In the early stages of buying the official restoration-mini garage
Started by 94touring, October 11, 2015, 07:49:10 AM
Looks like it just high enough that you will need to watch when moving it about.
Did you put the swivels on one end or one side?
How do they roll?
Why did you choose this over an engine hoist?
Brad the only thing it hits is the garage door motor but clears the lights no problem.
Dave, initially was going to just buy one of those however all this really set me back was the $80 dolly hoist.  Plus I have always found the legs on a cherry picker get in the way.  With the gantry it should be easier as well as more stable.  Not to mention way cooler.
Oh and rolls great!  Swivels on one end..not sure if one side would be better.
MtyMous
The bracket on the upper I-beam looks like a koala. Can't be un-seen.
Found a good deal on a lever hoist.  The chain hoist has a lot of chain!  Plus I'm pretty sure this will work well on the rotisserie.  Also added a low profile 3 ton floor jack to my arsenal.  4.gif
Tell me when you are ready for my pickup it was "restored" in England in 2004 so it should be an easy project.
;D
The big compressor is finally up and running.   Thank you to Merlin/Justin.
Merlin
Not a problem!
Now lets build a paint booth... Preferably faster than it took to do the damn compressor.
Next time buy a building with 3 phase power!
Engineering the Impossible
Just as soon as we put a slab on the compressor side, seal it off, add tons of lighting, and add ventilation  77.gif
Merlin
MtyMous
What kind of low profile jack did you get? If it's the Harbor Freight or Northern Tool type, look into the spreader bar attachment.
Yeah hf Pittsburg job.  One of those spreader bars is on the list!
Finished off the piping for the compressor.  Changed the oil and cleaned off the inside face of the oil level indicator to be able to see what it reads.  The old oil looked like mustard!  Glad I decided to change it out.  I can't stress how pleased I am to have quiet air in the shop...seriously amazing, especially after years of non stop noise.  Not only that but you can run air continuously and doesn't phase it.
What did you do for a motor?
Do you have a dryer on the circuit? What kind?
Does your area get the summer humidity we do?
7.5 horse single phase.
There's a water separator just prior to the 3 way splitter.  Just the standard one you buy from Lowe's.
Gets fairly humid.
My pressure regulator is kinda crap so probably will improve on that.
Most shops run a separate line for the paint gun, with an extra water trap and oil filter on it....don't you run a small pressure regulator and water trap right at the paint gun?
Pressure regulator at the gun yes, a 2nd water separator no.  Never had issues with moisture and don't need to make the gun bulkier than it already is.
Merlin
If it becomes an issue at all, let me know and we will add some knockouts for you.
Quote from: Merlin on February 23, 2016, 04:18:20 PM
I had to put the compressor on blocks to get it high enough for the piping to clear the floor.  Luckily the jack did all the lifting.
Well I tried a couple different pressure regulators.  Both leaked.  Before I ordered something high dollar online I bought a harbor freight special for 5 bucks.  Works perfectly.  Go figure.
Well after much agony I'm finally actually closing on the shop.  Turns out buying a garage is tricky business.
