Bahowe1
Thanks guys.  So, for now, I'll guess I'll just put the seal on the body and shut the boot quickly.  I only need it for possibility of rain at the April event (2-3 days).  But for when it comes the real time (after paint), the later seals, are they just larger and sort of lock themselves into that area on the body?
Also, yeah Dan, the screw holes are significantly larger than the screws on my old lid.  I was confused as well - but just assumed the later lid has a thicker screw.  I found some screws to fit, they were metric (maybe there is an SI equivalent - but that's harder to find for fine thread), M6x1.  That's a pretty thick screw.  I'll have to drill out (slightly) the cable ends and the rear latch holes to fit the thicker screw.  Anyone else experience this on a replacement lid?
The later seals are much easier to work with.  They just seal in  different spot is all.
The screws on my 89 are still the small ones.......
Bahowe1
#178
Lots more done in the past two weekends.
First picture is the boot lid screw difference.  I don't think it matters, just in case anyone is replacing a lid, it's something to note that you might need to source different screws.
Got the boot lid on... then off, then on, then off, etc.  Ha!  Fitting up anything new is fidgety.  But, I got the gaps pretty good now and am happy.  For the time being, I just glued the old seal on.  It'll get a new seal with the real rebuild (like my Flowmaster sicker?).
This weekend I put the doors back on - but I'll have a do a bit of fidgeting with the lower seals area to get the bottom of the door right, sort of sticks out a bit now as it is.  The front end and hood also went on and the gaps are pretty decent there.
I also got busy with a stud welder to fit my flares.  They'll get the rubber backing strip around them in the real rebuild, but for now, they look pretty good.  And I got a passenger seat in.  None of the interior will made the cut for the final rebuild... but it's good enough for the April event.  I also got a different color spray paint to cover over some of the exposed metal... I'm going for 'street camo' paint look now.
This weekend I put about 200 miles on it.  Problems... I have still been unsuccessful in getting the AC system to hold pressure all because one welded fitting.  Always, always make sure the tig welder knows what he is doing.  My first guy did not, and basically ruined the part.  The guy that has been trying to repair it, evidently can't get it clean enough to stop all the worm holes (even by trying to grind it all back down).  I'll have to start that hose from ground up again, with the good tig guy.  Been sorta aggravating that the first guy has cost me so much time and effort because he didn't know what he was doing.
Cooling... I noticed the fan would have to kick on in normal driving, 70 mile an hour interstate (which happens always in a stock mini), but I wanted mine to cool only off airflow (if possible), unless at idle- then use the fan.  I ended up cutting a bit more of the grill open and it made it significantly better - fan did not cut on (even though half the radiator is not in direct airflow).  But, the temps outside are 50-60, so I think I am still marginal when considering summer temps.  I may have to give up on my ideal of no fan during driving, or look into possibly doing some louvers or something, but they would need to be relatively un-noticeable.
Toe - the wheels were terribly out of line.  I had planned for an alignment, but it didn't work out, yet.  Jedduh and I threw some tape measures on it yesterday afternoon and revealed 3/4 to 1 an inch toe out!! Ouch.  No wonder the wheels were fighting each other.
It's really fun to drive though!  Lots of pictures to come...
Bahowe1
I forgot to get pictures of the whole car with the front flares too, but did have one shot of a front flare.
Also, the new headlights (trucklites), although spendy, are phenomenal.  I highly recommend.
How big of a hassle was it to get the boot handle to line up? I know that some/all? of those repros didn't line the handle up properly to the latching mechanism.
SomethingNew71
Man, this is looking so good Ben. I can't wait for you to give me a spin in it at CMU59.  ;D
I meant to share this with you before you got the stereo installed. It's a "headunit-less" stereo. All you use is a small control pad that can be wired to up front, then your phone just bluetooth's to it. Justin mentioned you wanted something concealed and hidden. Same process for wiring up all the speakers but no visible headunit.
Kenwood Amp+Headunit - https://amzn.to/2I26fOo
Bahowe1
Dan, you are right, the latch holes didn't line up.  Actually, the large hole even visibly looked a bit off center.  I ended up having to walk the big latch hole over North East a good 1/4 inch or so with a rasp.  But that then got into the screw holes that hold on the handle, so I had to walk those over too.  Then I back welded to close it all back in some, and carefully worked the rasp to get back to round holes and then ground it all back flat with a disc.  It took some time, but do-able.
Actually, the hinge holes were off enough too to where I decided to use them on the boot lid and then just walk over the holes on the body.  But... the body holes had been previously 'repaired', so it's possible those holes were off anyways.
Thanks Cole!  We'll certainly go for a spin.  Justin told me what you were doing for tunes and I considered that route.  I ended up with the stereo though because I end up listening to the radio a good bit, sometimes CDs and don't pay for any of the services (not as savvy as you).  But... the head unit I put in is already broken... way to go Sony!  At least they are sending me a replacement... but I am a little concerned that a 'today standard manufacturing' might not withstand the vibrations and bumps of the mini without some damping.  I'll try this new one and see what happens.
Is it possible the boot lid uses different screws because it is a reproduction part?    (not Heritage?)  If it was made elsewhere that would account for the metric threads.
Bahowe1
Bruce, I'm sure that is possible.
This weekend, I didn't do a whole lot on the mini - just re-wired a relay since it will run the radiator fan for both the AC line pressure, and coolant temp.  And I put on the side view mirrors (funny how shiny they are compared to the car).  I also worked on the AC line some more where the one weld was giving me a fit.  I think I have it mostly taken care of now, but can't yet charge the system because the body work is on the front end and the connections are too tight with the front end on ( I might change this as well).  At this point, I would rather drive the car and make sure it's ready for the CMU event, than take it back a part.  Oh - I got the replacement radio back in - so far, so good.  A couple more pictures with flares on...
Does anyone know a good place to get some louvers?  I've seen a couple places on line where I can buy blanks and then weld some in, but didn't know if anyone knows specifically of a place?  I would like to cut and weld in a few in front of the radiator as inconspicuously as possible.  I need some more air flow to the radiator.  It cools ok now in normal driving, but every now and again the fan has to come on.  Only about 1/4 to 1/3 of the radiator is in air flow.
Dave, does your friend's PuP do the same with cooling?
Also header wrap.  I've seen lots of thoughts on this.  Anyone have suggestions?  It'd have to make a big difference in my case, the header is only 6-8 inches or so from the radiator.
As I said, it's ok, but I'd like to see if I can get it to a state where it will cool itself without the radiator fan while in normal driving.  It might just not be possible - and that'll be ok if it's just the way it is.
SomethingNew71
I don't want you to paint the car. It looks so cool in the "multi-panel" look it has right now.
Bahowe1
Cole, get it right, it's called 'street camo'...
SomethingNew71
Bahowe1
Bits more done this weekend.  Got an alignment done - SO much better now.  I used some numbers MiniDave had online - except for the toe numbers - Dave what were your toe numbers again?
Modified the alternator tensioner bracket and changed the belt position - it could foul on the driveshaft during bumpy rides - all good now.
Made a new air funnel - two purposes - separate the header and radiator some, and funnel more air over to the radiator core.  Seems to help a lot.  The fan never needed to come on, but it was a cool-ish day.  A similar drive on a similar temp day needed the fan.  I also cut one more hole on the very bottom 'spoiler'? which will also get a funnel.
I have also achieved my 500 mile test run goal!
And... got an AC hose fitting re-welded (TIG - which I don't have) and tried to fill the system.  Failed again.  Pressure got too high on the low side - must be a blockage somewhere, or somehow the expansion valve is stuck.  I betcha I have had it hooked onto the AC machine 7 times now.  Usually it failed because a weld (see previous posts), but it seems to be all nice and tidy... just gotta figure out why it wouldn't take the full charge.
Does the fan come on with the A/C compressor? If not it pretty much has to or the low side will go crazy....
Bahowe1
Fan does not come on with the compressor.  The fan will come on off two signals - coolant temp sensor, or from the trinary switch if line pressure gets too high (like 250psi).  I called vintage air, they say for charging, it needs to have fan on.  I still don't think that'll get it.  They also said something about if the machine is charging with fluid or gas.  I have no idea.
I can certainly wire in to the relay a fan on wire when compressor is on - making it three reasons to turn on the fan.  You think this is what I should do?
Bahowe1
Well guys... thanks for all the help!  I made my goal...I was able to drive the car for the CMU59 event!  And it sure was fun!
I did have the tool bag out quite a bit, but I think it was reasonable.  The first spirited day, I broke the tack welds on the shifter.  a few months back, I had cut it and laid it back some and only tacked it back (didn't want to heat up all the grease in the cup).  A muffler shop at a lunch stop was able to fix me up.
Second day, I completely lost brakes.  Bit scary.  Turns out, the master cylinder went out.  Still baffled by this one, it was new-ish, installed right before I tore it down for the welding work.  Packed away nicely (better part of 2 years), reinstalled and bled out.  No problems for 500-700 miles, Yellow tag master, both circuits failed.
Next steps... take a break - do some house work!
I still need to finish the AC charge, just to make sure it is working well... but may give up on that until after I have torn down and rebuilt it all (with nice paint!).
Weld in some reinforcing for the rear seat belt install.
Weld in tabs to fit a real dash.
Weld on tabs to hold fuel and brake lines still under the car.
Fix master and a couple other niggly issues.
I always post with pictures... but looking back through CMU59 photos... I didn't take a single picture of my car... too ugly!
SomethingNew71
Well Bahowe1 we happen to have taken many of your car ourselves!
Bahowe1
Let's take a vote... Right or Left taillights?
If you vote left, I didn't care about your opinion anyway.
Bahowe1
You all have been a super helpful forum (thanks Dan!). If anyone is reading, I will share some (hopefully) helpful hints on welding - nothing new.  I am a self taught welder, so anything I say may be incorrect and wrong, but you all have been helpful and I thought I could at least share what I have found that allows me to weld in panels - using these taillight plates as the example.
I use a Hobart Handler 110 unit, with the gas bottle and solid core.  Most times, I operate it on this thin stuff at a level 3 power and feed speed of 35, gas flow around 35 (because I weld near the door of the garage and sometimes it's a little airy).
I started by removing the taillight (photo 1), then using the new piece to trace around to show me where to cut metal (photo 2).  Next I use HF specials - both their cheap grinder and their cut off disks to cut out just shy of the line I drew and finish it off to the line with a HF flap wheel - typically a 36 grit.
Once the fit is nice and snug, with very little gap all around, but enough gap to weld, I use a finer grit disk - an 80 or higher to just take the paint off the edges where weld and heat will be.  Shiny clean is your friend.
Then I use clamps, or my own fingers to hold the new panel flush with the old metal and spot weld a couple places to hold it in place.  Then, just continue to spot weld all the way around the part, maybe an inch or so apart, and then loop back around putting one in between each of the others until you finally have it welded all the way around (photo 3 - about half way through welding).  Then, I use a 36 grit flap to carefully knock off the top edges of the welds - and it helps your 80 and finer grits stay fresh.  Then use an 80 or maybe 120 flap to grind it down flush.
Spray some paint over top and done (photo 4).
Being a MK1 guy I'm partial to the right.  Nice work and description.  One of these days I'm going to buy a welder.  One of these days.
wow never seen a side by side comparison like that makes the left look really bad.
Lone Star Mini
Lone Star Mini
1992(?) Mini Cooper
1964 Austin Cooper
1980 Mini 95 (Pickup)
