My various projects thread.
jdbuild1 and 3 Guests are viewing this topic.
Ok so finally got this rear end grafted into place. You can see the difference in window sizes on the overlay and where the cuts need to be made to match it up.
I'll bet it's nice to work with clean sheet metal like this! This project is really coming along now.....won't be too much longer before its in primer?
#427
Primer is near.  I have a ton of welds to finish.  I have a few spots that need filler, but nothing crazy.  I'm waiting on  my bus heads to get back so I can button up the engine and get it out of the way too.  It's halfway into the paint booth and I either need to cover it with plastic or get it assembled so I can do my paint prep.
Also my HF air grinder tool to knock down spot welds died on me.  Need to go grab another one of those.
Is that one of the finger sanders? Cause they make an electric one too....
No it's a die grinder with attachment.  20k rpms.  Zings welds flush quick and way easier and less traumatic than the angle grinder.
This guy...
Takes the high spots off quick.
What did you use?
How do you weld the vertical seams, did you put some holes in the other part so you can plug weld it?
What do you mean what did I use?
I have to drill out the holes for the plug welds along the seam still.
What did you use to knock down the high spots?
The 40 grit attachment shown in that one photo above.
I never did update this car.  Before coming back to work got a ton done to it. A lot of block sanding, worked out warpage and dents as best I could, added filler where needed, filler primed, more sanding, glaze spot putty where needed, more primer and sanding, and almost had it ready for paint before leaving for work. Brant dropped off a ton of things for me to assembly or put on the car before he takes it home.
What do you do with all the sanding dust? Hepa filter vacuum? Sweep it out the back door?  :grin:
Fans blow it out the back as I use the air gun from the compressor. Short burst keeps the dust from billowing outwardly and more in the flow of air.
Summer time vacations wrapped up and I was able to get some color on this car recently. Exterior is close. Por-15 going on the interior areas not painted.
Got this painted last night.
Someone is going to be VERY happy to see those pics!
Slowly getting this together.
Wow! That's real progress! Once it's on its wheels it starts to look like a car again...   :great:
Nice being able to roll it around. I need to get the doors and stuff ready to spray. I only have so much room in the paint booth. And the bus is hogging up a ton of space while I wait for the trans to come back.
Haven't posted in awhile.  I have a few more odds and ends done on the early mini.  Got some bare metal interior coated the other day for example. Ran a harness, got glass in, got a tank in...
When is it going home?
At what point are you going to say "enough" and ship it?
The shiny black floors are interesting....
Rust prevention floors and same por 15 undercoat. I might get it fired up for him. That's where I'm ending.
It's been sitting a long time, you might need to prime the oil pump to get it to build oil pressure.
This one is about out the door...
