I can borrow? I need to fix one hole - on a shift knob - and I don't want to spend $65 to buy a whole kit for one damn insert.
I could also use a Keen Sert I think.....
The problem is I screwed up and used a 5/16-24 heli-coil, so now I need to go way oversize to correct my mistake.
Never mind, I was able to fix it with a Heli-coil after all.
Dmulder
Maybe I'm stupid. What is a time sert kit.
It's a way to repair bad threads, you drill the hole oversize, then rethread the hole and thread in a coil that brings the threads back to the original size.
Sorry, I posted a Heli-Coil video.
This is a Time Sert, same idea slightly different construction.
#6
I've never had one that a heli-coil couldn't fix, but if you have a hole that's really wallowed out a Time Sert might be the only way to fix it unless you weld it up and start all over again. In a lot of cases you can't do that, so it's a legit repair.
The kits are fairly expensive compared to a heli-coil kit, and one size only covers one size hole, you need a completely different kit for any other sized hole........then you have the extra step of machining the shoulder too...
There also is a thing called TwinSert (a heli-coil within a helicoil) for those cases where the hole is bigger than a single heli-coil will fix. Fairly common in turbinbe engine repair.
