My various projects thread.
How far will you go with the new paint, to the seam and the whole front end? Looks like liberal use of stone chip under the bumper and on the valance?
Well with everything else that's being done with flares and plugging old flare holes, basically the whole car minus the roof and windscreen surround.  Found a bunch of orbital sand marks on the bonnet, so fixing it too.
Merlin/Justin fabbed up wheel dollies.  Bruce's car is the guinnie pig. They work quite well actually.  Need to put your weight into the front a little but easily doable.  Floors must be clean and crack free.
I really like this idea but I would need large rubber tired casters to move on my cracked, broken up floor.
Don just bought a set of dollies for his garage, with the addition of the Midget roadster he'll need them to get everything in his garage when winter comes. His have a jack handle to raise the car up.....
He bought four of these, but they were on sale for half price.....
https://www.harborfreight.com/1250-lb-capacity-vehicle-positioning-wheel-dolly-62234.html
Dan, how do the new castors slide?  What reduces the friction?
They have ball bearings on each one.  We discussed how to improve them just a hair.  Right now they have 3 bearings per, and it may be better to have 2 directly down from the wheel studs.  As it is now the 3rd one may or may not take much load depending on camber, and 2 would eliminate some drag when rolling.  I do like them a good bit as is too.  Easy lugging your vat around.
Did up my water/meth injection today.  Fabbed up a mount for the reservoir and then it was a matter of running wires and hoses every where.  Started tuning and I'm still pulling fuel out. Started off so rich it would fall flat on it's face.  Anything richer tjan 10:5 and it's not happy. Currently hanging in the mid to high 10s and trying to keep boost steady at 20psi. Having some fluctuation issues.  Either way it's fast and loud.   Oh and it's 60cc direct to the turbo and 625cc on the elbow.
Back to my day job today, which means sitting around drinking coffee pondering car stuff.  Inevitably this means I buy things. Trying a new set of springs on the rx7 to go along with the adjustable front shocks I've neglected to buy since doing the rears over a year ago. My rubber shock mounts were worn on thr rear and I replaced those, now the fronts are and getting replaced. Also ditching this electric boost controller I've grown to hate and going to try to manually control the wastegate to see if I can get some consistency.
Manual boost controller installed. Took me awhile to get it hooked up properly, as there were no instructions and online diagrams were not consistent. Boost seems to be steady now. Only gripe is it's sensitive between the clicks on the controller knob. 4 clicks in is 18/19 psi, but click 5 hits 23psi.  Does have an allen key to lock the knob so maybe I can fine tune between the clicks.  I wouldn't mind running 23psi but I hit fuel cut, or it floods out or something. Happens too quick for me to see what my air/fuel is.
Otherwise started laying carpet in a car and got new visors to go with the new headliner.
That went in well!
How do you ever get all the body dust out of one of these when it's done - one that you don't take all the way to bare metal top and bottom and put on the rotisserie?
I just end up doing a thorough cleaning at the end.  His dash is filthy and I'm sure the seats that go back in are too.
Merlin
Is your boost knob a potentiometer a multi position switch? If it was a the first, we could put in a trim pot to adjust pressure between positions.
Engineering the Impossible
It's a spring and ball mechanical unit.  I found a diagram from the maker of my wastegate with way they say route lines.  So tomorrow will try it out.
Merlin
Right, MECHANICAL. Missed that bit.
Shock, spring, and bumpstop day. Old bump stops were non existent.
#140
Also put on the sway bars. These springs are stiffer than what came off, plus the adjustable shocks tighten it up. With the new bump stops it actually rides smoother though.
LilDrunkenSmurf
Just an FYI, I'm totally in love with your FD. It's one of my all time favourite cars, and extremely hard to find LHD in Canada these days.
RHD versions are a dime a dozen up here, but still cost >$15k CAD. I saw a bone stock LHD go for >$40k.
They are becoming hard to find here too, at least for one that's in good shape.  Prices just keep going up on them too.  Going to try to get an alignment today after I fiddle with a few things from yesterday.
Yea I think the latest low mileage example on BaT went for 32K or so.
Finally fixed the boost problem.  The diaphram wasn't torn, but two of the four tiny hex screws that hold the diaphram body to the plunger had worked themselves off. This allowed a leak, which in turn caused crazy boost. Probably why my engine blew to begin with.
OK, problem found and corrected.....time to do some tuning and driving.  62.gif
I made easily 30 pulls after fixing this. I have 10psi to 19psi tuned pretty nicely. Going to put in the bigger nozzle pre turbo and do 19-23 psi tomorrow. 19 is when the pre turbo nozzle kicks in.  I hooked the electric boost controller back up and debating what low boost to go with.
After he saw the pics he decided may as well add new door cards, so ordering those now.
