Wheel bearings?
Started by MPlayle, October 03, 2026, 11:37:00 AM
94touring and 1 Guest are viewing this topic.
When I added the wheel spacers to the rear of my Mini (unspacered rear drums with front disk brakes), I checked for play in the rear bearings/hubs and repacked the bearings while I had the hubs off to install the longer studs.
I recently noticed a shimmy/vibration apparently from the front (noticeable in the steering wheel) that starts about 65-70 mph.  It is still present after ensuring the wheels are balanced.
Today I went out and did some checking for play in the fronts and found if I grab top & bottom of the wheel and push the top while pulling the bottom style rocking, there is the faintest of play - just barely enough to feel.  It appears to be in the hub as watching the ball joints while doing the rocking shows no movement there, but the movement does appear at the hub.
Is this a sign my front wheel bearings are going to need replacing soon?
If so, I will add that to my list of projects/tasks for during the turbo install.
Edit: The only "play" is the very faint up/down.  There is no in/out play.
Disc brake hubs?  What ft lbs and method did you use to torque them?
Yes, the front is disk brake hubs.  I think I last did close to 150 ft-lbs, then to the next slot in the castle nut for the cotter pin.
To hold everything, I usually do it with the transmission in reverse and the engine locked by using my flywheel locking tool through the started hole.
I think there is supposed to be absolutely zero play in the front bearings, as that's what the spacer in the middle is for, to set the preload.
But sometimes it's wear in the hub flange that causes it, not the bearings, so you need to look at that closely.
Hub flange?  I am having trouble picturing what that is in order to inspect it.
If it is hub flange wear, does that mean new hubs are needed?
ADRay
Quote from: MPlayle on October 03, 2026, 11:44:04 AMYes, the front is disk brake hubs.  I think I last did close to 150 ft-lbs, then to the next slot in the castle nut for the cotter pin.
Just to clarify, the front bearings are new? Did you do the "torque with flat washer first" procedure? I had to do it to mine after new front bearings.
1982 Mini 1000 HL
@ndyray
I don't fully remember as it was about 4 years ago when I had the hubs of and redid the ball joints with the "maintenance free" ones.
I may play it safe and replace most of the assemblies - new hubs, bearings, drive flange, ball joints, etc.  I know the brake pads were new when I did the ball joints and they still have lots of pad.  I will likely reuse the calipers, pads, and rotors.  Unless the shafts of the CV joints show obvious wear, they will also likely be reused.
It will be the beginning of November before I can really start taking anything apart to check.
Where I am considering the near-full-replacement approach, where would I obtain the correct flat washer for the "torque with flat washer first" procedure?
ADRay
Quote from: MPlayle on October 04, 2026, 04:41:34 PMWhere I am considering the near-full-replacement approach, where would I obtain the correct flat washer for the "torque with flat washer first" procedure?
I was able to find a suitable washer at the local fastener store. Attached is the specs given in the Haynes manual
1982 Mini 1000 HL
@ndyray
I'll see if I can find a suitable one near me.  If not, I'll add one to the parts list to order from Spares.
Made a start on the new hubs: I installed the new "shimless" ball joints on the hubs and greased them in preparation for that effort.
I also reviewed my service records and I have NOT had the current hubs apart, so I don't know how old they are.  I did install a set of the "shimless" ball joints in May/June 2023, but that is the only thing I have done to the front hubs.
Did a bit more prep work on the hubs today.  I installed the new bearing kits into the new hubs.  I am using genuine Timkin bearing sets and paid special attention to keep the bearings matched to their respective outer races and center spacers.
After driving home from an "All British" car show this past weekend, I decided to tackle doing just the front hubs project first.  (I'm also doing some house-hunting to finally get out of an apartment.)
I got the left hub partially disassembled today - enough to get the drive flange off.  I haven't gotten it apart enough to inspect the bearings, but the splines on both the CV joint and the drive flange show obvious wear to even my untrained eyes.
I had hoped to reuse the screws that hold the brake rotor to the drive flange, but one had a stripped head and had to be drilled out.  Once the head was drilled off and the flange and rotor separated the rest easily unscrewed.  I will need to obtain a full set of replacement rotor/drive flange screws, but that is better than having to replace the rotors as well.
Congrats on the house hunt - are you looking in the general San Antonio area?
Quote from: MiniDave on October 28, 2026, 01:34:10 PMCongrats on the house hunt - are you looking in the general San Antonio area?
More or less.  Looking in San Antonio and the surrounding counties in the hill country area.  Finding something affordable is tough though.
Got some more done today.
I got the left side hub fully removed, the driveshaft out, the steering arm removed, the old outer CV joint off the driveshaft, and the new CV joint greased and installed on the driveshaft.  I also got the right side fully removed and the old outer CV joint off the driveshaft.  The new drive flange screws are due in Monday.
When I took the hubs off the CV joints, the shaft of the CV joint looked coated in thin, brown oil/grease.  The bearing in the old hubs are a kind that does not use the center spacer like the genuine Timkin bearings I put in the new replacement hubs.  I got the impression they are probably either factory or the budget variety bearings that were installed when the disk brake conversion was done by a previous owner before I got the Van.  They definitely looked ready for at least being repacked/resealed if not replaced.
Since I am replacing everything hub related except the brake rotors, I am just going to trash all the old stuff.
Got both the new hubs fully assembled and torqued (used the flat washer from Mini Spares first, then the tapered washer).  The axel/hub assemblies are now ready to put back in.
The carb for the turbo kit was backordered and Jeremy expects them to ship to him next week.  I expect it will be into the week after before they arrive at Jet Motors and then the week after that to ship to me.
With that amount of time, I will probably go ahead and install the axel/hubs back in the car and have it back on the road.
Both refreshed hubs are now in the car.  I just have to put the bonnet and wheels back on in order to test drive it.  I took the bonnet off to use my cone compressor to make it easier to put the hubs back in.
Yeah, you pretty much have to do that to change or compress the cones....sounds like progress. How's the turbo project coming?
