Restoration-Mini
Classifieds => Cars for sale/wanted => Topic started by: Willie_B on June 09, 2018, 02:19:49 PM
Title: Need rear subframe mounts-2
Post by: Willie_B on June 09, 2018, 02:19:49 PM
Looking for two usable early rear subframe mounts. Dirty is fine, I can clean no problem.
Let me know what you got. If you need anything maybe we can work a swap.
Brad
Title: Re: Need rear subframe mounts-2
Post by: MPlayle on June 09, 2018, 02:24:10 PM
Which style do you need?  I may have extras from the Moke project.  I will look and take a picture of what I have.
Edit: Attached a picture of what I have rear subframe mounting related.  All of it for $30.00 total (shipped USPS small flat rate box).
It is two used trunions, a pair of the large trunion bolts for the front, a full set of the rubber bushings, and part of the other bolts, nuts and washers.
Post by: Willie_B on June 09, 2018, 04:57:49 PM
Quote from: MPlayle on June 09, 2018, 02:24:10 PM
That is what I need for the moke.  I will take you up on it. THANKS
Post by: MiniDave on June 09, 2018, 05:16:24 PM
WillieB, when is your Moke shell showing up?
Post by: Willie_B on June 09, 2018, 05:34:14 PM
Quote from: MiniDave on June 09, 2018, 05:16:24 PM
I have been told " a couple of weeks" twice now. First time was two months back.
Post by: MiniDave on June 09, 2018, 05:37:07 PM
Sounds like what Michael Playle went thru.....
