Soliciting thoughts & opinions - power upgrades to a 998
Started by MPlayle, September 05, 2026, 06:10:14 PM
As the title implies, I am looking for thoughts/opinions on methods for getting a bit more power out of my 998 engine.  I find running with highway traffic at 4K rpm for much time is tiring on me, though necessary for getting in/out of San Antonio.  There are also a few hills that Bruce and I go over on our drives to area C&C events where I still lose significant momentum on the uphill.
The engine currently runs very nicely: has good oil pressure, does not overheat, gets me 30 - 33 mpg regularly.  The transmission/differential is currently set up such that 4K rpm is 70 mph (3.1 final drive, but non-standard drop gears make it act like a 3.2 final drive)
The engine spec as it is currently: stock pistons and cam; alloy intake manifold supporting a single HS-4 carb with a K&N filter in a modified stock air box; LCB exhaust; Mini Sport "Stage-3" 998 head with mild porting and bigger valves; forged 1.4:1 ratio rocker arm set.  The head and rockers were done to boost the power slightly from stock when I changed the final drive to the current setup.
What I would like to do is add more power so I can change the final drive again to either a 2.95 or 2.76 to lower the rpm more when doing highway speeds while still having sufficient power/torque for the winding hill country backroads.
The approaches I know of are: 1) upgrade to a 1275 based engine; 2) overbore and change the cam in the current 998; or 3) add a turbo kit to the existing spec.
Please chime in with your thoughts, pros/cons of the above approaches, any other alternative approaches.
#1
1275 motor/gearbox would be my first choice because it's all bolt in. Turbo to the existing engine would be second choice because kits exist that again are (supposedly) bolt on stuff, but spendy ($5K+).
I run a 2:76 in my green Mini, 70 mph is about 3300 rpm, 75-80 is 34-3600 rpm. I only have to downshift to 3rd if it's a really steep hill or if I'm at altitude (Colorado Mtns)
I like turbo motors in general, don't know what to expect from the Jet motors kit on a 998, but the mods you've already done will help quite a bit, I would call Jeremy and see what he says.
I had planned on trying to speak with Jeremy at Jet Motors about their kit on a 998.
The 1275 option is at least as spendy as the turbo kit and it leaves me with the 998 still sitting around.  Being in an apartment with detached garage makes storing things like an extra motor a bit iffy.
With all the work you have already done to the 998 engine I think I'd lean toward adding the turbo. Expensive but a 1275 upgrade will be as well. I suppose the advantage of the 1275 upgrade is the potential to sell the 998 to recoup some cost, but I don't know what the demand is for such things. Generally speaking if someone is going to buy an entire engine, its likely going to be of the 1275 variety.
Quote from: cstudep on September 06, 2026, 10:33:56 AMWith all the work you have already done to the 998 engine I think I'd lean toward adding the turbo. Expensive but a 1275 upgrade will be as well. I suppose the advantage of the 1275 upgrade is the potential to sell the 998 to recoup some cost, but I don't know what the demand is for such things. Generally speaking if someone is going to buy an entire engine, its likely going to be of the 1275 variety.
Those were some of my thoughts as well.  I am also inclined to think the cost of rebuilding/enhancing the 998 (non-turbo approach) will likely be about the same as the turbo kit (pistons, rings, bearings, cam, machine shop work).  I am not really into the Honda engine swaps and those tend to be spendy as well.
Yeah the Honda swaps are pretty spendy these days, probably the most expensive option actually. Just a worn out v-tec with transmission is getting pretty costly these days.
If you have a small bore stage 3 head with bigger valves you really need the cam to go with it. You might actually be a bit soggy down low with a stock cam on a performance head with bigger valves, though the 1.4s will help a little.  Adding a nice street cam like a 266 or evo1, both would work great with 1.4 rockers, simultaneously going taller on the gears will make it feel equally "slow".  You'll utilize 3rd gear a lot to pull hills.  3.1 or your 3.2 is a great compromise as is for doing highway speeds.  To run a 2.76 in my humble opinion takes a large bore with power or better yet a turbo.  I'm not a fan of taller gears because it's just lazy feeling to me in a mini.  I still want a 5 speed for the best of both worlds.  Also what's your compression ratio?  Bump it up to about 10:1 with the cams listed above. If you're running low compression right now that alone will liven it up.
I am trying to keep cost effectiveness and ease of implementation in mind with this latest effort.
The goal is to have an engine that will confidently pull hills while providing decent highway capability/comfort and retain reasonable reliability.
One of the current issues is the non-standard drop gears.  They shift the effective behavior of the final drive down one rating.  Examples: the originally installed 3.44 set acted like a 3.76; the currently installed 3.105 set acts like a 3.2.  If I install a 2.95, it will act like a 3.1 and installing a 2.76 will act like a 2.95.
I did not know it had the non-standard drop gears until after the change to the 3.1 final drive when I did not get the expected 3.1 behavior I really wanted.  The performance of the current setup is basically adequate, but really needs just a little more "grunt" for the hills based on having the current configuration for a few years.  The better highway behavior would be a nice addition.
To get the originally desired 3.1 behavior, I need to either change the drop gears to standard (1:1), or put in a 2.95.  Either of which will mean the extra "grunt" will become more necessary.  Thus this discussion for reasoable ways to achieve the desired results ("grunt" for hills and comfort for highways).
All that said, as far as I know it is still the factory 9.4 compression of the latter series 998s.
Is it possible to just change the cam without totally gutting the insides of the block?
To get what you want will take time and money is all. Dropping in a turn key 1275+ power house with a 2.95 or 3.10 would be the easiest way.
If you do tear down what you have, get the 1098 crank, add the cam, measure measure and triple measure deck heights, chamber volumes, piston dish volume, ect to know exactly what your compression ratio is. If you do a basic compression test you'll have a rough idea what you currently have.  Tosssing on a stage 3 head may have a radically different chamber volume than stock.  These details matter.
Are the connecting rods the same between a 998 and 1098?
#11
Yes it's the stroker crank for a 998, so there may need to be thicker gasket and or block decking required to get proper deck height for piston to head clearance. Or you figure out what rods make it perfect without needing thicker head gaskets or block decking.  Benefits are low end torque increase where you want it.
So I would have to tear it all apart in order to determine what may be needed before ordering parts?
Kind of something I was hoping to avoid if possible.  But, that is why I started this thread - to get input and find out what sort of effort I would be facing.
You'd mock it up and see where the pistons top out at. Same as what I'm doing on a vw type 1 motor build with stroker crank, C height pistons, and 5.7" rods. You need to re-ring and dingle ball hone at minimum.  If there is a lip/ledge on the cylinder wall then you're looking at a bore up at that point. But this is all part of the process.
No matter what you do with the gearing you're still only going to make about 40-45 hp with a 998, it's not enough to pull hills in 4th. A 1275 will make more torque and with a 3.0 will be in the sweet spot at highway speeds.
Dan's version with the 1098 crank will give it good torque, but you're talking about a total rebuild.
If you can find a guy with a Vtec removed 1275 you'd be in good shape.
Either that or go turbo - that will give you the torque to pull hills and the taller gears.
Thanks for the link.  I will read it through a bit later for educational reasons.
As for this engine project, I think attempting to convert my 998 to a 1098 is beyond the intended scope.
I called Dave C. (MiniDave) and had a good discussion with him about the endeavor and have a better understanding of some of the approaches under discussion.  I need some absorption time, but I think I may have a target approach in mind now.
Thanks to all that have contributed so far.  The discussion does remain open to contributions.
I went out and did a compression test today for a current reference:
#1 - 152 psi
#2 - 152 psi
#3 - 145 psi
#4 - 152 psi
The plugs were all even in color - a light brown/tan on a set of NGK BP6ES plugs.
Quote from: MPlayle on September 08, 2026, 10:08:29 AMI went out and did a compression test today for a current reference:
#1 - 152 psi
#2 - 152 psi
#3 - 145 psi
#4 - 152 psi
Using my engine build app, and what A+998 specs I quickly found online, so correct any numbers if I got bad info, gives you about 8:5:1 compression around 155psi cranking
That is about what I expected the CR to be.  The engine is a 99HG31 series which online searches did not explicitly indicate the CR for.  The searches I did indicated standard 998s had 8.5 and the high-compression was 9.4.  I expected this one to be more towards the standard 8.5 which Dan's calculations confirm.
More info with that in mind and I realize building a motor in your apartment is out of your scope.  Taking that 8:5 ratio add the stroker crank and you get 9:3 compression. A size up on the pistons gives 9:4.  A worked 1110cc motor will make more power than a clapped out stock 1275 from a v tec swap. Change the drop gears to get a 3:1.
Or, with that low of compression ratio, a bolt on turbo kit would be perfect..... :great:
Get more HP but more importantly, more torque - especially at lower RPM, which lets you run those taller gears for less noise on long highway runs.
OR.......just leave it alone and use third gear up those hills and let it wind out - it's good for it to do that once in a while. Dan had no problem keeping up with us 1275's with his 998 Mini on everything except a long uphill run, once over the crest he was right there with us again.
It would be a good candidate for a turbo  at 8:5. But it needs to be tuned properly or you'll for sure be rebuilding it in your apartment.
Just to muddy up the waters a bit more :grin:  I have a 1098 (1100?) I might be willing to sell. Dave and Dan are both quite familiar with it since that is where it came from. I really probably need to clear some stuff out anyway and I am not sure I will ever use it since I have a few 1275 motors I can rebuild.
You could put your head and what not on it and basically accomplish what Dan is talking about without having to tear into a bottom end potentially. I have no idea what condition the motor is really in but it does run, Dave had it on his engine test stand, and I believe he had compression numbers and what not that all looked good. Not sure if it was in a driveable car at one point to know the trans condition.
I am not anywhere near you so the shipping complicates things a bit.
Would you sell him one of your 1275's?
The thing Dan is talking about is putting a 1098 crank in a 998 to give it more stroke. It makes a quicker revving engine that makes more power than a stock 1098. It usually needs special pistons tho.....I think Russel in Australia sells the kit and is a big proponent of it.
