Restoration-Mini
Technical Forums => Maintenance and Modifications => Topic started by: SoCalMiniFan on September 27, 2015, 11:37:56 AM
Title: Setting up my Clutch Master Cylinder
Post by: SoCalMiniFan on September 27, 2015, 11:37:56 AM
I'm stuck on what part I need to put on next to connect my Clutch Master Cylinder to the Slave. In the pictures you'll see what I have, can someone tell me the pieces I need to make it complete? A Banjo Hose?  I looked in the manual and parts sheet but it has ALL the possible parts listed for pre-/non-Verto so I'm confused.
(http://i48.photobucket.com/albums/f250/dbrandsema/All%20things%20Mini/ec85a528-dfef-4441-9d82-702fe6c892c2_zpsqovuqa5t.jpg) (http://s48.photobucket.com/user/dbrandsema/media/All%20things%20Mini/ec85a528-dfef-4441-9d82-702fe6c892c2_zpsqovuqa5t.jpg.html)
The Master Cylinder, nothing attached thus far.
(http://i48.photobucket.com/albums/f250/dbrandsema/All%20things%20Mini/a54fbc4d-2541-4e64-9bf5-e924b8b8d981_zpsjjotsbrr.jpg) (http://s48.photobucket.com/user/dbrandsema/media/All%20things%20Mini/a54fbc4d-2541-4e64-9bf5-e924b8b8d981_zpsjjotsbrr.jpg.html)
The Slave and connected to it thus far is the following that I'm not sure is even the right part but it's loosely on there for the time being.
(http://i48.photobucket.com/albums/f250/dbrandsema/All%20things%20Mini/985d78af-47d5-4673-abde-74087ecea6cd_zpsnw7jpvvv.png) (http://s48.photobucket.com/user/dbrandsema/media/All%20things%20Mini/985d78af-47d5-4673-abde-74087ecea6cd_zpsnw7jpvvv.png.html)
Thanks in advance.
Title: Re: Setting up my Clutch Master Cylinder
Post by: 94touring on September 27, 2015, 11:46:51 AM
From the master to that fitting beside the stabilizer is just a basic ole hard pipe hand bent to fit with standard mini style fittings on each end that screw in.
Post by: MiniDave on September 27, 2015, 11:55:49 AM
You can see one here in my pic - the bright copper pipe....be aware, later cars had metric fittings.....your master cylinder could be metric and the fitting for the flex hose end could be English.
(http://www.somerfordmini.co.uk/eshop/images/21A2234.jpg)
Post by: SoCalMiniFan on September 27, 2015, 11:58:30 AM
I thought it was as simple as the Hard Pipe being fit to it! I got hung up on Banjo 17.gif fittings!
Post by: DS1980 on September 28, 2015, 06:49:06 AM
I like the idea of the rubber mat for firewall insulation.
Post by: MiniDave on September 28, 2015, 08:14:52 AM
I don't really know how much difference it makes, but it's not expensive and since I had everything out of there to paint I decided to add it. My 62 Cooper S had it too.....
Post by: DS1980 on September 28, 2015, 09:08:10 AM
Don't sell yourself short. It makes all the difference in the world if it keeps water off your binnacle and fumes out of the cabin. That's how it should have come from the factory. Lots better than that odd foam insulation. I had the pleasure of owning a mini that had that foam. It was glued to the firewall, not sure if that's how the factory did it or I was just lucky. It was awful. And completely saturated with water.
Post by: MiniDave on September 28, 2015, 10:07:32 AM
It's actually a vinyl mat with a jute backing....you can buy it at all the major Mini parts suppliers, but you have to cut it to fit the later cars like a Clubman.
