Finished 3600 miles of testing out the tow bar. Worked great!  Things to improve upon it.  Needed my hitch stabilizer clamp for the back of the truck. I think some of the swaying would have been reduced with that. Not a single damn one to be found driving back for 3 days. I have 2 at the shop.  Grooved pavement made it sway as it turns out, where it tried to track the grooves. My front upper right torsion arm that I have a replacement for in fact needs replacement. I knew something was wrong with it, bent or something, which has too much camber for the suspension specs.  As a result that tire wore badly on the inside.
#1026
Torsion bar on the Bus or the truck?
Glad to hear it went well - for once! Where did you leave the truck while you were at BM?
12mpg towing sounds about right, the best my Tundra of that year ever did was 17. Curiously, the next one I got which was considerably bigger, heavier and had a bigger V-8 with way more HP, got the same mileage - 17 - whether I was just cruising or towing a trailer.
I needed this on the truck hitch connection sideways to keep the hitch receiver left and right movement to 0. Any slop in the system multiplies swaying once it starts. What is maybe 1/8" of play at the hitch becomes a lot extended 16 feet out.
Left the truck at the hotel in Fallon for a week after talking with them.
I have one of those hitch stabilizers on my Subaru.  Even in the upright position, it totally locks the hitch in place.
The hitch receiver is moving? On the truck? Or the draw bar is moving in the receiver?
Mine has that bit of play between the receiver and draw bar, but I've never had any swaying to deal with.....I imagine that would be a bit disconcerting, especially towing something as heavy as a fully loaded Bus.
Bruce's tow bar that he used with his Mini and his MINI did this when towing his classic, over a certain speed it would start walking back and forth, slowing down just a bit would cure it. I think his issue was with his tow bar itself tho.
The bar with Ball that slides into the receiver. That thing. It never sways more than a certain amount when it does it, but eliminating it or at least reducing it would be nice. Strong crosswind or going up a hill it's more stable. I am guessing because that bar is forced into a fixed position and not allowed to shift left and right.  I wouldn't be surprised if fixing the torsion arm helps with tracking too. For the majority of the drive it wasn't swaying, but it's annoying when it starts acting up. Grooved pavement made sure of it. I noticed an camper trailer doing the same thing on a section of grooved road.
The stabilizer eliminates all the play between hitch and draw bar (forward/backward, right/left, and up/down).  As Dan says: any small play at the itch end get magnified at the back of the trailer.
On my Subaru, going over irregular pavement and bumps or changes in speed would make the draw bar rattle in the hitch due to jolts from the trailer.  The stabilizer eliminated that as well.
I need to install one on the rear cargo hauler with bikes too. It would help angle is more level instead of slightly drooped.    Overall happy with the setup. I can carry the same amount on the cargo haulers as I do on my little trailer.  I could add bigger bins to the front if I get motivated and install headlights on the cargo hauler. They get blocked otherwise with wide bins.
Red Riley
I use one of those on the 1.5 inch receiver hitch on my Elf. It used to rattle around like crazy. Now it's rock solid. I wish I could find one made specifically for the smaller size, instead of the onesizefitsall one. It's way too big, but it works.
#1035
Spent all day yesterday cleaning the bus and camp gear.  It was beyond dirty.  Also screwed around with the rear cargo hauler and bike rack.  The sagging was actually just from the assembly shifting where it bolts together.  I shifted it up and welded it together. No more shifting and sagging.  I also tried the stabilizer clamp on the bike rack portion and the cargo portion. Basically anywhere there is the ability for things to be sloppy.  All nice and snug for the next trip. I wish I had thought of all this before this trip but live and learn.
Get to fix something when I get back to the shop after this work trip.  Had my air hose out in the yard blowing dust off stuff after burning man. Took the Inno for a ride to the gas station and inadvertently got the air hose hooked on something. Instead of the hose breaking or any of the smaller connection points like water separators, it broke the pipe that goes from the compressor through the wall.    Tempted to just weld it fixed.
ve9aa
Self explanatory (I think?)
Mike in NB
Saturday was tune up day for the FJ Cruiser. Plugs, clean the K&N in the TRD CAI, I cleaned the airflow sensor as well and topped all the fluids.  After the M5 Debacle changing the spark plugs, it is nice to work on a simple car again.
I was telling my BIL about the M5 spark plug job, he told me his Lexus with a V6 needs to have the intake manifold removed in order to get to the rear plugs, he let the Stealership do it, $1600. I thought the German cars were bad.
I noticed my TRD CAI is shot, the air filter is dry rotting, the box has cracks in it. I decided to order a new one Sunday, I will install it in a couple of weeks. Between that and the race tires for the Mini, I spent a little money Sunday.
I better get back to work!!
Almost all the transverse V-6 engined cars require removing the intake to get to the back plugs - I'll bet a LOT of them never get changed - just charged for.
I remember the first time I changed plugs on a Sunbeam Tiger - to get to the rear two plugs on the left side, you had to remove a panel in the floorboard, under the pedals. It was a nightmare!
Finished up the 998 gearbox for Jeff Shaw, he'll pick it up towards the end of this month. He hopes to get some serious work done on reinstalling it over the Thanksgiving break when he'll have a week or so off, before he has to head back to his job in Connecticut.
Last things I needed to do were install the new 1st motion shaft bearing race and the crank seal in the drop gears housing. I went ahead and bolted on the housing so I could measure the clearance on the intermediate gear.
ADRay
the Subaru's (daily driver) check engine light came on over the weekend. Brought it to the parts house and a scan revealed a misfire in cylinder 2. Starting with replacing the plugs, I figured out what was wrong pretty quickly.
1982 Mini 1000 HL
@andyray998
Whoa!!  Hopefully the missing parts left the building.
Did you scope the cylinder to see if there was any damage?
So it doesn't shoot spark out of that big hole?  Super gapless extended heat range plug.
Ouch, yeah I'd be worried about where the end of the plug went too! Looks like something banged up the end of the plug?
ADRay
I think the metal that's gone just completely corroded and wore away, and the ceramic part probably was pulverized and sent out with the exhaust. The other 3 plugs were not as bad but definitely headed in the same direction. new plugs installed, running good and quietly. Didn't scope as I don't own one, but it would have been a good idea.
1982 Mini 1000 HL
@andyray998
#1046
Mrs5543's car needs tires bad. I have a set of Rims/tires I purchased to use the R53 for AX before I ended up with the Blue Mini that is now my dedicated AX car.
I decided to throw the AX tires on so I can just drop her rims off for tires. I really think these R53's look and handle better with 16" rims.
Edit - did some quick shopping this morning, was looking to put Pilot Sports on it, stumbled across this sale, reviews majority positive, at $95 a tire I'll give it a try.
https://www.tirerack.com/tires/tires.jsp?tireMake=Firestone&tireModel=Firehawk+Indy+500&partnum=045WR7FHI5XL&vehicleSearch=false&fromCompare1=yes
I also had Tire Rack ship to an Authorized installer, which is a Firestone a couple of miles from my office, the reason I did that is because the price is set by Tire Rack, $123 for 4 Mounted and balanced. I just paid $75 at my little local tire shop to have 2 racing tires mounted for the classic.
MiniGene
That MINI looks mean! (I say that in a good way)
My buddy Don is running those on 16's on his 2006 JCW and really likes them. Since this isn't a competition car you're after decent wear, a quiet ride and good wet performance as well as dry. He loves his - got them at Costco tho.
They're strictly summer tires for him too, he runs Blizzaks in winter.
All day cleaning camp gear from burning man.  Fixed the bikes that were having issues from playa dust and gave the generator a deep clean.
