AcesLow's 1973 Morris Pick up
Started by AcesLow, April 05, 2011, 02:36:36 PM
Here's a pic of someone's pickup...don't know who, showing the tailgate lowered.
Could the support bars be reversed (left to right)?  It looks almost as if the mount plates are different heights and the ones on the bed upright panels are taller - recessing deeper into the bed.  That would pull up the tailgate ends creating the angle.
AcesLow
Ill check that out. I didnt label them so they could be reversed.
I have my truck back at the house with me if you need any pics let me know I will be happy to snap a few and post them up.
I don't think you can put the struts on backwards without them being upside down but maybe.
I got to check out a pickup this last week and his tail gate sat up as much as yours just the build quality on some of them I think. That said I would have to modify it to sit lower.
BTW Looking good I have had to do the same to door gaps I think I ground down the door edge on one of mine and re welded.
Jeff
Start          Spin 180       To get        Flip 180      To get final
with            on this         this for       on this        position on
this             axis           swapping      axis           other side with
on one                           sides                           mounts in right
side        positions
  0                 0               0             -- 0 --                0
Hopefully, the above stick diagram helps visualize what might work.  It should keep the hinge point of the braces still pointing down for a right-to-left swap.  If the height of the mounts on each end of a brace are the same, it won't matter.  Just if the one mounted on the vertical is taller would swapping let the tailgate drop a bit further.
AcesLow
Your bracket seems to be alot lower.  Ill try the new ones when i have time. Im scared the box floor dropped a bit while I was putting the box sides on..
Thanks for the help and the pictures!!!
Let me know if you need some more accurate measurements, it is kind of hard to tell what the actual dimension is.
How many miles of welding wire have you gone thru so far?   ;D
I see the factory instrument cluster opening through the firewall being blanked off and a radiator grill/outlet being added to the right inner wing, but I do not understand why.
I may have lost track, is the truck getting an alternate power source that needs the cooling repositioned?
I asked a while back.
5PW Yamaha R1 engine was the response
Jeff
AcesLow
I guess the text didnt post with the photos. Added the cooling on the right hand side as the rad switches sides with the promotive kit. I am shaving as much of the firewall as possible to give it that clean look.
The problem I have with putting a bike engine in a car is it seems they run about 5K rpm when you're doing 30 mph, because the HP is all above 5 grand.....so you're always wound up.
AcesLow
Gearing should help with that I would think.  We will see. Hopefully i dont get it all together and hate it.. its only been a 5 year resto...
AcesLow
Can a pickup owner please snap a picture of the opening for the tail gate and measure the opening. I think my tailgate is bowed and that has now caused me to set the box side width with a damaged tailgate. Just want to see if I am out or not.
Am I being a perfectionist? I am thinking to order new box sides and try fitting them again. They seem to be tilted tail down slightly which is causing a tight door gap at the bottom and where they meet the  B pillar there is a 3/16 gap.  As well as the mentioned above with the tail gate.
Spitz
"Am I being a perfectionist?"
Absolutely nothing wrong with wanting to get it perfect.
I'm sorry I can't help you with a measurement.....but the fitment of my tailgate bugged the hell out of me.  To me it sticks out like a sore thumb if it's not correct, as the pic of mine shows
My buddy Don's is the opposite, wide at the bottom.....we tried to widen it our a bit with a porta power, didn't move a lick so we gave up.
Mine is far from square as well.  My tops are too tight and needs work.  I chalk it up to minis being cheaply built.
AcesLow
#196
I had to modify these brackets a fair bit. Which is why I am wondering what the opening width is.  I'm scared if I wanted to go get a new tailgate that all the body work I've done makes the tail too narrow and Ill have to cut it all apart to fit a new tail gate.
AcesLow
Builds been quiet for some time. The truck is home now and I can work it alot more. Hopefully make some headway inthe next few weeks and have some updates for you all.
I can't believe how much room you have to work!
Quote from: AcesLow on February 25, 2016, 09:50:26 PM
PM me if you ever need anything. I completely missed this, if you still want numbers I can do it this evening. I think mine is pretty straight. I I am going to be out there this evening.  Do you have the tail gate?  Why not measure that ?
