HIF throttle cable mount plate
Started by Willie_B, July 29, 2020, 06:19:35 PM
I use a slightly modified BCE.  This chart will show you probably want to start with a BDL, BDK, or BCE.  I had to file the upper stations a little to richen top end.  I use a red spring and 1 washer.
Here is the size washer I use to tweak John.
#26
Did you just lay it in the piston under the spring?  What about the air transfer holes - or is that washer big enough that it rests only on the upper portion of the piston?
Quote from: cstudep on August 09, 2020, 05:42:51 PM
So if a guy was going to attempt converting a dual carb setup to a single HIF44 what is the recommended setup for a 1275 in a 1960 car? It's running a 266 fast road cam and I would probably run it with a K&N filter.
I have heard that the early Minis have a bigger clearance issue in that the firewall does not have the cut out/dip under the jet area.
On the Later 90s 1275 Minis with HIFs the factory moved the engine forward around 3/4 to 1 inch and used a longer engine steady to get the clearance needed.
Quote from: John Gervais on August 10, 2020, 04:59:52 PM
Just rest on the upper portion.
Cool - I'll look for a larger washer!
Quote from: John Gervais on August 10, 2020, 06:38:51 PM
I took my carb piston into the hardware store and matched up the washer.  It's a perfect fit.  Granted this is very OCD type tuning, but little tweaks can make some significant improvements.  Without a wideband you're really just guessing and going by seat of the pants feel.  Wouldn't be worth the time.
Excellent thanks for the information. I have been looking at various wideband sensors and gauges, is there a particular one that you prefer? I see some complaints about some of them being a bit fragile with the sensor contaminating easily.
I have a couple different one's I use and they're all about the same.  Very rarely have a sensor go bad.  Fail about as much as your standard 02 sensor.
