Mini ST Hotrod
#225
A friend asked if I seam weld where it's not punched for plug welds and my answer was - sort of. You spot weld it, one spot at a time, but you completely weld the seam. If you try to run a bead you'll simply blow thru this thin metal. If you do manage to blow a hole, you just do a spot past it and one before, then use those to fill in the hole from one side to the other. Even tho you have to pause for a moment in between each spot, and it seems like it would take for evar, but his line only took a few minutes to do. I pass a bright light behind it once I'm done and if I missed a spot or two it's easy to go back and fill them in. Once done I run a flap disc over the welds to take down any high spots, but I don't go so far as to blend them in since it will be under the sound deadening and carpet.
