Rust Bullet Paint
Started by cdnmini, March 02, 2021, 05:14:03 PM
cdnmini
Has anyone used this product on their mini to help keep the tin worm away?
Painted my spare front subframe last year with this product, but was wondering what peoples personal experience is with this paint.
Have used Por-15 in the past, with good results, but not fun to work with.
Phil
Why do people say that about POR? I've heard folks claim that it won't come off if you get it on your skin, a little lacquer thinner on a cloth took it right off me. It went on really smooth and laid out nice once it cured.....I was pretty happy with how easy it was to use......and it looked great - really shiny, almost like porcelain.
As for Rust Bullet, I've never tried it.....
cdnmini
Por-15 is still doing its job after 10 years. So no complaints there.
You had better luck getting it off your skin then I did.
Had latex gloves on, but didnt notice that they had ripped in few places.
By the time I was finished painting the underbody, my fingers were a mess.
Tried everything I had in the garage, unfortunately ended up wearing the paint for few weeks.
Interested just how the Rust Bullet paint holds-up without having to top coat it.
Phil
So Rust-Bullet is UV stable?
cdnmini
Thats what they claim, no top coat required.
One thing I did experience, you need to put two coats on.
First coat usually ends up with little bubbles.
Second coat seals that.
I also painted a rusty roll bar, which came out really good.
Time will tell....
Phil
Quote from: MiniDave on March 02, 2021, 05:36:09 PM
Because POR is a PIA to use store clean up etc....  It can work very well but can peel in sheets if not over rust depending on prep, the top coat can peel if the primer is not applied to POR while tacky, I like POR and it has a place but it has issues.
If it was easy you might be getting away with something or didn't need to topcoat and only painted over rust and nothing else in the area you used it. In the latter case, it's awesome.
I'm just using Rustoleum now, easy to use, easy to clean up, lasts well in our applications. not show quality but holds up well
