My 65 Australian MKI
Thanks Dan. Lol. Yea got the subs on, motor in, doors, boot and hood buttoned down.  Even did an alignment on it.  Another big thanks to Dan for all his help.  I didn't take any pics, didn't realize Dan was.
We got a lot done.  Flared some brake lines and got a couple rusty minis moved back into the side garage too.  Rear boot rubber needs time to settle in and the bonnet fitment was probably the worst of it.
Take pics!  Later on you'll want to show off it was a bare metal rebuild.
Once you get it running again, there will be tons of little fettling to do, but once it's drivable it becomes more fun every day!  77.gif
I have lots of pics. Just didn't take any over the two days.  Will definitely be taking more as I get things done.
That's the plan is to get it running.  Gonna go through it an put together a list of needs and then get to it.  Just doing what we did this weekend found more pieces that need replaced, painted or powder coated.  Spring is the goal.
And then the REAL fun begins. Lol.
Can't wait to see it with trim and such on it!
Mark, are you using the same interior or something else?
It'll be all black except some inserts on the seats.  Still using the cobra buckets.
G67mcs
The body shell turned out great. Really like the Fiesta!
Fun begins but you are way ahead already with the engine installed.
Garry
1967 MK2 S
2003 Mini Cooper S
2016 4Runner
Yea, I keep telling myself I started with a fully functioning car, so I should be able to get it back there.
Of course I'm finding out functional doesn't always mean right.  Looking through my books and discover the door handle spring is the first thing in the stack unlike it was when I took it apart and currently have it.  Sure I'm going to have a lot of this.
Love having a hardware store that carries all these unusual thread size screws.  Just got all new for the door handles, catches and nylon buffers. Also for boot latch and license plate holder.  Be nice if the one they opened here in Allen had all the same stuff the big store does in Plano.  But either way it's better than paying 1.50 per from Europe or Australia.
Do have to get the nylon things from Australia but working up a list for everything from there.
#440
New fasteners make all the difference in putting one of these back together - at the very least if I reuse fasteners I run them all on the wire brush on the bench grinder so I have good clean threads.
Quote from: gr8kornholio on September 21, 2020, 09:50:54 AM
You talking about Elliott's Hardware?
That's one thing I really miss about Dallas.
I've found nuts and bolts to be way less expensive at Home Depot than Ace hardware, but I still maintain a large selection in my bins from Bolt Depot, all grade 8 stuff as it costs less than grade 5
Is Elliots Hardware in Dallas still open. I think they have more hardware than has ever been invented... well almost. They were the goto when I lived in Frisco/ Dallas
Yes Elliots.  I go to the one in west Plano.  They opened one in Allen, but it's only got a fraction of the stuff.  Our Home Depot/Lowe's doesn't carry the fine thread sae sizes.  Elliots has them in stainless, zinc, chrome, black chrome, and several others including polymer. Some times it's a curse though trying to find the needle in the haystack.
Quote from: gr8kornholio on September 21, 2020, 05:04:38 PM
Yeah, I would estimate that Elliott's carries about 10 times the number and types of fasteners compared to a typical HD or Lowe's.   Ask one of the many old guys for help.  They know their stuff there.
I was going to change timing chain and front cover but don't have the right size socket/wrench. Thanks to Dave for the size.  Did notice the pulley is loose. I can move it around without it moving the crank bolt.
So I cleaned up the wiper motor and painted the housing.  Replacing the wiper boxes also. Took some figuring to get the old ones off.  The new ones have play built in so they go on easy.
While waiting for the wiper motor to try I got the main front harness shoved through the tiny space it goes through above the cone pocket.  Speaking of wiring, any tips on making sure the little Lucas connectors are fully seated and tight?
#447
Yes. Take an old pair of slip joint pliers and cut a notch in the ends big enough for the wires to fit into - then just squeeze the ends together - they will pop into place perfectly. I sent you pics of mine
I got frustrated trying to get them to pop into place using my thumbs or needle nose pliers - this works a treat and cost nothing to make.  77.gif
