JDM Mini Canvas II
Started by Merlin, October 20, 2026, 06:41:55 PM
Merlin
I am creating this post as a start for the update to a new-to-me mini. I still have BondoRocket sitting and waiting for more time or motivation.
I picked this mini up a month or so ago on a whim. I really wanted to get a smaller car as I drive my truck all over the place at around 20Kmiles/year. Not entirely sure it was a great idea, but when have I ever had a logical one.
This is a 1992 1.0L Auto. I saw it on BAT and bought it because it appeared to be rust-free, working sunroof and an AC that blows cold. It turns out that none of those things were true.
Additionally, Data on these cars is hard to find. Google says that only 400 of these canvas cars were created and its likely that 200 of them exist. I spend more time researching. ChatGTP, TheMiniForums and somerford minis has been limiting in help.
Car showed up looking good but worn. A few things of note were that the sunroof would not close all the way. The engine was packed full of emissions stuff. Seat foam was worn in critical spots. Lots of japaneese aftermarket stuff wildly wired. The first drive involved the car overheating two miles from home.
After digging into the car, I found that all of the vacuum lines were toast, carb was worn, radiator shroud and fan were shot and the front right wheel was making contact with the fender. I noticed on the short drive that the car had "terrible torque steer" which is probably more a worn suspension issue.
The interesting thing to learn is that these cars were sent over to Japan from England and then modified. The car is full of imperial hardware, and then when you come across a Japanese market addon, its metric. Electrical is a mix between nissan and lucas. No exact wiring diagrams exists, and the components that were added are tied in with those insulated wire splices.
So what to do....
I really want a daily driver. I find myself driving often as a single rider. I need a car that is fun and quirky, yet I need to trust it.
The list of goals for this are below.
Fix the sunroof, or replace with something else
Refresh the seats and seat cushions
Suspension refreshed and corrected
Emissions removed (within reason)
AC system rethink and revamp
Engine clean and reinstall
Apple Car Play
Remote locks
New wiring harness
Convert to LHD
I am sure that more will come.
Engineering the Impossible
I'll come by and check it out when I'm back in town.
Convert to LHD will need a completely different dash, as the JDM one is unique to those cars. not that you can't buy one from any of the sources.
I'll get you a link to a wiring diagram.....https://www.theminiforum.co.uk/forums/topic/324929-wire-diagrams-redrawn/
Depending on whether you want to keep the air conditioning or not will also affect the LHD conversion effort since most JDM Minis have the evaporator on the left side and the vent arrangements vary considerably.  The evaporator will have to be relocated to the right side and the venting reconfigured as well.
Probably easier to leave it RHD?
There's an Austin America on BaT right now for really cheap with a 1275 Automatic in it, might be cheaper to swap than rebuild the 998 in there now - bonus - mor powahhhh!!!!
https://bringatrailer.com/listing/1969-austin-1300-2/
Merlin
Ahh the AC is the hot topic. Pun intended. The plan is (no so) simple. We are going to build a completely custom setup.
The issues to address are as follows.
The system was an r12 setup and needs to be updated to R134a
Condenser takes up too much room in the engine bay
Evaporator and fan assembly make the passenger footwell impossible to be utilized
Parts are difficult or impossible to source.
The first issue to resolve is the R12 to R134A
This will require the changing of all the orings and the expander valve. I have also found that because of the higher phase-change temperatures, the R12 condensers are not effective. Compressor requires no change.
We are lucky in that the mini went through this change and offers an R134A condenser. This is thinner than its counterpart. in the later mpi setups, this was mounted to the right inner wing. The controller for the electrical fans comes with two outputs (more on that later) so we can run a dedicated fan for the condenser. The mounts for the newer condenser are NLA, so I created my own to include the fan. This creates two new issues. The first is that the windshield wiper bottle has to move and that the hinge rod catch will need to be moved. Future Merlin issues
The evaporator was a debate for a few days. I was doing some forum research and someone posted one of these AC units from Siroco and it appears to fit in the same spot as the heater. The thought of the heater and the AC being separate kept gnawing at me so I pulled the trigger and bought one. After it arrived, further thinking and drinking happened.
https://www.t7design.co.uk/air-con/air-conditioning-units.html
I noticed that the matrix of the unit could fit inside of the heater. What if the AC unit could be a direct swap? A little Solidworks and printing and the first proptype box came out for fitment.
After some tweaking and serious digging, we are currently here.
My next plan is to create another door in the top of the box that would feed upwards into the dash. I had orignially planned on keeping the car RHD and I was going to reuse the ac vents that slide up the dash and to the center, but after having a think about the car and what I intended to do  with it, converting to LHD makes more sense but creates two issues that I need to resolve... the first is that i cannot reuse the ac vent tube and the second is that there is not a LHD version of the JDM dash.
The current plan is this: The fresh air vents that are already in the car are useless to me with AC. I plan to use these vents as the AC vents by either one of two ideas.
1: Cut a hole where the wheel well meets the dash and the firewall and run scat tubing through a printed flange. Create and elbow and re-intercept the fresh air vent from inside the wheel well.
2: Create a printed vent that runs along the firewall and the wheel well and have it replace the existing flanges to allow the vents to connect with little modification.
A third option is to recreate the center section of the dash and make a mirrored version. This is also a reasonable possibility except that I would also need to carry this over to the glovebox. Since both are separate from the three gauge dash, this wouldn't be too terrible.
Controls for the AC are to be driven from the Vintage Air servos. I picked up their water control valve and their Gen II servos. These will be included into the AC box. I have done some testing and it appears that these are dumb motors with a 3.5k pot attached as feedback. A simple H-bridge can be used to drive these. An arduino with some potentiometers as input could be used to do blending and door control. The H-bridge chips are on their way to do some further testing in a few months.
Wow, seriously impressive engineering and fab work.....thanks for posting this whole journey.
Did you figure out why it was overheating?
Merlin
I suspect the overheating was a combination of lean condition from vacuum leaks and a lack of sealing on the radiator. I have a four core, new thermostat and new hoses when the time comes
Just to be sure, maybe do a compression test too?
Aside from a cracked head, odds are it's from a combination of coolant that's muddy and a stock radiator that doesn't do well around here.  Though in 2 miles it could have been the head in my experience. I could usually drive at speed for a little bit before it went ballistic on coolant temps with a stock radiator in peak summer heat. Even with my thick aluminum radiator I need the inner wing aux fan on for low speed stop n go or the temp starts creeping up. I know you got a new head so that eliminates the head being the problem.
I was thinking head gasket blown....for it to overheat in 2 miles seems like it needs to be more drastic than just lean mixture and/or vacuum leaks. I was thinking either clogged radiator or head gasket.
My last blown head gasket didn't overheat.  Showed up on a leak down test. But my last cracked head was very evident.
Merlin
#12
I cant confirm if it is a head issue or if it is something else. I know that the car was running very lean as it needed choke to stay running. I feel that this is an issue that may reveal itself in the cleanup.
In the meantime, I am looking at the AC vent issue. Part of me wants to have a clean dash with the gauge pod and the air vents and the rest open. I cant say for sure that it is entirely possible, but I guess I can dream. I also noticed that the latter export cars had an AC dash and I could potentially reuse this with a custom adaptor to the center vents. I am not entirely sold on the idea. Before I track one of those down, I thought I would try my hand at making a custom AC vent that would use an Eyeball vent. The goal is to have it mount where the current one sits, but redirect itself to the back of the shelf so that I could connect a scat tube to it. This would fit down where the lower dash meets the firewall and allow for a clean open look.
Here is a little CAD mockup of the design.
Here is me using "CAD" aka cardboard aided design to make sure the design matches the existing. I ended up cutting out the paper print and fitting the profile to the car. The new eyeball vent is now in the printer.
I made one small alteration. The new vent tube size is 2.25" instead of 2.5" Not sure if it will help. I have not powered up the fan yet to see the output and then check the area of volute output to make sure i=I "like" the velocity.  The opening of the AC fan volute is app 8in^2 and two 2.25" tubes would be about the same.
Im not entirely sold on it. I need to make the other one and see if it clears the gauges.
Oh I almost forgot! My new canvas roof arrived today. White top with black headliner. Not exactly as it came from the factory, I just wanted the canvas to blend in with the white paint and a black headliner to tie the rest of the car together.
I hope you are successful with those vents, cause I'm building my A/C up from scratch and I'm sure I'll need some parts too! Watching all of this with fascination!
Merlin
Minor update. Just moved the mini to the shop. Future updates will include putting it on the lift and separating the engine and trans from the car.
Floor looks great! What's the Moke-ish looking thing under the chassis on the lift?
Merlin
My industrial golfcart. I strapped a jeep seat to the back to take the kids out for trick-or-treating.
Merlin
Not much work done as have been distracted by other things. I ended up buying a new dash for the mini. A charcoal LHD dash with the three gauge pods. I have a wideband for one.... not sure what the other two will fill. I debated back and forth on how to handle the A/C vents and came to the conclusion that I would need to cut some holes in the wheel wells to pass the ductwork into the air vents. The custom ones I made had a small flaw in that I would not be able to use the little cone covers without me making my own. I also wanted to retain the radio mount so going to a standard dash was the compromise. The other struggle was that the dash gauge bracket was very much in the way and getting around it was going to be tricky. This is why we ended up going with the standard wood dash as I now can hide all of my sins in there.
I ended up creating an adaptor for the fresh air ducts. These are bent at a 35deg angle which means that rotating them around wont guarantee clearance, but with the scat tubing, I can now bend as I see fit. Still sticking with the 2-1/4"
I also got the mini on the lift so we can see all the sins. Lighting is next on the list for the hangar, so apoliges for the poor shots.
The first is the clearance made on the front right tire. I measured the car here and there and really cannot determine why this is such and issue. Its clear that the wheel is forward in the car more than the left side. Ill probably pull the front subframe out and swap over parts from the other project and see what is incorrect.
The next two are the only spots of rust I have found. the first looks superficial with the second being an actual hole. easy fix  :lipsrsealed:
The auto transmission is dripping oil. I can see that an attempt to fix it has been done.
My favourite is the exhaust. It appears to be an inch in dia and had to neck up twice to connect to the RC40 on the back of the car. A new mangnaflow cat, 1-3/4" pipe and LCB are waiting to be installed.
This one has me thinking a bit. This is the fuel pump on the car. It sounds like a wobble pump. Not sure if I should keep it or replace it.
And lastly, my favourite! A little hardened grime on the brake cable with spray paint.
#18
Love how the brake cable was hidden.... :grin:
I'm trying to figure out what dash to use on my hot rod, I'm going to have A/C also, and I have a 9" GPS I might want to incorporate too as it has front and rear cameras as part of the assembly (mounted separately of course)
I'm also wanting to retain the fresh air ability, I can't imagine using recirc only, especially when it's chilly out and I'm using heat/defrost.
I like the later model silver/metal dash, but I'm not sure what I'll be using for instruments. There are lots of cool choices in gauges - I even found one cluster that's similar to an earlier 911. Or I might just go with one of the all-in-one digital dashes, like a race car uses.
https://www.intellitronix.com/product-page/6-gauge-analog-universal-color-changing-needle-white-lightning-edition
https://speedhut.com/legends-icon-6-in-1-cluster-metric
