Racing Green 89 Mini
Yeah that's strange with the rust look discoloration. Are they possibly burnt and have a rust appearance?
I never felt them get hot, and I checked them every time we stopped as we drove home from South Dakota, but they def looked weird. It was odd that the pitting wasn't all the way around the rollers either - it just seemed to be on one side.
At any rate, it's fixed now.....on to the next problem - whatever that turns out to be.
I'm going to drive it later today or tomorrow morning and see if I still hear anything, if I do I'll tear down the right side too.
I decided to go ahead and tear down the right side and check the bearings - the good news is they looked fine, and I noticed I used Timken bearings and not Chinesiums......I'll repack these and put them back in - I wasn't hearing any noise but thought if the left side looked that bad I should at least check.
I also found the end of the axle all beat up - no idea how the heck that happened as like on the left side, I know I'm the last one to work on it and I could not have gotten the nut on with the end of the axle damaged like this.
On top of that, another mystery - the cup in the upper control arm is broken on this side too......what in the heck causes that?
So, I guess I'll pull the bonnet back off as it makes it much easier to work on,  plus I have to remove the wiper motor to get to the big ass bolt, and I can't get the spring compressor in there with the bonnet on either.
#703
All better now, I did have to remove the bonnet, it just made it worlds easier to get the wiper motor out of the way so I could use the cone compressor.
I was lucky that the remains of the cup came out ok, sometimes those things are really stuck in the control arm. There was a small bit of plastic that had been beaten down thru the little hole in the control arm but I was able to get it out with a set of bent nose pliers. I also greased all the zerks before I put the wheels back on so the front end should be good to go for a long time. Looking at these pics I can see I need to put another turn on the hi low to get it where it was.
Everything went back together smoothly, so all I need to do now is give it a good bath. Our MINI club is meeting for ice cream Saturday evening so I want it looking good for that.
My poor little green Mini has been living in the garage for the last month or two due to the typical winter weather we've been getting and the tons of salt that's been poured on our roads - I had planned to drive it to Sat's breakfast meeting of the Age and Treachery Racing group but we've been getting "wintery mix" of rain, ice and light snow today, so I'll bet the roads are coated in salt again. Too bad as we had enough rain a few days ago to really wash things down nicely.....
I noticed the last time I drove it there was a noise in the left rear on braking, so I'll need to pull that drum and see what's up - it has new shoes and only a thousand or so miles on a new set of Minifin drums but it sure sounds like metal on metal.
We may be doing a local roads run in April so I want it all spiffed up for that, we have two new classics in town that we want to get involved, that's why we're planning this run, plus we just like to get our cars out and hit the roads too!
That annoying squealing noise on the inno went away with the 4 pots, as did the jerky brake booster engagement.  It's like it was meant for 4 pots!  Having a squeal sure is annoying though.
I've been hearing a grinding noise in the left rear brake, especially when braking hard so I decided to check it out. I have fairly new Minifins and Mintex shoes so I wasn't expecting it to be metal on metal - and it wasn't. All I found was a ton of black brake dust, it was completely dry - no grease or brake fluid.
So I just cleaned it all out with a short brush, shot some brake clean on everything and put the drum back on - there was still plenty of shoe left and no unusual wear patterns that I could see. I also adjusted the shoes a bit, I think I got an extra 2 "clicks". I still need to adjust the brake handle end too, it's too many clicks up of the handle before anything happens and I have to really pull it up hard for it to hold on the slope of my driveway.
I'll go ahead and do the other side too just to be sure......
I'm due for an oil change, but man is this thing leaking oil now. I'll need to get it up on the rack so I can see where the heck it's all coming from and to do that I'll need to get the hot rod down on its wheels and get some help moving it about. It's not that hard to roll, but I have a pretty good slope to my driveway so controlling it could be an issue - I wouldn't want to be on one of the You tube vids of a guy chasing his car as it rolls down the block!  :043:  :dance:
#708
Last year just before we went to Rushmore and MMEMW, I bought a nice new MiniSpares dipstick, with a T handle and a couple of O-rings where it fits into the blcok....a nice looking piece of kit.
Yesterday I went to change the oil and the T handle came right off in my hand! I don't know if it was made with a little epoxy to keep the handle on the rod or what, but I knew I could do a better repair than just stick some JB Weld in the hole - tho that probably would have worked I prefer a mechanical solution.
So I ran up to Westlake and bought an 8-32 allen set screw, drilled and tapped the T handle and it's on there solid now. I might go back and buy a shorter set screw as this one sticks out a bit.
Oh, and I machined a small flat where the screw hits the rod so it would have a good place to bite
#709
Took an early morning run with the local MG club - and I do mean early, it started at 7 am -  which meant we left my house for the meet up point at 6:30!
So as we were meandering around trying to find roads with curves in them, all of a sudden I had the strangest thing happen.....it felt like I was sitting on a balloon and the air was slowly going out of it and once all the air was out it felt like I was sitting on an open 5 gallon bucket with my butt down in the hole!
I'm pretty sure I know what it is - the webbing under the foam gave way, but it was just so strange that it did it so slowly - not with a pop!
So, I have a couple of options - I can fix the seat. Or I can re-install the WRX seats I had in here before - or just the driver's seat since that's the only one that's broken. Or, once Dan gets home again I can see about getting the other seat he has in his shop for me.
Whatever I do I need to get it done before I leave for the Ozarks on the 10th.
The white mini belongs to local guy Zac, he was a surprise show up because he's on call today! But it was nice to have another Mini show up for the meet.....Zac drives a train for a living. I helped him rebuild the engine and gearbox in his car and he did a super job, the car runs and drive's beautifully!
The green XKE is almost done after a 4 year restoration done by the owner - it's turned out beautifully, and the sun really showed off that green paint.
The blue MGA coupe belongs to the owner of the local Armacost Museum, which is mostly dedicated to all things Studebaker - as his father was a Stude dealer for decades. He's about 6'5" and I have no idea how he fits in the MGA coupe', but he does. He says there's plenty of head and leg room - once he's in the car!
https://automotivemuseumguide.com/armacost-museum/
The red Midget was the leader of the run, and I saw his wife waving her arms around and yelling at him anytime he went over about 30 mph - made for a long, slow trip this morning! I thought she was waving off a bug or something, but no.........The tall guy talking to the woman is Chris Armacost (MGA owner) and the woman is the wife of the tour leader.
We also cruised by the brand new, just opened 4 million sq. ft Panasonic battery plant in Desoto....jeez louize that thing is fricking  huge. It was supposed to open in July but with all the uncertainty in our political waters these days, they postponed it. It may open sometime before the end of the year, but it may also never open. Remains to be seen.......
Once Brant is out I can move the pickup to unbolt that seat. It's just stuck for now on a pallet without access to get the seat out.
#711
OK, found out what happened, and when you look at the pic it makes complete sense why it felt like a balloon slowly deflating......the rubber tore, and it started at one end and slowly worked to the front.....making it feel like my butt was falling into a bucket! The foam still feels ok, in order to replace the diaphragm I have to take the backrest off, then remove the cover and foam, which is glued to the frame. I'll probably just take it up to my seat guy and let him do it......
https://www.minispares.com/hgd100150-seat-base-diaphragm-1993-2000
I decided to put the WRX seat back in, but it's too hot and I'm too tired to do the other one tonight, I have a MINI club Sonic night meetup in a couple of hours, but I may put the right seat in that matches the back seat before I head down to Ozarks - or I could put the other WRX in, who knows?  :grin:
Drove almost 100 miles to and from the MINI club event last night, which is getting harder to do on these evening events as it gets dark a lot earlier now and I really don't like to drive at night, even in familiar territory. This one started at 6 and I got there early and left by 7 so only the last 20 miles were in the dark.
I have the new seat diaphragm on the way and I took the seat apart and delivered the bottom half to my upholstery guy who says once the new part gets here he should be able to turn it around in a day. So, if it gets done in time I can swap it back out or just leave the WRX seat in place.
The Mini has been on two consecutive 100 mile drives with no issues, so I'm fairly confident taking it to the Ozarks next weekend. Even so I will leave the tow bar attachment on the front just in case.....
My upholstery guy was too busy to fix my seat, so I picked it up and decided to give it a go. The part came in yesterday so first things first I took the cover off. Mini Spares or Newton - can't remember which - said the foam would be glued to the frame, but it wasn't so once I got the cover off it was easy enough to get the old one out. BUT, the new one was really stiff! I thought I might have to invent a tool to stretch it across to where I could drop the hooks into their holes, but I wound up clamping into my bench vise so I could really pull on it and stretch it into place. It took a while but I finally got all the clips hooked into their respective holes. I used the hook tool in the pics.
The rest was just re-assembly and remembering where everything went. If anyone ever has to do this, one tip - the seatback angle adjusting knob just pops off. I took this one all apart, and once apart realized I didn't need to do that. I think it turned out pretty well!
#715
I've done two runs with the racing green Mini since I fixed the seat, a 2 1/2 hour drive each way to Ozarks International for the vintage races, and today we did an MG club run about an hour south to a club member's shop.
I'm still having to add a little bit of water (about 4-6 oz) from time to time tho it's not leaking anything on the floor. Today I bought gas someplace other than my regular place and on the way home the car started running rough, bucking and missing occasionally, so I guess another bottle of HEET is due. Anytime I've had this happen it's been due to bad gas, some HEET in the tank and it clears up and stays that way.
I've had the car 9 years now and it's always been reliable, I've never not been able to get home. Next up it's due for tires (they're not worn out but they are 8 years old) and I'm dreading to see what it will cost in shipping and tariffs......I was charged $67 in customs duty, fees and tariffs on a $155 master cylinder I ordered for Clancy's Moke. DHL is looking into it they claim and will send me an email with their findings. There was a $17 admin fee, a 1.50 something fee, and $48 tariff charged on this shipment.
scalpel_ninja
Recently got a quote from Mini Spares for four:
TYRE NANKANG ECO 2+ 165/70/10
It came out to be $489 with shipping, not including tariffs.
Should have been $15 in tarrifs  :banghead:
#718
Quote from: scalpel_ninja on November 01, 2025, 01:35:36 PMRecently got a quote from Mini Spares for four:
That's the problem, we think it's just a standard across the board number, turns out it isn't - for example air craft parts are tariff free, but there are different prices for steel and aluminum, so if your parts are made from that it might be a different rate. Used parts are at a different rate than new, and I have no idea what number rubber parts get. It's really confusing, especially for those charged with coding the parts so the duty can be assessed according to today's regs. On top of that if the coo is China, who knows what they'll charge?
We'll see next week what DHL says about my part, they claim they'll have an explanation and will send it to me in an email.
What was the code on billing?
So far I have nothing from DHL, no codes no real info other than the breakdown of the charges that I detailed above. I did get an email from them Friday saying they're still working on it.....
#721
So the green Mini has been running terribly lately, it started on our trip home from Ozarks International Racetrack,  just every so often it would cut out, briefly but harsh - like the key had been switched off and right back on.
I made it home OK and had driven it several more times with no issues, then the other morning on the way to breakfast it refused to start - like the ignition was off. Cranked fine but just wouldn't hit. I fiddled with the wires on the coil and tried it again...bingo! Popped right off.
But.......it would cut out intermittently, so I took it back home and drove my Audi to brekky.
A few days later it was warm out so I bought some HEET (just in case I got some shit gas in Laurie, Mo) and treated the fuel, it fired up normally but every so often it would cut out, especially under hard load. If I took it easy it mostly ran OK but clearly it's getting worse. At one point it died and acted like it would not restart, but then it caught and I was able to make it home again.
So, I don't think it's bad gas as I don't see anything floating in the tank and any time it doesn't start there is fuel in the filter, so I'm leaning towards a bad coil. This one's been on there more than 8-9 years, so I'm guessing it could be failing.
At any rate, it'll be an easy diagnosis - either it fixes it or it doesn't.
Cheapest Lucas Sport coil for 3 ohm non-ballasted ignition I could find was at British Parts Northwest, $36 plus shipping or about $50 at my door. Moss wanted over $150 for the same part, and Nate Kulpa at Wild Child was out of stock, tho he wanted over $90 for his.
So remember BPNW, I've used them before and so has Don for Spridget and GT6 parts with good success.
Engel didn't have a listing for it, and I didn't call them since I found it at BPNW and their shipping was reasonable.
Even flamethrower 40k volt coils are only 52 bucks shipped off Amazon!
Do I need 40K or 60K like you run if I'm not running a really high performance cam and such? Mine is basically a stock engine, overbored 40 thou with 10.3 compression and using the Evo cam and a stock head with bigger valves. The stock coil seems to have done well since I've owned it.
Edit: completely forgot to check Amazon.....
#724
I'd run the 40k. The extra voltage is ideal with your higher compression and sport cam. You can gap your plugs more too. I could feel seat of the pants difference between some old shitty coil and a 40k volt on the bus when I swapped them out after getting into town on the old coil. In fact also coil output related, but on my rx7 the ignition amp that bumps up voltage makes 10 more HP to the wheels and feels smoother and more crisp with it installed.
Edit: I'll add too that with resistor plugs and maybe a resistance rotor arm, and some resistance wires the extra voltage comes in handy to overcome all that.  I gap 0.035 on a 40k volt coil and 0.040 on a 60k volt.
