Electric a/c for Minis
Started by MPlayle, October 08, 2026, 10:07:13 AM
Starting a separate thread to discuss/track this.
Quote from: MiniDave on October 08, 2026, 08:54:06 AMPost up what you find on the A/C, in fact we should start a thread on just that as I'm looking into it too for my hot rod Mini.
I had a guy bring an electric compressor over yesterday so I could see how big and heavy it was, and where I might mount it. My understanding is that they all draw about 50 amps on start up then run at about 30, so you'll need a healthy alternator to keep up - fortunately the one on the hot rod is 150 amp, so I'm good there.
I'm not sure but I think you can get one with a heat strip in the evaporator assembly too, which I would love - instant heat and defrost!
My thinking is to mount the compressor right up on the bulkhead so the hoses will be shorter, then I just have to supply power from the back. It was interesting on this compressor that the inlet and outlet for the hoses were on opposite ends of it. I already have the condenser but I still need to figure out the mounting, hose runs etc. I was thinking I would like to make hard lines for almost all of it, just a short run of rubber hose off the compressor. The one he brought also had rubber mounting "feet", and I would have to make a bracket to support it up on the bulkhead..
Not sure what size cable I'll need, the wires that went from the inverter/controller on this one only looked to be about 10 gauge. Seems like it would need to be bigger than that to supply 50 amps. Not sure on that yet. Lots to learn!
I am still researching the topic.  A while back, another Mini related friend sent me an article where a UK outfit had installed a setup into a classic Mini destined for Singapore.  I have been consulting with them and some of their sources - in particular for a high output alternator that will fit our Minis.  I am still waiting on feedback regarding the alternators.
Most of the kits I have found recommend an alternator putting out at least 120 amps at idle/low rpms.  I did a quick consult with one of the kit suppliers in the US (Miami, Florida based) and they can supply with a variety of condensor sizes (I am considering the 12"x14" for tucked into the rear subframe) and a variety of evaporators (both "cool only" and "heat/cool").  I have a couple of models under consideration that are 14.5" wide, 12.5" deep, and 6" tall.
It sounds like the compressor you have test fit is the typical one now being used.  They are often listed as being dual-scroll type.
One thing I have been finding in my research: the cooling capacity of the 12 volt electric compressors is better than it used to be, but not yet comparable to belt driven compressors.
As long as you are realistic about your expectations, they are still a viable option for our Minis, just don't expect to get 40* output.  You are most likely going to get 60*-70* output, which for me is vastly better than 90*+ ambient in a Van with sliding windows and wispy little USB dash fans for when stopped.
If I can get the alternator output requirement solved, I will likely go forward with the effort.
I figure with such a small area to cool it should be adequate, plus too and also, I'm not out driving on 95* days if I can help it!
To me, it will help just being able to close the windows for less travel noise.
