Wow, it's been 2 1/2 years since that motor hit my shop! Glad to see it finally in a car. 77.gif
It's been 10+ years since it's been in a car!
Front end sitting a bit high with these red dot cones. Threw in 240lbs of sand in hopes it settles.  Otherwise I'll have to take the locking washer off the hi-los, which I'd like to avoid.
Quote from: BruceK on June 27, 2018, 11:21:54 AM
That rear disc brake setup looks sweet!
One thing I instantly like about it, aside from cool factor and the fact the rear subframe is dramatically lighter...no drag associated with drum brakes now.
I think you need to change the thread title, this is hardly a mild refurb!  ;D
Quote from: MiniDave on June 28, 2018, 07:34:46 AM
Ha, I know. I think Playle said the same thing several pages back.  It's been a 3 year documentation on the evolution of a daily driver to a full on build.
Wrapped up paint today, minus flares.  In fact one quart of this new lessanol paint I've been spraying mixed 2:1 was nats ass the amount that was required for this job.  I'll have to mix an 1/8th for the flares, though considering black.  Mininal color sanding required which is always nice.  Did miss a minor ding on the one door, but it's in a spot I'm betting my dolly set can push back straight.  I fixed a couple dents on the body pre-spray that came out flawless.  Also finished up hard lines for haudralics, got the headers and carb in.
Doors are on and everything matches up, except the bottom of the right rear quarter panel I went light on the paint.  So will have to hit that area again.  Didn't notice till everything was on and the garage door was open.
Ha, yeah it's wierd cause it's as if I painted the whole car but completely missed a 6x12 inch section.  Standing above or to either side you'd never know.  Stand back 10 feet and it's like what happened.  I may respray the one door now to sand out a couple minor ripples left over from pushing out a ding.  Need touchup paint anyways since I'm flat out.
You're so close on this one, you should just go ahead and finish it, one car out of the way in the shop? Plus then you get to start driving it and breaking it in so you can make the dyno day.
Getting there.  Been pretty busy with 66 and 65.  Wanted to get out there today but I'm under the weather.
Tried a new adhesive.  My 3m 88 ran out so I took it up a notch with industrial strength.  This is where it's at, even has an adjustable nozzle and with the spray pattern easier to hit the lip.   Headliner came out flawless.
Made a lot of progress the past couple days.  After a bit of fiddling, misinformation online, and a phone call to Dave, I have power to the starter.  Having an old style harness and then installing  the pre engaged starter with new engine made that a small annoyance.  I have spark and everything inside pretty much wired up.  Need to finish off lights to verify it all actually works, then induce some fuel and see how it sounds!
Take a vid of it, at least of the first run up the block!
We have noise!  Blew a coil so don't think that I run two at a time.
Ha, so true.
Also...  come to find out it needed cut for the new headers but still.
Color looks good.  What's your best guess on how much it is going to weigh?
I think he said he's taken about 400lbs out?
