How do *YOU* install heavy wheels?
Started by ve9aa, September 14, 2026, 01:32:11 PM
ve9aa
"Heavy" depends on your age, how strong you & your back are, your health, etc. I am starting to get there on all 3 counts...
I made this today to install & remove wheels on 3 or 4 cars here every 6 months (fall & spring) as we do the winter/summer wheels & tires in NB, Canada.
Haven't tested it - I'll know in about a month if it works!
p.s.- no idea why the 2 pix uploaded sideways. Look ok on my computer - sorry
Mike in NB
Forum glitch. Clicking on sideways pics immediately puts them in the right orientation.
As far as wheels go, my tundra wheels are fairly big and heavy. I use my man strength to take them on and off.  :cheer:
ve9aa
Quote from: 94touring on September 14, 2026, 01:39:26 PMForum glitch. Clicking on sideways pics immediately puts them in the right orientation.
OK on the pix. Tried - worked. Now I know.
I used to have the "man strength" as well Dan.  It's been a hard year for me in/out of the hospital several times this year (not looking for any sympathy, mind) so this "invention" (not my idea) I stole should help
with the heavier wheels/tires alignment, such as the Subaru Crosstrek we now own.
The BINIs wheels aren't overly heavy, even when you're bent over but the F'n conical rim holes onto the hubs are brutal to get the wheel aligned and stuck on there well enough to get a couple bolts started.  I need 3 or 4 hands. What a cr@p design. LOL
I bet this'll help.  At least I hope so !
Mike in NB
What you created looks similar to what I've seen the mechanics use to change out plane wheels.
ve9aa
Mike in NB
#5
Every car I own except the classic Mini has those damn wheel bolts, so I got a long bolt of the right thread, cut off the head, then screw it in. Lifting the wheel onto that stud is not nearly so hard when it has a place to "land".
For my 18" Audi wheels I sit on the ground and use my legs to lift the wheel while guiding it onto the stud.
The other idea I've seen is to use a long rod stuck thru the bolt hole on the wheel - insert it into one of the bolt holes and lift using the rod's leverage, then slide down into place.
Tire lifting rod
Interesting device, never even occurred to me to try that method. Knowing my luck I'd just end up bending or breaking the wheel stud lol. It would make it a lot easier if it actually worked like the video shows. The wheels/tires on my 3/4 ton truck have to weigh close to 100lbs, never weighed them but the tires themselves are about 70lbs.
Dan Moffet
You guys must be buying the wrong vehicles! Everything I've owned for decades has wheel studs with nuts. The last car I can remember for certain that had bolts was a 1937 Plymouth. (I was maybe 12 at the time, so I'm not THAT old!) Even back then they had the decency to provide a small guide post protruding from the brake drum that fitted into a corresponding hole in the rim - not one of the bolt holes. When installing a wheel, you had to be mindful of which side of the car you were on, because the left side wheels used left-handed bolts.
Large trucks and busses use studs and nuts.
Makes me wonder if your studless cars could be converted to using studs. Shouldn't be that hard.
Germans seem fascinated with the lug bolts, Audi, VW, MINIs, BMWs, Mercedes all use them.....
My FJ Cruiser Wheels are probably 80-100lbs each, I jut get them to where they are barely off the ground and use the top of my shoes to lift them into place, they go on studs to its pretty easy to line up.
On my M5 with 20" rims and 300 wide tires those are heavy too, same deal just more tedious due to lack of studs (refer to above, Germans love their lug bolts) I can usually get it close and on the centric hub them rotate slightly to get one lug bolt in then its easy.
Wife's R53 and the classic are non issues both have lightweight rims and are easy to lift, even with my back injury (L1 to sacrum bulging/degenerating disk) they are not a problem. That is a pretty cool setup though. Good idea!!
