joakwin
rear control arm by joa kwin, on Flickr
rear arm set up
coilover mount rear by joa kwin, on Flickr
in the process of making a lower coilover mount
joakwin
rear wheel mounted by joa kwin, on Flickr
this is how far my 6 inch wide rim sticks out from the body
13x6 with +12 offset rim.....wide body coming soon
joakwin
wide body kit by joa kwin, on Flickr
looks like i forgot to post a picture of the wide body arches
joakwin
lower coilover mount by joa kwin, on Flickr
still need to paint the spacer, but the coilover clears the caliper by a hair
joakwin
right rear control arm by joa kwin, on Flickr
right arm, i still need to mod the rear coilover mount
joakwin
joakwin
joakwin
#133
mini wide body by joa kwin, on Flickr
left rear arm mounted to the car with the Honda rear disc brake set up mounted
I still need to order up new Honda rotors and paint the calipers black to match the front wil wood calipers I have, red wouldnt look right
joakwin
joakwin
right rear suspension by joa kwin, on Flickr
right rear arm
i need to paint my calipers
need to order new rotors and brake pads for the Honda calipers
joakwin
my car has a park brake system now, with the del slow's park brake handle as well
i made up the new brake lines from the rear to the front valve
only thing left is to make lines for the front calipers and then i can bleed the system out
I can't wait to hear how the automatic performs - it should have a taller final drive than the manuals, so the revs should be lower, esp on the highway......
joakwin
#138
Quote from: MiniDave on March 12, 2018, 06:25:36 AM
the automatic gearing is perfect for the smaller size tires we use on our minis
1st gear take off ratio is 11.5
and overdrive is 2.77 ratio
it should take off nice and still pull good mph on the highway
joakwin
#139
body kit 2 by joa kwin, on Flickr
my car feels so low now that its sitting on four wheels, and not on jack stands anymore
tomorrow i plan to work on front brake lines
joakwin
rear calipers by joa kwin, on Flickr
todays work
calipers and pads for the rear, $73 for each caliper
i put 12oz of brake fluid into the car
started to pump the brakes and then hips got tired, so i called it a day
MiniGene
You should pick up a vacuum bleeder--they make bleeding brakes so much easier (and no pumping.)
joakwin
Quote from: MiniGene on March 15, 2018, 11:09:47 AM
yeah i need to buy one bad
joakwin
#143
1st drive by joa kwin, on Flickr
test drive
click on the photo and the video will play, not sure why its acting up
i still need to work on the front for the wide body suspension set up
MiniGene
Nice!!!  Where's the video of the burnout you did?
joakwin
joakwin
joakwin
wide body kit 2 by joa kwin, on Flickr
front clip is on the car
and i started to fit the flares
wide body 4 by joa kwin, on Flickr
wide body 3 by joa kwin, on Flickr
i plan to build the lower section of the front
joakwin
the outside edge of my tires to outside edge of other tire is 61.5 inches
i still need to adjust the lower arms for the camber
joakwin
wide body flare by joa kwin, on Flickr
i started to ext the flare to the body, i also made it 1/2 inch wider
lots of welding to do, i plan to weld those panels together and to the body to remove the screws from the panels
the screws are just to hold the sheet metal to the body
