Mini is ALIVE!
Started by Dan Moffet, Today at 08:40:10 AM
Dan Moffet
Yesterday, I finally found time to wake Desiree from her long winter slumber. Tires were low but holding. Oil is full and clean, Rad is full to proper level. Absolutely no drips on the floor! Battery charged. Spark plug wires connected (wondering why I'd left them disconnected).
She started! Because I'd squirted oil into the cylinders and swished it around, cranking with the plugs removed, there was the usual cloud of oil smoke. It took a while for the engine to warm up and purge the oil and whatever was left in the carb bowl.
Once warmed, there is some roughness and idle eventually drops away to nothing. I attribute that to 2 year old gas. High octane with stabilizer, but that doesn't last forever.
So, today, I pumped the 3/4 full fuel tank out (about 5 imperial gallons) and put that in the Jeep which was 3/4 full and uses regular gas. The next step is to go get some fresh gas and try that. I'm hoping she will only need a hearty romp to clear her lungs.
