68 Mini Pickup Project
Started by 94touring, June 27, 2009, 02:46:22 PM
"Nothing is particularly hard if you divide it into small jobs"   ;D
Got her welded into place, now to do the other corner.
Ok to finish it off I had to fab up the elbow brace that sits behind the corner.
Also I took off a bunch of bondo along the side, found a few dents and dings, but the most impressive thing were two holes in the upper corner that were simply filled over with bondo rather than welded closed.
MiniGene
Looks good!  What area are you moving onto next?
Well I want to get the other corner done, the valance on, and then I need to tidy up the front left a little.  Then its the floors.  I have a few patches in the bed to make, and looks like the left side of the body is going to need a section cut out and replaced, but thats easy.  Get this rear end done and the floors and I'm home free.
Managed to fab up a new bracket for the tailgate hinges and patch up the bed where it all goes together.  Was more of a PITA than I was expecting.  Tomorrow I may start fabbing the right corner.  After clamping things together it looks like the valance is a tad too long and I may need to shorten it about a half inch.
MiniGene
What condition is your tailgate in?  Do you have to do any work to it?  I saw your post about FG parts.  I didn't even know they made a FG tailgate.
Its in good shape aside from some dents, but I like the idea of shaving weight and having something that can't rust.
Ok so here's what I got done today.
Before
After
Other corner cleaned up.
MiniGene
Nice progress!  What are your plans for the color?
I'm still leaning toward a bright metallic orange and white roof.  Next week I should get the rest of that rear end done and move on to something else.
Didn't get to do anything with the truck this week, had a big list of house chores to catch up on.  However next month I have a lot of time off and hope to tackle a lot of body work.
Ok well got a chance to organize at the shop today, sort through boxes of tools, and play with the rear valance a little.
Is this a Keeper or are you selling it.
If you are selling, lets talk. :D
Quote from: Jims5543 on May 20, 2011, 04:30:03 PM
LOL i've heard that before!  This is a keeper, if I ever get the damn thing done!
MiniGene
Glad to see you're working on the truck again.  I thought it was going to be put on the back burner for a while.
I need to get out to the garage and back to the 77.  I've been distracted with other things as of late.
I intend to keep working on it.  Should have done more the past couple days but motivation levels have been low.  On that rear valance I had to chop it in half and reduce the length by about a half inch to get the ends to line up evenly on each side.  Welded it back together and clamped it up.
MEhinger
Dan, where do you buy sheet metal stock and what gage do you buy?
I just get it from home depot or the like.  22 gauge is what I'm using on a lot of areas, its a little thinner.
MEhinger
22 gage!! Then I admire yous skills with a mig even more. That is hard to weld.
Yes its thin  ;D  Ok moving along, today I thought I'd poke at this area and see what I could uncover.
It was badly dented in with about 3/4" of bondo and rust underneath, so I cut the bastard out.
Double layers again for no apparant reasoning.   :-[
And got part of the side fabricated and tacked into place.  Will not need 10lbs of bondo now.
Gona be a lot of work back there...
#145
Hey finally touched it!  Rear corner complete, tomorrow gona try and get the inner areas painted and throw on the valance.
Ok the rear is done.  Primered and sprayed with some white acrylic enamal I have.
MiniGene
Progress!!!  Looking good.
Ordered rave fender flares today.  Similar to wood and picket, just a tad wider.
MiniGene
I had to look those up, I had never heard of them before.  They look nice and clean.  Are you going to paint match them to the body?
