Adventures with a 68 Mini
blaked
Light progress on the car this past weekend. Fitted the door post boxing plate. Question for the group - would you recommend as a next step to install the outer wings or save that for the later and instead tackle the rear driver corner and boot floor repair. Is there any advantage one way or the other.
mk2 cooper
Either way, but one thing I probably should have mentioned was fit the front wings before you go welding up the A panels. It can prove to be difficult to get A panels, wings, and the front end panel to all fit. Also fit the bonnet at the same time to verify gaps. You should also fit the front subframe to the front end panel to align it all.
blaked
Afternoon everyone - fiddled with the outer wings for several hours Saturday and got them to a reasonable place for welding today. The passenger outer wing is now securely tacked in place. Would have kept going but ran out of wire. The wings in are clamped in place in the photos with the bonnet. With the wing on its looking like a Mini again!
On the way are several panels for the rear: a complete back panel, full boot floor, heel board, and some other odds and ends. Anyone know if repair panels are made for the upper parts of the B and C post - essentially the surround of the rear window.
mk2 cooper
skmini
Gaps look really good.  I spent a few hours with mine too and it was super satisfying to have it finally all line up.
blaked
Good morning everyone, yesterday was new panel day for me - very exciting. A complete back panel, full boot floor (w/ battery box), heel board, rear valence, and some other bits. The parts landed within a week of order at 570 GP in shipping and 350 USD in tariffs. If anyone hasn't ordered panels recently tariffs are applied at entry. A separate invoice was sent by the carrier, in this case DHL.
As I plan the rear end repair, is there an oder of operations that is recommended? Back panel first then boot floor, boot floor then back panel, both at the same time, or doesn't really matter/personal preference? Secondly, is bracing recommended before either the boot floor or back panel are removed?
Appreciate any guidance the community can offer.
mk2 cooper
Would you mind breaking the bill down? I'm still trying to compare what we're all being charged to find some consistency in the tarrifs.  It's all over the map right now. Whenever I make my next big order I'd like to at least be prepared for the pain.
For your rear end...are your wheel arches still in place and the subframe attach point brackets that are on the rear arches?  If so just slide the boot floor in place and bolt it to those attachment points. If not, well attach a bare subframe with trunions and clamp the whole rear end and boot floor and then begin to tack into place. Then remove subframe and get to welding.
blaked
Checked the invoices and total for the panels was 903.50 GP. The tariff was 319.93 USD. Looks like i overestimated from memory in the post above.
The arches are in and so are the brackets so thats good. Ill use that for alignment. Once I get the floor tacked in ill test fit the subframe. Kinda regretting that task as the assembly is fully built with radius arms.
mk2 cooper
Ok so after shipping the panels were about 2k USD and then call it 15% tarrif plus their $17 admin fee and a few bucks for the regulatory bill they add.  Thanks!
Takes about 1.5 hours to take the arms off and put them back on I just discovered yesterday redoing some stuff for a guys subframe fyi.
Another thing you'll see since the arches are still in place, the boot floor will only fit one way with them there. So the alignment part will be very easy. You'll just want a rear end panel there to get the correct "pitch" on the boot floor, though those brackets for the subframe on the arches, provided they haven't been bent one way or the other, will set it pretty much where you need it. No real reason to mount the subframe since those brackets are already there.
blaked
The math im calculating is:
1 GBP = 1.32 USD (as of today)
903.5 x 1.319 = 1,191.72 USD
319.93 / 1,191.72 = 26.8%
mk2 cooper
#36
Did you say shipping was 570£ also?
They use shipping in their duty calculation. So if it came out to approximately $1945 × 15% = $291.  Then they charge us $17 in processing fees.  Then there's a few bucks in regulatory charges.
blaked
Got it, didn't realize shipping was included as the cost basis in the duty calcs. That's unfortunate. To bad i ran out of gas today and couldn't get to putting those panels in. But i did finally take the sliding door trim off my van to clean out the playa dust.
mk2 cooper
Yeah it sucks.
And that playa dust is still in every knook in my bus!
blaked
Both outer wings installed. Some clean up remains on the driver side but shes all in! On the drivers side front end panel I had to build up the flange and grind the curve to get a good fit. good enough for my car. Hope ya'll had a wonderful thanksgiving.
mk2 cooper
Nice job. Sometimes those front ends need a little persuasion.
blaked
Another round of panels were delivered yesterday. 440 GP including shipping. This time I was not asked to pay an import duty by DHL. Strange times.
mk2 cooper
Yeah like what happened to me on a big order. I guess we get lucky once in awhile.
blaked
Lots of demolition on the back end this weekend. Got the rear valance, valance closing panels, most of the boot floor, rot at the wheel arch, and part of the seat pan. Its possible i went a little overboard on the demo, but i found it helpful to create access and see how the panels are connected to each other. As the heel board requires repairing I decided to replace a section of the rear floor pan instead of patching it up. While i'm in this corner and before the boot floor goes in i'll repair the section of the quarter panel. Hopefully new metal goes in before the new year.
mk2 cooper
Yeah may as well just install it as one unit and replace the rear seat. Inspect the captive nuts for the rear subframe attach points. Good time to add an extra weld or replace them if they're hanging on by a thread. Nothing worse than welding everything closed and one pops loose when you reinstall the subframe.
blaked
Are you referring to the heel board or the full boot floor pan w/ seat?
mk2 cooper
Yes the captive nuts on the heelboard the subframe bolts to. With them exposed they're easy to clean up or replace if they're on the ragged edge. It's not uncommon for them to come loose the way the factory presses them in. I like to add a spot weld or two on them when they're easy to get to.
blaked
#47
Happy new year everyone. Did not manage to get new metal in before years end. Instead, I needed more demo, decided to make a jig (Don't mind the 12t jack) and spent several hours overthinking the sequence of repair. Major analysis paralysis with the heel board and floor but think i'm there.
Boot floor including seat pan is now completely out. Decided on a half the heel board repair over the whole panel - hope I dont regret it. During passenger outer sill replacement I throughly inspected the heel board captive nuts and they appeared to be in serviceable shape. Ill tack in the repair panel then fit the subby. The half heel board is prepped up and ready for install - including some extra weld on the captive nuts.
Decided to cut out some rot in the rear quarter panel and fabricated a repair section. Will put that in, then go after the heel board, then get to the rear floor section.
mk2 cooper
Boy howdy do I relate to the analysis paralysis....
blaked
Heel board repair section welded in place. Once there's more structure to the back end ill clean up the welds. The jig was built from the mounting holes on the existing heel board before demolition and the jig was confirmed to mate with the rear subframe. So hopefully she lines up when that point comes. Rear quarter repair section installed. Rear floor board with inner sill tacked in place. Would have been nice if this panel was always part of the plan - in that instance the perpendicular weld line would be under the cross member - or alternatively a half panel would have been used.
There really is a lot of hammering to be done on these restorations - still not great at it though. Nevertheless still satisfying getting new metal in the old car.
mk2 cooper
