wet blasting
Started by 94touring, April 15, 2016, 01:37:45 PM
stan360
It looks like that blaster works well.   If you were able to clear that much in just a few minutes, it should make things a bit easier.  I am guessing if you breezed through the resprayed panel with it then hopefully the thicker stuff in the boot shouldn't be to bad to deal with.
The thicker stuff actually comes off easier.
Quote from: 94touring on May 15, 2016, 06:49:03 PM
I am guessing more to grab on to for the media, ironically this can work out well in real life too. IfyouknowwhatImean.
Lowe's carries 50lb bags of fine sand that doesn't need filtered so that is a big time saver.  At 4.70 a bag it beats 10 bucks for something like blacl diamond or crushed glass.  Made a booth to capture media but it really didn't work too well.  Tomorrow will attempt to get hooks installed to hang a tarp.  I did the engine bay, inner wings, windscreen, and one side with 250lbs of sand.
Are you able to re-use the sand?
What do you drive that can haul 250lbs or sand or more? I'm tellin you, you need a pickup truck!   ;D ;D ;D
I could reuse the sand but honestly it's not worth the hassle.
Pax seat out of the mini!  Instant work vehicle.
Rain gear, runber boots, and face shield are required.  Based on what I've done so far I'd say 1500lbs of media will do every nook and cranny.  Also bought this same sand the other day and it didn't require sifting but every one  of these bags had  to be sifted.  Good news is the blast nozzle can take large media, so a kitchen collender with larger openings was quick and fairly painless.  Lowes was out of the extra fine sand.
The tarp worked great but I need an outdoor pad to do this without all the mess.  Also a pic of rust iinhibitor tthat does the trick.
MiniGene
Man, that set up looks handy.  Let's see it in action on some wheels!
I'll hit the clubby wheels next chance I get.
Quick update to how to prevent flash rust.  After you spray this phosphoric acid (diluted 3:1), you let it sit 15-30 minutes, rinse off, then immediately dry.  If you don't dry it will get rust looking streaks.  The end product after drying will have a bluish to blackish to grey coloring.  You may also note some white powder type coating, which is a byproduct of the acid doing its work.  I would recommend a quick scotch bright scuff and metal prep/rubbing alcohol  just prior to sealer primer.
My BIL works for a water blasting company, they blast paint off concrete minus the media, it is insane.  They can also cut steel too, with water....
Paint Removal:
Cutting Steel
Can you imagine how much water pressure their machines make?
I am sure he could wipe the paint off a car like it was nothing.
It would probably bend a mini in half!
Nah, it would just blow holes in it like tissue paper!
Dmulder
My neighbor works for an environmental company that also pressure washes industrial tanks and such. He brought a pressure washer home the other day that could cut through steel. Crazy
Quote from: Dmulder on May 26, 2016, 04:53:17 AM
Yup, that is what my BIL does too, in that one steel pic you can see they opened up a silo to clean it out.
They work for the Sugar Farmers a lot in the middle of the state.  His is an effing machine my BIL. They were supposed to be at this school in Tampa for 3 weeks straight, no days off, including this weekend.
He rallied the crew and they worked from 6 a.m. to 11 p.m. all week, they are 5 days ahead of schedule.  He then approached the owner, reported they are 5 days ahead and would like to take the holiday weekend off. They are all heading home this evening and going back Tuesday morning.
He used to work for me, he is the reason I am in a hole right now, I tried like hell to keep him when the market crashed.  He was and will always be the best employee I ever had.
Contacted an abrasive company locally to get my fine sand pricing to a tolerable level.  Can get 3400 pounds for $160.  To compare, that much fine sand from lowes would be $390.
Delivered? Where will you store it so that it stays dry?
Delivered...Justin lol.
I'll probably just stick the palet in the corner of the shop via gantry.  The rx7 might be moving to the carport.
Oh, it's bagged, not bulk? That's a good deal then.....
42 80lb bags at a time!  Save a dollar a bag buying by the palet.  Considering how much sand it takes to do an entire car, a palet a time is ideal.
Won't that make for a lot of used sand all over the shop floor?
Beach volleyball anyone?
I'll be doing it outside.  I tarp off a section in the garage opening for now.
Eventually, you'll have a big pile o'sand.  Not that the local cats will see a huge litterbox, but I'd be tempted to try sifting it and re-using it.
My yard will be fine with sand.  I have a country lot with a depression that collects water.  Never will I be out there sifting 2000lbs of sand.  This much I can tell you.
