1960 Austin 850 Project
So after fighting an engine issue off and on since January I finally identified and fixed the problem.
The problem? apparently a flaky erratic ignition condenser.
Re-capping: previous posts detail some of the engine run problems encountered; changed fuel pump, replaced kinked fuel line,cleared fuel line, gravity fed carb, changed carburator without improvement.
I was able to run the engine but was hard to start. It showed evidence of fuel problem but couldn't determine if ssupply or caarburation problem. It was run with a timing light which occasionally indicated misfires and would stop flashing when it stumbled and quit. Wasn't sure this was a sparking problem or coli problem.
I checked and adjusted the points (.020 adjusted back to .016) Contacts and condenser had been installed new with not more than five hours run time).  I installed a new 12V coil and saw some improvement but it still stumbled after a few minutes.Took the ignition resistor out even though coli said to use a resistor. all this without nay imporovement. Adjusted the mxture so many times i wasn't sure where it was. Couldn't get it to run long enough to set right. Wasn't sure that I wasn't flooding the engine.
All this and exhibited the same erratic run, start. When it wiould run it would run like a banshee, so WOT ran great but idle was a nightmare.
Last few days I redid all the things I changed; re-installed the SU fuel pump- no change hard to start, stumbled then quit. Ran with gravity feed- no change; stumble then quit. Changed the carb back to the original carb. No change. Back to original parts except new coil. Hard to start, rough runnning, misfiring.
Then got to thinking the only thing i haven't changed are the points and condenser. I was going to change them but needed to order and continued troubleshooting. Seemed that was the only thing left and ignition was suspect anyway.
I wondered about the condenser so I googled symptoms of a bad condenser. At that time I presumed the the engine simply would not start or run. Surprisingly there was info that a condesnser going bad will exhibit hard to start, rough running, misfiring. I realized this described my engine's symptoms to a tee.
Since i hadn't ordered a set of points I didn't have a condenser so I dug around my old parts bin and found an old distributer with a old Lucas condenser. Installed the condenser and strated the engine. I think it was flooded as it sttered around the ran. Blew the cobwbs out WOT and it stated to run like sewing machine. tweaked the mixture, checked the timing ran till running temp reached without a hitch. Shut it down and restarted without any problems.
And Bob's your uncle.
My first experience with a bad condenser.
Now to clean the yellow pollen off. Its in the garage. How does that stuff get in? Duh Open garage door.
Success! Lots of good old mechanical detective work there.
So much different from just plugging in a scanner and reading the codes.  ;D
And that's why I convert every engine I work on to pointless ignition. I've only had one failure, and it was over 20 years old and easy to diagnose......no spark. Changed it out, runs perfectly again.
Glad you found your demon too - but if you want to make sure it doesn't happen ever again, switch to a Pertronix or the like.
Quote from: MiniDave on March 27, 2020, 08:13:07 AM
No spark is what I expected of a condenser failure mode, not a "99.9% of the time it works." mode.
Couldn't seem to figger out if it was ignition or fuel problem but  the next step was pointless. ;D
Electronic distributors for the Mini are dirt cheap.  A complete distributor unit under $75 last time I looked - including a cap.   Probably even cheaper now.
i spent today installing a Pertronix LU142 electronic ignition. What looked like a 15 minute job turned into 5 plus hours. and still doesn't even start. It was running fine with the points but hard to start.  Anyway the screws supplied seemed to be the wrong thread size so fiddled around with those until I found they were just ahrd to start. Turned out ok but the rubber grommet where the wires go thru didn't seem to fit either so looked a a spare dizzy i had and found out that the plate underneath the mounting plate should have been removed and the metal forks  the points mount to, should have been cut off. Since I already had the unit mounted I trimmed the rubber grommet to fit. Since the coil said to use a resistor I wired it per instructions. As usual no start no spark nada. Checked wiring nothing. rewired without the resistor. Still nothing. Not even a sputter. Don't have a remote start button so it was difficult to check for spark but don't think even the coil is sparking.
Gave up for the night so may bring in my helper to check for spark somewhere tomorrow.
Not sure how this thing works so checking the coil for charge may be the only thing.
Anybody have any troubleshooting ideas?
Looks like I'm going back to points. It did run well when hot but hard cold start.
A few things - I have gotten a bad one of these - they either work or they don't.
Next make damn sure you hooked it up right - red wire to coil + and black wire to coil - if you did it wrong, it will fry the unit instantly.
Do you have 12V to the coil? I've not heard of adding a resistor to the coil + before on one of these, but it will not work if it doesn't have 12V to the coil - if you have a ballasted primary wire it won't get the right voltage. To check you can run a jumper from the starter hot lug to the coil and then see if it goes.
Lastly, I've had two Minis that start exactly the same way - they never start cold if I just crank them, but if I give it a 3 second crank, then off, then crank again they always seem to start easily on the second crank. No idea why, but that seems to be how it works. When warm they start normally.....
LarryLebel
If its an Ignitor I it will burn out if you leave it on for more than a minute or 2 without turning the motor over.
Easy to fry those as stated.
So I got out studied Troubleshooting guides. All wires checked for proper install. All resistance and voltage checked Ok. Petronix specified that the igniter gap should be .030. Checked and it was about .075. That could make a difference. The igniter is mounted on two posts with no adjustment either in the ignitor mount or in the plate. So I took out the dremel and elongated both igniter mount holes enough to get .030 gap. Didn't have any other TS to do so buttoned it back up.
Fired right up! better start than with the points. Points needed a strong battery to wind it up but the battery I have tends to fade real fast.
Warmed it up and it runs a lot better. No random missing. It started to rain so will put off shake down until later. I may check valve clearance when running as one valve is noisy.
If I take the valve cover off will oil spray everywhere or can I quickly check clearances before oil gets everywhere?
Somewhat annoyed at Petronix for the hacks needed to install the system. It was made out to be  a fifteen minute job as a bolt in. No mention of a minimum gap until troubleshooting.
I may even put one in my tractor now.
You wouldn't think it would be such a pain in the butt!  I've always just bought a whole new unit and sounds like I'll continue to do so.
By whole new unit you mean distributor all built up right? You're probably right the dizzy I have I think has a few miles. Would have saved some hours.
Yeah a whole dizzy with the electric guts.  Spares has some affordable options all the way up to something more advanced like the csi unit I run with programmable curves.
Quote from: 94touring on May 24, 2020, 12:50:23 PM
The original petronix systems had that issue but the later Petronix II is supposed to have resolved that issue.
A few years back there were a lot of bad condensers and on a Mini run i had one fail even installing another new one it still had issues.
I stopped at a parts store in a small town and having no luck finding the correct condenser i bought one for a 1960s Chevy 6 cylinder. It was too large to install inside the distributor so i attached it to the vacuum advance mounting screw on the outside and it ran better than ever.
I converted to electronic ignition but always carry a set of points and condenser or a complete distributor.
I've been running the car for 5 or 6 miles a day and runs cool but i seemed to have to add watter more than I would expect so I ran the overboard vent into a water bottle instead of overboard. I thought I saw some bubbles aroiund the tank to core joint so figgerd it was leaking so pulled it and found a radiatoe shop about 40 miles distant. He pressured it and found a huge leak around the filler neck. He re-soldered it in 30 minutes for a twenty. It was areely good '62 brass rad so was happy to see it repairable. The neck had apparently been squashed at one time so apparently broke the solder. It doesn't look the best but a little cleanup and paint will make it presentable.
Can't believe I didn't leak check it before I installed it. I usually leak check every thing I can but...
I have a spare tire but the rim has cracks in all four bolt holes. it could be welde but I'm not a good enough welder to do it. it also needs to be fixtured to prevent distortion while welding so it will run true. I haven't yet investigated weld repair locally. I had kinda thought i would find a used one around.
So does anyone have a spare wheel 10" 3.5 PN 21A881 that needs a home?
Thoughts on weld repair?
I would not weld it, even for a spare.....there are bound to be some steel wheels around.
Looks like MiniSpares sells new ones.....  http://www.minispares.com/product/Classic/Wheels/Wheels/21A1282.aspx?2003&ReturnUrl=/search/classic/steel%20wheel.aspx|Back%20to%20search
Let me check the extra I have for which style and I will get back to you later today.
#294
Here are some pictures of the spare 10" wheel I have.  I checked the lug nut pads on both sides and they are solid.  It is also one of the welded wheels, so no worries about being an early riveted wheel.
Let me know if you are interested.  I would consider $10 or $15 plus shipping.
Edit: Shipping would be from 78232 zip code.
The wheel looks great. i'll do the $15 and shipping. If it's more convenient I have a nephew in San Antonio around Randolph AFB area that you could drop it off.  i'll leave it up to you. Unless shipping is outrageous.
USPS estimate $11.30 for Priority 3 day 12x12x6 box 5 lb to 75757 so shipping charges OK
Thanks much appreciated.
I already have a box for it that just holds the wheel, so about that sizing.  I will box it and get it in the mail to you.
Send me your address in a private message through the forum.
Scargo
tsumini indicated: ..."I may check valve clearance when running as one valve is noisy.
You do not check or adjust rocker clearances with the engine running, so oil spraying will not be an issue. You need to check them with the engine off and set them to the desired clearances when cold.
Yes that's what book says, just wondering... my brother does chevies and they are set with the engine running. Gets a little messy.
The noise was the dizzy rotor had too much up/down travel so lobed shaft clattered up and down when running. Needed a spacer under the screw that secures the lobed shaft to the dizzy drive shaft. Fixed the clatter.
Thanks for th input.
Got mikes tire mounted on  the wheel. Took it downtown Tyler where I had done a set of four wwhich the guys then mounted and bakanced in about twenty minutes for twenty bucks,  Here the kid comes out and says ten dollars. Him and another guy spent about twenty minutes wrestling it on first by trying to pull it on by hand. Finally put it on the machine and somehow managed to get it on with a little damage to the rim. Then wanted  five dollars for a new stem. 50.gif.
But it's now in my boot. Also need to get a spare tire retainer. Any one have one to spare?
