1974 Mini Marcos - tidying up
Started by MPlayle, May 25, 2019, 02:13:33 PM
I got out to the garage and did the alignment today.
I measured the existing settings prior to making any changes.  This is what a local service shop left it at from the second try at an alignment on a Hunter machine.
                   Left        Right
Caster         +7.25*     +9.5*    (degrees)
Camber       -0.75*      -2.0*     (degrees)
Toe (in/out)   0.0"       1-1/8" toe-in (inches)
I used a string "box" to get some "center line" references for each side, my bubble style caster/camber gauge, some home-made slide plates (two vinyl tiles, smooth sides together with grease between them) and a set of 24" toe plates.  I was able to get the desired settings Dave recommends: +3.0* caster, -0.5* camber (both sides) and 1/8" total toe-out.
I will take it out on the highway tomorrow to see how it feels.
It should be immensely better, and easier to steer! That much caster is nuts!
They had something registered wrong on their machine as I recall it was trying to tell them to shorten the control rods to go to a smaller angle.  When I read up on alignments, that was the wrong direction to be going.  Following the instructions for my bubble gauge, lengthening the control rod would push the wheel back and make a smaller caster angle.
The lesson I learned is their "techs" may be good at following the directions of the machine, but they do not know the geometry and function of the settings.  If the machine is not registering correctly, they still blindly follow its directions even though backwards.  They do not know the geometry and so cannot tell when the machine is not operating correctly.
I ran into this a lot when I taught steering and suspension at college, my solution was always to tell the kid to pull the car off the rack and roll it back on and start over. Sometimes the machines lose their way too - and you have to reset it to get it accurate.
A tool is only as good as the guy using it......
Oh, and yes, you lengthen those rods to reduce the caster angle.
Had the Mini Marcos out for a "test drive".  It handles much better - more stable in curves at speed on the highway.  It is still a light handling little car, but no longer feels like it is suddenly trying to plunge into hard turn halfway through a bend in the highway.
I'm gradually getting confidence in it for general running around.  Now if only the 95*+ temperatures would finally break.
You guys not getting any of this cold front coming in overnight?  Tomorrow high is 60 and think Sat. low is 40's
We're supposed to get some of the front tomorrow (Friday) morning.  Good for a couple days cool down into the 70's daytime and upper 50's overnight.  Back into the upper 80's to mid 90's by Monday/Tuesday.
54 years since the Mini Marcos "debuted" at the 24hrs of LeMans
http://maximummini.blogspot.com/2020/06/today-54-years-ago-mini-marcos-at-le.html
Mine is still for sale.
Some recent videos of the Mini Marcos.
Cold start:
Walk around:
Short drive:
Medium drive:
All the videos look good. Every time I see it I think how much fun it would be to drive.
#85
Michael, I like what you shot, but the video quality seems low.  Did you upload them in a low quality format?  Is the original video higher resolution (sharper images and better colors saturation?)
I'm not trying to be a jerk, I just think a top presentation will help bring top dollar.
You need to put some tape over the mic too, the wind noise ruins the sound on the video......or if you can get a remote mic to work on this camera and can put a wind sock over it.
The driving and walk around videos were recorded in 1080p at 60fps.  The cold start was at 1080p and 30fps.  The cold start and walk around videos were uploaded as the original MP4 format.  The drive videos were edited using QuickTime on my Mac to clip them out from a single 20 minute drive video and so uploaded in the QuickTime 'mov' format.
I did have the windows open for air circulation since they were taken on a morning that already had temps well over 90* by noon (some of the recent 100*+ days).  There is less air noise than many of the comparable drive videos on BaT.
The camera is supposed to support an external microphone, but did not come with one and I do not have any form of one to try.
Then just put a piece of duct tape over the mic opening, it will cut down the wind noise considerably.
