joakwin
i finished the metal panel work on this one side
the flare is solid, i made mounts on the underside of the flare to connect to the body
and i welded the sheet metal to the body, and i started to lay fiberglass over that
and starting to get into body work to smooth it out
i hope this weekend to start the other flare
joakwin
front flares by joa kwin, on Flickr
did a little work on the right front flare tonight
i cut the line to space the flare out some
2 layers of mat on it, tomorrow i will do the other side
joakwin
Are you planning to meet the lower edge of the arch to the front spoiler?
joakwin
Quote from: MiniDave on March 26, 2018, 08:45:45 PM
yeah, im going to make something, just not sure what yet
joakwin
i think im going to make the lower front valance a flat style panel
im almost done with body work on the two rear flares
joakwin
extra auto trans by joa kwin, on Flickr
picked up a extra obd1 Honda automatic trans, pedal box, and p28 auto ecm for $30
joakwin
Obd1  Honda parts are getting hard to find in the junkyards here and
People s hit can Honda automatic trans parts because they have no value
Because they did a manual swap
And my current auto gearbox has 200k miles on it
So sooner or later it's going to give up the ghost
Facebook market place has another auto box, the guy wants $50 for it
joakwin
right rear flare by joa kwin, on Flickr
did a small amount of work on the flare today
i still need to fix the outer edge and the bottom of the flare
the bottom flows like dirt going into the rear valance
joakwin
front valance by joa kwin, on Flickr
I started to work on the front valance, lots more to go
joakwin
Is there a reason you went with the taller aspect ratio? I run 175/50-13's on my car. Are those Yokomama A539's?
Bahowe1
Joakwin, I had the same size tires on mine for a while... but in turns, it would just barely foul on the radiator so I had to step down to 50's.  Yours is a different setup, but sometimes, just a smite matters.
joakwin
Quote from: MiniDave on April 25, 2018, 03:29:08 PM
the tires are 20.7 inches tall, about a inch or so taller then the 50 tires
honda del sol si came with a 185/60/14 and those are 22.7, so 2 inch shorter tire makes the engine spin a hair more into the power band, and the automatic gear ratios are awesome for the smaller size tires we use on our minis  vs the honda manual trans and the cost of tires vs the yokomana is night and day
these tires have alittle more side wall over the 50's, so they should give a nicer ride
https://www.amazon.com/NEW-ACHILLES-P165-60R13-TIRE/dp/B00VV0H4MU
i paid $38 a tire shipped with fedex, so for the price, im willing to give them a try
joakwin
Quote from: Bahowe1 on April 26, 2018, 06:24:21 AM
i'll keep that in mind for my stockish 998 lhd mini
but what offset wheels did you have on your car with that size tires?
my radiator is mounted up front on the passenger side, if anything i would rub on the automatic gearbox or subframe
but my front suspension is also wider then stock
i haven't posted pictures of it et, but i kind of changed directions in the middle of my build
i wasn't going to go wide body at 1st, i had planned on keeping the old arches, group 6 or 7's, whatever they are
but plans changed and im going all out now
joakwin
front lip by joa kwin, on Flickr
i started to make a small lip at the bottom
joakwin
Whoa! You weren't kidding about the wide body look!  :-\
joakwin
Quote from: MiniDave on April 27, 2018, 05:59:44 PM
yeha, and those are only 13x6 +12 et wheels, not even a deep dish wheel
joakwin
bye bye del slow by joa kwin, on Flickr
bye bye del slow,
im getting ready to cut it up
Can't sell it or give it away to someone with a rusty one?
joakwin
Quote from: MiniDave on May 02, 2018, 11:26:52 AM
im cutting it up and keeping the part of the body the suspension connects to
my buddy has a lhd mini van that im trying to talk into selling to me,
he's never going to rebuild it because the floor of this van is rusted up like crazy
my plan is to build it with stock Honda suspension and Honda drivetrain
and stock honda axles
and a few other body mods to it
joakwin
cut off wheels and saw zaw blades were being super slow at getting this job done,
so i ordered a plasma cutter last night
it comes in Friday
joakwin
the del slow chassis, today the windshield came off of it
