Looking for a Rear Hydro Subframe
Started by stodgy, December 15, 2023, 02:48:21 PM
stodgy
Hi -
Car's been off the road for ~10 years and am compiling parts for a rebuild.
I'm looking for a rear wet subframe.
Looks like someone hooked the web when towing and ripped the metal apart. Drove it like this as daily driver for awhile but it needs to be replaced.
I'm in SoCal.
Thanks!
Dave
Red Riley
What's different about a wet rear sub vs dry?
Where a rubber cone would seat in a dry subframe is different in a wet subframe as it has a set of tabs to help lock the hydro bag in place as well as the hole for the hydro hose/pipe down the center.
stodgy
Red Riley,
Mine's about as useful but I wonder if your might just buff right out  :cheesy:
Quote from: MPlayle on December 16, 2023, 12:54:48 PMWhere a rubber cone would seat in a dry subframe is different in a wet subframe as it has a set of tabs to help lock the hydro bag in place as well as the hole for the hydro hose/pipe down the center.
Gee, seems like a little welding of tabs and drilling two holes would convert a dry to wet subframe?  Someone must have done this before?
Mini Spare has genuine Hydro rear subframes in stock.  They do seem to have a caveat about needing the retaining tabs though.
Usually you hear of someone converting a hydro subframe to dry rather than from dry to wet.
Looks like they have the non genuine as well which is a little bit cheaper. Same caveat about the hydrogas retainers needing to be welded on from the old sub frame or fabed up. Seems simple enough to do.
I have one from a mk2 that still has the old hydros in it, but its not likely worth the cost of shipping, its not bent up but pretty rusty.
stodgy
I was hoping to avoid buying a new one mostly because the added cost of shipping but might have to suck it up.
All those wet-to-dry conversions over the years have made prices go bonkers.
I thought about going dry but I like the ride quality and have an extra set of pipes and bags so should last me.
The hydrolastics do ride nicely
Whee
I have one in Colorado I think. PM me if you are still looking.
