Looking for a cone compressor tool
Started by Dmulder, March 25, 2016, 01:20:13 PM
Dmulder
I know I'm relatively knew around here. At any rate I've been helped a ton by your knowledge.  I'm wondering if anybody here is in Michigan and would be willing to loan a tool or if anybody would be willing to ship/loans tool to me. I'd be willing to pay shipping and when I have the opportunity to help I will give back.
Thanks,
Devin
I just take the upper control arm out - you need to check the bearings anyway unless you know they're good. Mine moved smoothly and I thought they were fine till I took them apart and found the shaft looking like this.....
You can also simply make your own.  I don't know if I still have pics floating around but if you find a piece of threaded bolt or rod the proper threads of your cones you're halfway there.  It escapes me what the threads are off the top of my head and also varies on years.
Here's a pic of what I made from a piece of threaded rod welded to a bolt that was the proper threads.  Found a spacer and then you just screw the nut on top which pulls the cone up.
Early cones are US threads, later ones are metric - 14mm IIRC
Dmulder
Quote from: MiniDave on March 25, 2016, 01:44:20 PM
If I take the upper control arm out how do I remove the trumpet without getting hurt. I don't mean to sound stupid. Also do the cones just stay in place then because they are bolted in?  I know Dan said I could cut the trumpets right out. I just want to make sure I don't lose any fingers or limbs in the process
The cones simple rest on a lip.  With the suspension at full travel there isn't much force left behind the cones, especially old ones.
Also, while there is weight on the suspension, remove the lower bump stop to get a little more travel. It's only held in by one screw......
towjoe
#8
Dmulder I'm in Orlando , but have the correct cone compressor tool with both metric and SAE rods.
E'mail me if you are unable to put together. I will loan mine out.
Other tools mini specific in my tool box are ; rear wheel cylinder retaining clip tool,flywheel housing oil seal installation tool,syncro hub tool to install ball & springs.
Regards
