How could I forget...almost shit my self taking a shit at the shop.  Something aggressively hit my ass on an upward trajectory whilst sitting on the toilet.  There was a tree frog in there. I came up off the seat like a rocket ship.  Set him free outside.
I noticed my TRD CAI was on its last legs. The filter was dry rotted, the box was very brittle and cracking in a lot of places.
I decided to just get a K&N CAI to replace it as the TRD was about $500 vs $350 for the K&N.
My one issue, the K&N tells you to scavenge a fitting off the stock intake to use on it, I do not have the stock intake, only the TRD and that eliminated the need for the fitting, I was able to find the part number, Toyota wanted over $40 shipped, I found it OEM on Amazon for $20 shipped and it will be here tomorrow.  For now, I made an adapter out of some orange cap I had lying in my garage that fit the hole, sort of. I will feel better once the correct adapter arrives.
Correct adapter acquired and installed.  Much better now, I expected a 90° fitting, this works.
Is there a bracket or something that's supposed to attach to the nut and stud on top of the new tubing?
Since the filter is behind that bulkhead, where does it draw it's cold air from?
Most Toyotas I have seen draw air into the airbox through a fitting/hole in the inner fender. So I suppose its technically a "cold air intake" even in stock form since its drawing air from the space between the inner and outer fender.
Nut/Stud on top is for the engine vanity cover, I always take them off my cars.
There is a large factory hole to the left of the new K&N filter in the fender, the TRD box had a opening that reached into the hole, you can see it on the top pic of the TRD box, the K&N just shields the air filter from the engine bay with the air coming in from the hole in the fender.
Merlin
Been a minute. Just getting caught up. Been working on my workshop fairly heavily the last two months and bought a forklift to help with some heavy moving. This S-hyster is too smart for its own good and wont start or move unless you sit in the seat and buckle the seatbelt in that specific order. If you work alone a lot, you find yourself operating a forklift while standing next to it quite often.
So today I hired a new employee.
Engineering the Impossible
That's hilarious
Worked a little on both cars:
1) Flipped the tow ball on the hitch of the Subaru from a 1.75" rise to a 2" drop for better use when flat towing the Mini.
2) Mounted the new "shimless" ball joints on the new hubs for the Mini as a start of that process.
Quote from: Jims5543 on October 08, 2026, 09:51:26 AMNut/Stud on top is for the engine vanity cover, I always take them off my cars.
Don't worry about getting rain/spray in there? reason I ask is that I may have to do something similar on my hot rod Mini - ie: pull intake air from under the fender
My tundra gets it's air from the fender also.
ADRay
yesterday I put the finishing touches on rebuilding the head, and after a couple hiccups, had it out for a drive by 2 pm. It's been off the road since early June.
1982 Mini 1000 HL
@ndyray
I'll try to grab a couple of pics Dave, there is a hole in my fender that leads to the wheel well behind the liner. Water cannot get inside the air box unless I tried really hard like took a large puddle at 40 MPH.
I was annoyed by the tire store, I was hoping they had enough sense to use black wheel weights on the black rims. The didn't. Amazon to the rescue. I ordered a box of them and replaced the silver weights with black.
One thing struck me as curious, one rim had no weights? None.  What are the chances of that?  Or more likely they missed balancing that rim, I am taking it back tomorrow to have them check it.
Merlin
We've been working on our shop for a while. I've been putting in epoxy floors and spray foam and LED lights, but I only have space to work on half of it at a time. We are in the process of grinding the second half for epoxy which I hoped to have laid down by this weekend.
#1064
When they did the epoxy on our plant floors, they used an interesting machine - it shot steel balls onto the concrete to "etch" it for the base, primer coat. Then the top coat was sort of troweled on. It came out beautifully, but was slippery as hell when wet - so watch that! Of course, if you add the texture to make it less slippery, it also becomes harder to clean and shows dirt worse. This stuff went down to a total thickness of about 3/8"...
It sure was easy to clean tho, we had a Tennant machine to do the floors. As this was a food plant with lots of flour everywhere it had to be done daily, hence the machinery and floor coating.
The brand was "Stonhard", and it was durable enough that we drove fork trucks over it, at one point we had to move a 10K lb mixer and that fork truck had to weigh the same, didn't even make a mark.
https://www.stonhard.com/industry/industrial-commercial-flooring/?creative=628028627653&keyword=stonhard%20flooring&matchtype=e&network=g&device=c&gad_source=1&gad_campaignid=18591092554&gclid=CjwKCAjwl4HXBhAjEiwAHlpWhMKr3db5MXyDwA8LICvNafyagLWNT5AnWFfC7KmC_MUW76DRCE9yUhoCzssQAvD_BwE
Merlin
I looked at renting the shot machine but it was $500++ a day. The grinder was $200 a day and I had two rounds to go through. Part of me wishes I went the shop peen direction because the dust was killer with the grinder and my concrete was poured by the lowest bidder.
I think those were both the reasons they used the shot peen, we didn't need the dust in the air and it gave a quick result - however you couldn't take out bumps or unevenness very well with it.
Grinding is an arduous process.....
