AcesLow's 1973 Morris Pick up
Started by AcesLow, April 05, 2011, 02:36:36 PM
AcesLow
Finally some real progress!! Door gaps are okay. Needs a bit of adjustment.
AcesLow
Well.  50.gif  passenger isnt fitting well.. even bracing it it moved.... i hate body work... Time for a Jack and Coke
I've never seen a Mini with really good fitting doors, close panel gaps or even seams - remember, these were cheap throw away cars made in the height of the British labor troubles.....these were not made with Lexus-like attention to details. If they ran and the doors opened and closed....good enough!  ;D
Most Mini's I've seen - even ones that have had huge attention paid to the door fitment - still don't fit well after the door seal is installed.... so don't be too hard on yourself, you're not working with precision equipment here.....
That's true.   Mine usually fit good to great prior to the door seals then fit good to ok.  I've spent whole days shimming and adjusting a pair of doors and occasionally bending door seams to adjust the rubber seals.
AcesLow
I agree its not precision equipment. I had to open up the hinge hole 1/8 and now the doors fit. What is an exceptable gap around the outside of the door?
Basically what doesn't rub and looks decent.  They all vary from barely not touching to pushing quarter inch gaps.
AcesLow
AcesLow
I cut the flange off the box panel. Fixed my door gaps.. Fully weld it and radius it and it should look okay.
AcesLow
In my mind its not right. But it works...
How long have you been working on it?
And what are those holes above the rear window for?
Merlin
I thin the holes are for a factory cover of sorts.
I can't wait till the day comes for me to fuss over door gaps for hours and hours.
Engineering the Impossible
#164
The holes above the window are where brackets bolt that would hold a bed cover.
AcesLow
#165
Is that as far down as the tailgates came?? Been so long since mine was attached.
My buddy's lays pretty much flat, with a slight upward angle - but it seems much less than that....
AcesLow
#167
Im exactly 7 inches from the bed floor to the center of the first hinge mounting hole on the tail light assembly... can anyone measure their pickup? 94touring???
I'll have my hands on mine this weekend and try to remember to get a measurement.
I've got 7 inches too.   Gigitty.
AcesLow
Hahaha. New tailgate struts maybe. How far does yours (tailgate) "hang" down? Is it level with the box?
Ha.  I don't have my tailgate hooked up so that I don't know.
OH MY! your's isn't hooked up where do you keep it in between uses? I think I heard a song about this once.
https://www.youtube.com/watch?v=byDiILrNbM4
Oh wait, I see now were talking about tailgate's never mind.
Quote from: jeff10049 on November 18, 2015, 08:19:50 PM
:D
I only got through part of that video...unfortunately, I can't now unsee it.   :(
Spitz
I don't have my PUP anymore....but I do know it lay flat...perhaps a very VERY slight incline, but not noticeable.
The pictured one is definately not sitting right.
