Racing Green 89 Mini
As a side note, these are the adapters I almost always end up using. You can usually get one of them to fit what you need. They also work with other pressure testors like Matco, snap on etc....maybe the parts store has this style of adapter you can borrow too? If not maybe their pressure tester would fit these adapters so all you had to buy was the adapters. I think my pressure tester is an old Napa brand but I use it with these harbor freight universal adapters.
https://www.harborfreight.com/universal-radiator-adapter-set-56204.html
#751
I went this morning and bought the HF pressure tester setup, if it works I'll keep it, if not I can return it....it looks pretty complete, so we'll see. If this radiator has a leak I'll get a new one on the way, we have a Brit car show this Sat so I'd like to drive it and see if my motor mounts made any difference in the vibes. If not, I'll clean it up and put it back in and test the whole system and see what I can learn.
If the leak test indicates no actual leak in the radiator, could the cap spring be a bit weak and letting operating pressure push a bit out the overflow tube to stain the area at the end of the tube?
#753
Well, good news and bad - the coolant system pressure tester I bought this morning from HF fit this rad perfectly and the test proved exactly what I thought it would - a very fine stream of water jetting out of that stained area on the radiator. So, good news - I don't have a bad head gasket (really didn't think I did anyway) bad news, I need to order another radiator.
I buy these on Ebay pretty regularly for other Mini owners, and pretty much every engine I overhauled got one too. The first ones I found today were a bit more than I've been paying plus they wanted 12-15 shipping, but digging a little deeper I found one for $69 shipped - it's on the way. I don't know if it will get here in time for sat's Brit car show, but here's hoping.
Aluminium Radiator
Edit: Looking a little further down the page there's one for $59 and free shipping too!
This one has been in my car for 10 years already, so it owes me nothing, but I am a little curious how/why it's leaking there, pretty impossible for a rock to hit it there, and there's no rub marks so it hasn't been hitting the body. I guess it's just a failed tube.
One thought, it seems that when enough of the water comes out of the top tank, it no longer can refill that tube, so it stops leaking there till I top it off again, and the hole seems small enough that it doesn't start leaking again till the pressure builds back up, starting the cycle again. I'm figuring that's why even tho the top tank looked empty, the car never ran hot, and it only took 4 -6 oz of water to top it off again, the rest of the system was full. I would think that as the engine ran some water would go down those tubes too, but it never seemed to be enough to cause it to run warm.
Glad it fit, a pressure tester sure makes quick work for finding coolant leaks, especially the small ones that never really leak enough to track down.
I think I might go ahead and get one of those radiators to have in hand, thanks for the link.
#755
For the money they're a heck of a value, and best of all they work. My car has never run hot with one, even on 90+ days running for miles down the hiway at 75/80 mph.
I haven't looked at it closely to figure out whether the hole is due to damage or just a failure of the metal. It's always had plenty of anti-freeze so I doubt it's due to corrosion. The only reason for the rusty look is that I've been replacing the anti-freeze with water for the last 2 years or so!  :rolleyes:   :grin:
Just got the updated shipping notice, it won't be here till Monday, it's coming UPS via truck from California......so I'll find something else to dive to the show this sat. In the meantime I can do some other maint it needs, the left rear wheel cylinder seems to be weeping very slightly, I have a pair of new ones so I'll put them in plus a new set of shoes in case these are impregnated with brake fluid.
#756
My radiator came in unexpectedly late Sat evening, so I managed to get it installed today....but first I closed off the ends and pressurized it, just to make sure. It held 13 psi for about an hour and I called it good!
Fired it up, no leaks, brought the car up to temp so the coolant would get mixed well, and shut it off.
I need to do some trouble shooting on the charging system, I had the alternator checked and it tested OK, but the gauge just barely shows 13 V, should be just over 14. I retested the battery and it's fully charged, so I wonder if I just have a duff gauge?
I'll do some more sleuthing tomorrow....
#757
I thought the rear brakes on the left were leaking brake fluid for a while now, but it never left a puddle - till today!
So, before the green one comes off the rack it's getting new wheel cylinders, shoes and such.
Man, keeping the fluids in one of these is a full time job! First the radiator, ongoing oil leaks and now this!
The joys of owning a "classic car", always seems to be something.
#759
Changed plugs on the Green car today, not because they were worn or missing or anything really.....just because. Interesting to see that the plugs on one end look a lot cleaner than those on the other end which almost look fouled. Interesting because this is a single carb motor on a joint intake manifold.....so why one end is rich and the other lean or almost perfect is odd. I also put on copper core plug wires, just because, the others were still fine.
Plugs on the right are the radiator end or 1&2....cylinder #4 especially is supposed to run hotter, but it doesn't look it does it? maybe I'll swap ends and see if they change?
Oh, and I pulled the drum off on the right rear, the shoes are completely soaked! I have new shoes and wheel cylinders, can't find my little tool to put the clip on tho.....
Dan Moffet
Quote from: MiniDave on May 13, 2026, 11:17:00 AMPlugs on the right are the radiator end or 1&2....cylinder #4 especially is supposed to run hotter, but it doesn't look it does it? maybe I'll swap ends and see if they change?
Yes, it seems backward to "logic". I wonder if it might be due to restricted exhaust, maybe valves want adjusting or something preventing that end of the engine to breathe equally. Or maybe a manifold gasket leak upsetting equilibrium and mixture setting is compensating.
Well, I did check for a vacuum leak and intake gasket not sealing well on that end of the motor, and all was good....valves are set OK
Seems like it's always been this way, but it seems like it used to be rich on the center two.....who knows? It runs well, I can say that!
I was concerned that I might have had a head gasket internal leak till I found the radiator leak was where the water was going.
