Fresh air hose.
Started by Spitz, November 02, 2015, 08:22:13 PM
Spitz
Is this available?
The hose goes from under the bonnet through the dash and down to the early fresh air heater.  Opening on the heater is 3.25".
I have all of the coil....maybe it can be covered(?)
Also....how do I detach the window defrost tube from the back of the heater?  Don't want to bust anything
I have heard that McMaster has tubing similar to the large diameter fresh air hose.
As for the smaller demister hose, from the picture you attached I would try "unscrewing" it some and see if it loosens.  I don't have much familiarity with those earlier style heaters.  The early Minis I've had had slightly later heaters where the demister hoses slid over the outlets on the sides.
I'd try unscrewing the small hose.  The big hose I've often wondered if the rv hose I see in wal mart in the automotive aisle is the same diameter.
Are those rocks inside the large opening?????
Spitz
No...they are oblong food pellets of some kind I think...maybe burner pellets(?)   They heater was absolutely full of it....obviously a mouse was making a home or stash
#5
McMaster definitely has the duct.
7 Enterprises may now be selling it as well.
This what I used:
5499K447 High-Temperature Blo-R-Vac Duct Hose for Dust, 3-1/4" ID, 3-3/8" OD, Black, 12' Length
http://www.mcmaster.com/#catalog/121/254/=zojsvi
Terry
Spitz
Thanks very much for that link....thqat is some pricey stuff!  ( was that a typo you made...should it be 5499K247?)
Is the cheaper stuff above it ( 3.5"OD 53145K64 ) going to be too large to fit through the holes?  It's nearly 1/2 the price
BTW...I got the small hose out...yes, by turning it out.
Is the defrost tubing available?
Yes, the price has gone way up since I last ordered.
They have other materials, but I went for the heat resistant double coated style
