Soliciting thoughts & opinions - power upgrades to a 998
Started by MPlayle, September 05, 2026, 06:10:14 PM
As the title implies, I am looking for thoughts/opinions on methods for getting a bit more power out of my 998 engine.  I find running with highway traffic at 4K rpm for much time is tiring on me, though necessary for getting in/out of San Antonio.  There are also a few hills that Bruce and I go over on our drives to area C&C events where I still lose significant momentum on the uphill.
The engine currently runs very nicely: has good oil pressure, does not overheat, gets me 30 - 33 mpg regularly.  The transmission/differential is currently set up such that 4K rpm is 70 mph (3.1 final drive, but non-standard drop gears make it act like a 3.2 final drive)
The engine spec as it is currently: stock pistons and cam; alloy intake manifold supporting a single HS-4 carb with a K&N filter in a modified stock air box; LCB exhaust; Mini Sport "Stage-3" 998 head with mild porting and bigger valves; forged 1.4:1 ratio rocker arm set.  The head and rockers were done to boost the power slightly from stock when I changed the final drive to the current setup.
What I would like to do is add more power so I can change the final drive again to either a 2.95 or 2.76 to lower the rpm more when doing highway speeds while still having sufficient power/torque for the winding hill country backroads.
The approaches I know of are: 1) upgrade to a 1275 based engine; 2) overbore and change the cam in the current 998; or 3) add a turbo kit to the existing spec.
Please chime in with your thoughts, pros/cons of the above approaches, any other alternative approaches.
#1
1275 motor/gearbox would be my first choice because it's all bolt in. Turbo to the existing engine would be second choice because kits exist that again are (supposedly) bolt on stuff, but spendy ($5K+).
I run a 2:76 in my green Mini, 70 mph is about 3300 rpm, 75-80 is 34-3600 rpm. I only have to downshift to 3rd if it's a really steep hill or if I'm at altitude (Colorado Mtns)
I like turbo motors in general, don't know what to expect from the Jet motors kit on a 998, but the mods you've already done will help quite a bit, I would call Jeremy and see what he says.
I had planned on trying to speak with Jeremy at Jet Motors about their kit on a 998.
The 1275 option is at least as spendy as the turbo kit and it leaves me with the 998 still sitting around.  Being in an apartment with detached garage makes storing things like an extra motor a bit iffy.
With all the work you have already done to the 998 engine I think I'd lean toward adding the turbo. Expensive but a 1275 upgrade will be as well. I suppose the advantage of the 1275 upgrade is the potential to sell the 998 to recoup some cost, but I don't know what the demand is for such things. Generally speaking if someone is going to buy an entire engine, its likely going to be of the 1275 variety.
Quote from: cstudep on Today at 10:33:56 AMWith all the work you have already done to the 998 engine I think I'd lean toward adding the turbo. Expensive but a 1275 upgrade will be as well. I suppose the advantage of the 1275 upgrade is the potential to sell the 998 to recoup some cost, but I don't know what the demand is for such things. Generally speaking if someone is going to buy an entire engine, its likely going to be of the 1275 variety.
Those were some of my thoughts as well.  I am also inclined to think the cost of rebuilding/enhancing the 998 (non-turbo approach) will likely be about the same as the turbo kit (pistons, rings, bearings, cam, machine shop work).  I am not really into the Honda engine swaps and those tend to be spendy as well.
Yeah the Honda swaps are pretty spendy these days, probably the most expensive option actually. Just a worn out v-tec with transmission is getting pretty costly these days.
If you have a small bore stage 3 head with bigger valves you really need the cam to go with it. You might actually be a bit soggy down low with a stock cam on a performance head with bigger valves, though the 1.4s will help a little.  Adding a nice street cam like a 266 or evo1, both would work great with 1.4 rockers, simultaneously going taller on the gears will make it feel equally "slow".  You'll utilize 3rd gear a lot to pull hills.  3.1 or your 3.2 is a great compromise as is for doing highway speeds.  To run a 2.76 in my humble opinion takes a large bore with power or better yet a turbo.  I'm not a fan of taller gears because it's just lazy feeling to me in a mini.  I still want a 5 speed for the best of both worlds.  Also what's your compression ratio?  Bump it up to about 10:1 with the cams listed above. If you're running low compression right now that alone will liven it up.
