Ivy - 1995 Mini Cooper
Started by flipstah, July 21, 2016, 08:27:09 AM
0 Members and 8 Guests are viewing this topic.
Yes....how are the bearings for example? Ball joints? Axle boots? Front and rear rubber brake hoses? Cotter pins for the front axles and rear bearings? Cotter pins for the pads? (those might come with the pads, but usually don't)
Some of that stuff looks like it has really come down in price, BTW.......
flipstah
Quote from: 94touring on June 17, 2024, 04:37:55 PMIf you're not needing to drive the car anytime soon, go ahead and pull your brakes off, disassemble, and see what all you need to buy or replace.
I wish I had that luxury. My garage is small and the wife's car goes in there while I park mine in a car cover.
flipstah
My MiniSpares order came and did the brakes today but had some minor setbacks that'll need another day of work,
- the rear drum adjuster screw was a tough one to remove so have to buy spare ones just in case I snap them and have to drill a new hole
- does anyone know the size of the front axle nut? Couldn't replace the discs so just did the pads until I buy the appropriate socket
#153
Be aware that the rear adjuster screws come out to the inside of the drum, they don't come out thru the back of the backing plate......just FYI
I'm pretty sure the nuts are 1 5/16"
flipstah
Quote from: MiniDave on June 29, 2024, 08:23:33 PMBe aware that the rear adjuster screws come out to the inside of the drum, they don't come out thru the back of the backing plate......just FYI
I'm pretty sure the nuts are 1 5/6"
Wait what? Lol that was dumb
So how does the adjusting work so that the shoes expand to the drum when it's on? I could not make the outside bolt move for the life of me
1 5/16, sorry.....
If the adjusting screw is stuck, you def need to get if freed up.....get some penetrating oil on it and with the rear drum off run it in and out till it moves freely. You can remove the screw to clean it by running it in all the way. You probably have to remove the shoes to get it out but if you can get it moving freely that will do.
flipstah
Quote from: MiniDave on June 30, 2024, 08:17:06 AM1 5/16, sorry.....
Just wanted to clarify that the "dumb" comment I made was the design of the drum brake.
Appreciate the help so far and I'll definitely need to get the bolt off to finish the work!
I usually remove the shoes, then I can get some heat on the adjuster if it's really stuck......but normally getting some penetrating oil on it and just working it back and forth will get it loose. Once you go to putting things back together a tiny bit of grease on the flats of the adjuster where they hit the shoes makes it all work better.
flipstah
#158
Had a major coolant leak last week which was worrying. Turned out to be the water pump failing.
Fitted a new pump and we're back in the races
Then I find out my battery is ancient from Japan so replaced them with 24F size from NAPA
Post polarity was inverted so had to replace the ground wire with a longer one. It was due for a new one anyways
