Restoration-Mini
General Discussion => The Lounge => Topic started by: Dan Moffet on June 12, 2025, 09:28:37 AM
Title: It is ALIVE!
Post by: Dan Moffet on June 12, 2025, 09:28:37 AM
(so am I!)
After two years of health problems (mine), I was able to start my Mini and back it out of the garage.
It took awhile to start as the carb was probably bone dry. It runs rough, but that's because the gas is two years old. It did have stabilizer "when parked" though I forgot to run the engine long enough to get the stabilized gas up to the carb. Consequently it is grumbly! I will drain the fuel tank and put in fresh gas.
No flat tires, though I haven't checked pressures yet. Clutch and brakes work, and no leaks! Just have to activate the insurance and then....!
Title: Re: It is ALIVE!
Post by: Willie_B on June 12, 2025, 10:11:41 AM
Hope you have some good weather so you can get it out and drive it. Glad you are doing better too.
Post by: Jims5543 on June 12, 2025, 10:54:18 AM
It's always satisfying when a car sits for ages and fires up.
Congrats on the better health and getting the Mini back on the road, a little car therapy does wonders.
Post by: Dan Moffet on June 12, 2025, 01:55:38 PM
I pumped out the old fuel and put it in my daily driver. Both cars had about 1/4 tank, but the daily driver has a computer capable of dealing with old fuel, and a bigger tank, so I figure the old gas is adequately diluted.
I put in about half a tank in the Mini and fired it up. Still running a little rough with tailpile pops and bang when suddenly revved. I wiped the heavy soot off the plugs and tried again. Still rough. I removed the air filter to see if it would lean out. No change.
Then it suddenly died and would not restart. OKAY, I thought, maybe the drain and refill washed dirt into the SU pump or somewhere. I disconnected the fuel line at the carb and ran the pump, with good results. Hmmm. Tapped the carb in case the float needle was sticking
Checked the plugs again. Not much change there,except the soot was beginning to burn off. That's when I noticed  a wire had come loose from the coil! With that back on, it fired right up. YAY! Still running rough. Checked the dashpot oil and decide to add some, just in case. Realized I had no idea what I was using so put a dribble of 5W30 in. Big improvement! Idle is smoother and exhaust pops are gone.
Enough excitement for one day. Tomorrow the insurance goes on and the next step is what we used to call an "Italian Tuneup". Oh, and check the tire pressure!
Post by: ve9aa on June 12, 2025, 02:09:18 PM
You'll get it figured out DanM. :13:
Post by: MiniDave on June 12, 2025, 02:30:30 PM
Yay!!!!
Mini therapy is the best.... :great:
Post by: 1071S on June 13, 2025, 08:37:36 PM
Great to hear Dan, mine has been sitting for a couple of years with a minor clutch problem.  I'm not overly concerned as some years ago while I was living in the States the Mini sat in a friend's shed for 4 years.  After whacking the fuel pump (use something soft ..like a shoe) we drove it to the rego shop, renewed the paper work and we were away.
Cheers,Ian
Post by: Dan Moffet on June 14, 2025, 03:06:49 AM
Yesterday life got in the way (as it does) and I did not get the Mini drive in. That, and it was Friday the 13th. :cheesy:
But it got me to thinking: we are sooo cautious about the reliability of our cars that we have the "protection" of cell phones, Automobile Associations with breakdown seervices and the like.
Then I remembered my very first car: a 1968 Mini Countryman complete with 850 cc engine, a magic wand transmission and a grabby clutch. I drove it summer and winter ANYWHERE (including a road closed except for snowmobiles). I had a summer job measuring schools for a provincial Ministry of Education space survey that put me and a co-worker on the road and in motels, doing hundreds of miles a week. No cell phones back then, no AA. The only mechanical problem on the road I recall was when the bellows-type water pump-to-head by-pass hose gave out. (That's when I learned you could use ditch water if you needed to and that the hose could be replaced without removing the head or water pump.)
There was one week the Mini was out of service because I did not quite get the 1100cc swap completed in a weekend, outdoors of course. That week we rode in luxury - a rented Chevy Vega station wagon. That will give you an clue to how long ago that was. (Early 1970's for those who have no idea what a Chevy Vega is.)
Nowadays I have a cell phone, CAA and even by-passes of my own.
Post by: MiniDave on June 14, 2025, 05:34:21 AM
It's true, there's no reason not to use our cars as cars - that's why they were built in the first place!
I rebuilt the motor in my first Mini - a 63 Cooper S with the twin carbs, tiny 7" discs and boat tires (I had bought Cosmic 10X6's and the only tires I could find were 145 section Pirellis, the boat tires were nice and fat! So much so that unless I ran about 10 psi in them they only drove on the middle 2" of tread - but I digress) The day after the first start up I drove it to Colorado Springs. I had straight exhaust with a megaphone on the back and as soon as I got there I bought a short glass pack muffler for it!
I drove that car all over Colorado, winter was no exception.....just like I drove my Dino around KC all year long too.
Post by: 94touring on June 14, 2025, 09:27:51 AM
In my 20s I logged thousands and thousands of miles on cross country trips in minis.
 I use to pick them up sight unseen after Peter Cavallo would import them to me to flip. I blew a head gasket in one driving from the port in Georgia to Oklahoma and had to pull over every 50 miles to add water to the radiator. My daily driver for a decade or so was a mini. I did break down once in New Mexico with a wheel bearing failure which was a fiasco.  Now I have logged thousands of miles in a old vw bus taking trips.  Something about it or a mini is just more adventurous.
Post by: cstudep on June 14, 2025, 02:37:08 PM
The nice thing about the older cars, even if they may be less reliable at times (debatable perhaps) is that you can fix nearly anything anywhere with a fairly simple tool kit. The disadvantage of course with something like our mini's is the availability (and quality these days) of parts. That issue can mostly be solved though by keeping some of the more likely to cause problem things like wheel bearings, points, maybe a head gasket etc... in the car with you.
Post by: Dan Moffet on June 27, 2025, 05:05:14 PM
I love my Mini!
In case you missed it, I got it back on the insurance and back on the road. Idle was a little low but 1/4 turn on the idle screw gave me 1000rpm idle when warmed up. Since then it has been running like a champ. Needs a little choke until warmed up (about 1/2 mile) then pulls smooth and steady. Nice music from the HIF44 and the stainless 1.75" single box exhaust.
Then the heat wave hit and it was back to the daily driver (2010 Suzuki SX4). Meanwhile my wife's daily driver (2010 Jeep Liberty) suffered the dreaded ignition interlock linkage failure: the key cylinder is on one side of the column and the needlessly complex switch is on the other. Between them is an evil device that:
(1) has a thin pin through the middle to depress a contact in the switch to tell the computer a key (any key) has been inserted;
(2) has a heavier casting (barrel)that locks the column when a proper key is inserted and turned; and
(3) two cast fingers on each side of the thin pin(1) extending out from the barrel(2) to actually turn the rotating contacts in the switch.
A known Chrysler issue, one of the fingers breaks off jamming the cylinder and barrel from turning... most of the time. Eventually with fiddling it will work intermittently. Then the weird stuff begins: The key will now turn the barrel and the switch, allowing the engine to actually start. However the pin(1) no longer depresses the key sensing contacts so the engine only runs for a couple of seconds and the confuser (BOLTR's term) shuts it off. Meanwhile the steering column no longer locks.
Master mechanic Goggle shows it to be an "easy" fix on most jeeps, though you do need one particular Torx security bit to remove the ignition switch proper. (Side note Canadian Tire had a 61 piece set on sale... so much for "security".) You also have to loosen the multifunction switch cluster (lights, wipers turn signals etc.). I got that far into it when I realized I could not safely see how it disengaged from the steering wheel without possibly causing more damage. And if I got past that, I'd still need to somehow put my head on backwards to see up under the column to remove the screws holding the middle component. Even with the seat all the way back and the tilt all the way up, there's less headroom than in my Mini.
So, between not wanting to cause more damage to the vehicle or myself, it got loaded onto a roll-back.
Next calamity: With her vehicle at the shop, my wife was using the SX4. Last Tuesday she needed it in the afternoon to do her IT work at the church, so I made a morning trip to Canadian Tire, about 1.5 miles away. It was far too hot to use the Mini. 2/3 the way there, the serpentine belt let go. leaving me without power steering, alternator or AC. Lets just say parking was a challenge and the ride home was HOT. So, now the SX4 is in line at the same garage - the belt was replaced on it not long ago, so there's something else going on in there.
Fortunately my sister lent us her car, a newer Dodge something that has fancy modern stuff like backup camera and keyless push-button start. I can only imagine how complicates that would be.
But today the Mini worked just FINE!!
Post by: Dan Moffet on September 09, 2025, 12:37:01 PM
Today is a perfect Mini-drive day - clear skies and temp 23deg C. The plan was to go get some beer, some cash from the bank and get my hair cut for my driver's licence photo tomorrow. The Mini was in its personal resting space to the side of the garage. In the main part was the Jeep, which I had just finished touching up some rust on its hatchback. I opened the garage to move the Jeep out onto the street to get the Mini out. Partway down the driveway, I decided to park the Jeep on the driveway with enough room to scoot by in the Mini.
Not having been run in a few weeks, the Mini was reluctant to start but eventually roared to life. I backed out of the garage and let the engine warm a bit while the garage door closed itself.
A couple of "vrooms" and I threw it in reverse and began enjoying the mighty torque... half-way down the driveway. Suddenly the Mini came to an abrupt stop. I was about 6" too close to the jeep and the rear tires of each vehicle kissed the other's bodywork. And the Mini was wedged tight.
I had to get out the rolling floor jack, lift the Mini and hand-push it clear of the Jeep. The Mini suffered  twisted bumper, a little popped Bondo (I didn't know about) beside the taillight assembly and the plastic wheelarch trim came loose. So far, I have been able to straighten the bumper.
As for the Jeep, all it had was lipstick on its collar AKA red paint transfer from the Mini. That came off using some lacquer thinner and a paper towel.
I did get a Mini ride, albeit halfway down the driveway and back. Errands were done in the Jeep. (Sigh)
Post by: 94touring on September 09, 2025, 02:01:26 PM
Well that sucks!
Post by: MiniDave on September 09, 2025, 05:46:20 PM
awww man.......
My brother is coming to visit and I plan to loan him my car, so I'll be driving my Mini as my daily for the week while he and his bride are here......we're going to have temps in the low 30's all week (90's in American freedom units) so it will be fine in the early part of the day, toasty in the late afternoons.
Post by: ve9aa on September 10, 2025, 04:32:54 AM
That sux, Dan.  :banghead:  Kinda reminds me of the time I took my Classic to work and 2 B-I-G guys picked it up and flipped it 180° in it's parking spot.  No problem, right?  Wrong! Cracked the bodywork (Bondo) in both corners of the cowl, below the wipers. (they had picked it up from the 2 front wheel arches, which thankfully were attached very well) I was not impressed.  :rolleyes:
  It's pretty thick bondo there, but has been cracked for 20+ yrs now.   I try not to drive in the rain, as those will collect water.
Hope the best for you, neighbour! :victory:
Post by: Dan Moffet on September 10, 2025, 01:56:09 PM
Thanks for the words of sympathy. The only part (beside a bit of Bondo) that came off is the 1.5" long seam cover below the bumper flange.  It lost a bit of paint and may be slightly tweaked, but it will serve as a paint sample when I go hunting for touch-up paint.
When I bought the car from Erik Mogilever (remember him??) the deal included an exterior paint job, done in the Toronto area. They did a good job. I picked a colour from an old paint book from a friend who has a body shop her in the Ottawa area. I chose the brightest red in the book, viewed in direct sun. That was called BMW Red 1. Of course the bodyman in T.O. had a different paint system but he matched it very well. They even included a small glass jar of paint for touch-up. I still have that somewhere. After over 20 years, I wonder if it is any good.
Post by: ve9aa on September 10, 2025, 02:48:23 PM
Quote from: Dan Moffet on September 10, 2025, 01:56:09 PMglass jar of paint for touch-up. I still have that somewhere. After over 20 years, I wonder if it is any good.
My money is that it's now a red hockey puck...but who knows?  :043:
Post by: Dan Moffet on September 13, 2025, 01:52:06 PM
Update:
 I got the Mini turned around yesterday so the damaged corner isn't tight to the wall and out where I can work on it.
First the bad news:
The right quarter panel had a large arcing crack about 4" up from the bare wheel arch. A nice clean crack, but the lower portion protruded about 1/16": a fairly wide expanse of body filler (What is "bondo" in German?) from the wheel arch flange on up. Of course that needed to be ground out to find out why and how much, and to fully eliminate the crack.
When I removed the right taillight assembly, there was more body filler behind its bottom right corner. It had to be ground out too as it had a rack as well.
The third spot of filler was at the bottom of the quarter panel where the short horizontal seam meets the vertical seam and the wheel arch flange. Behind that lumpy bit was a small rust hole into the boot, right at the inner fender. So that had to be ground out too.
Now the Good news:
The filler on the quarter panel was there because the panel had been hit mildly in it first live in Germany That cause it to bend gently inward with mild distortion that a wide application of filler was able to blend out. It was well done as it was not apparent at all. When I pranged it, apparently the metal tried to regain its original shape, which is why the protrusion at the curved crack was produced. Today I was able to grind and sand most of the filler away, leaving a profile very close to the original. It has a coat of primer on it for now to protect the bare metal, which is already pretty smooth. No filler added!
At the tailight, I ground out the filler and found that there was a dent about 3/8" deep (as thick as my finger). this included distortion of the turned in rim of the opening. With an assortment of tools (claw hammer, ball pein hammer, assorted pokey tools) I was able to get the shape pretty close to the original. A test fit of the tailight shows the rubber seal will sit correctly. It will only need a small amount of filler to smooth any small ripples.
I am still working on the small rust hole, but I think, with a bit of backing and sealant from the inside, I can just fill and refinish. The backside of this "bodge-ette" is inside the boot, so rust should not be a significant issue. Better than the window screening and body fill I used on my first Mini to fix the sill at the front door post. (That lasted longer than the car!)
Another afternoon and it should be ready for paint.
I know the original repair was done in Germany because it was painted silver to match the original colour. Then a previous owner painted it black with a white roof, which was how it was dressed when I bought it.  It came to Canada that way.
Post by: 94touring on September 14, 2025, 06:45:58 AM
At least you'll have less filler once you're done.  Always funny when you find work that could have used way less filler had they just hammered a little bit.
On the rust hole you won't be welding. What I'd do, and do occasionally on minor pin holes in unimportant areas, that if you were to weld would just burn bigger holes,clean the back side to bare metal and fiberglass it from the back. Then glaze filler the exterior side.
Post by: Dan Moffet on September 14, 2025, 01:33:35 PM
Yeah, no welding from me. The last time I welded was in grade 8 metal shop, using oxy-acetylene. I would have been somewhere around 14 years old. Lets just say I'm not 14 any more (though my wife would dispute that). Multiply by 5 and add a few!
Post by: Dan Moffet on September 21, 2025, 04:53:11 AM
Update!
The Mini (I call her Desiree) is back together.
After adding some body filler back in to fill in the imperfections, I painted it with several coats of grey Rust Check Rust Stop paint I've had around for who knows how long. There was no rust, but I used it because it will stick to bare metal, I sanded between coats to even out any fine irregularities and then fine sanded the last coat to flatten the gloss to prepare for the final colour paint.
Off to Canadian Tire to find the closest red they carry to use until I could get the car to a paint seller with a colour scanner for best match. I had a sizable chunk of nicely painted body filler removed from the car as a comparison sample.
The closest I found, matching to the cap, was Rust Check Flame Red, which seemed pretty darn close and was of the same brand as the "primer" I used, so adhesion should be good.
Now for the best part: the purchased paint matched the car colour closer than any touch-up paint I've used (since Wimbledon White on Dad's 1964 Ford Fairlane station wagon back around 1968). It is so close I can only see a difference in sheen - the new paint is shinier, though some fresh wax should sort that out. The car is done in a base + clear system and the repair in a one-coat gloss paint. I'm sooo pleased!
There is a slight, soft crease line that the original Bondo was hiding that can only be seen if pointed out in the right (wrong!) lighting. But the car is about 45 years old, so some battle scars should be accepted.
I'm not quite satisfied with the bumper fit. The right end protrudes forward of the rear side seam about 2 cm. Its mounting brackets got tweaked and need a little more persuasion. But that's for another day. It may have been distorted in its previous altercation anyway.
Yesterday was spent cleaning out the garage completely and sweeping and hosing down the floor, which was long overdue before I started sanding off body filler.
Post by: BruceK on September 22, 2025, 06:15:15 PM
Good to hear you've got back together.
Post by: Dan Moffet on September 24, 2025, 04:32:51 AM
My next little project was a Mini-lift.
My garage is about 22 feet long by 15 feet wide inside. There's a 10 foot wide overhead door front and back which are close to the south side. That leaves a 5 foot wide storage bay for the Mini and the lawn tractor, as well as a small work bench at each end.
To get the Mini out requires removing another vehicle (see above), moving the lawn tractor and then see-sawing the Mini (with both overhead doors open... I don't want to bump into anything :lipsrsealed: ).
The solution I thought about for years was to have some sort of a dolly to lift the back end of the Mini and angle it toward the front O/H door and just back out. That usually revolved around those lever affairs they used to use in F1 pits to lift a car to change tires, but there isn't room to use or store something like that, and I needed it to roll sideways.
Last week, I sent my old daily driver off as a donation, knowing it was worth at most $500 CDN and would likely be scrapped. The donation process made disposal very simple. I decided to keep the never-used scissor jack from it.
Then the idea popped: put the scissor jack on a platform dolly. I had 4 large swivel casters and 3/4" plywood. My first attempt used a scrap of plywood about 11" square, which left the casters too close together for stability - it tipped over when I tried to move the car. A bigger piece of plywood solved that. After lubing the swivels and the wheels, it worked! The annoying part was how tedious it was to use the 2-piece hook and crank affair the jack came with.
Then the revelation landed. In the garage I have a fairly heavy duty corded electric drill I have used maybe 3 times in at least 10 years. I cut the flat hubcap removal tip off the hook part of the crank, chucked it in the drill and... presto! a powered Mini-lift. If the big vehicle is in the garage far enough, I will be able to get the Mini out without moving it or the tractor.
Now if it would just stop raining....
Post by: ve9aa on September 24, 2025, 05:05:09 AM
I'd love to see pix of this Dan !
Many years ago when I had Barney-the-floorless-wonder-Mini I made 4 dollies from just wood 2 x 4's and normal $10 casters and was able to wheel it around my garage myself "fairly" easily. Not so easy to get it off the 4 dollies however. So I like your idea on that!
Unrelated, I took a normal scissor jack and welded a 17mm nut to where the handle would go and can use a large 20-VDC or Air impact wrench to raise/lower it.(I suppose even a regular ratchet would work if I had a breaker bar and short extension.
Fools seldom differ?  hahah.  Good ideas Dan
Post by: MiniDave on September 24, 2025, 08:50:39 AM
 :great:
We always like to see pics!
Post by: cstudep on September 24, 2025, 12:52:32 PM
You already have your solution but as an aside, for as cheap as they are, these things actually work surprisingly well for moving a Mini about on decent enough concrete. I put one under each wheel to move the entire car in any direction, but they also work fairly well just under the front or rear wheels to pivot it about like you are saying. They make metal dollies specifically for such things, and even ones like you mention with a jack feature built in but they cost about 10x as much.
I have seen them for sale at Home Depot and the like for basically the same price as well.
https://www.harborfreight.com/18-in-x-12-in-1000-lb-capacity-hardwood-dolly-58312.html
Post by: Dan Moffet on September 24, 2025, 01:49:06 PM
Yes, furniture dollies are great and nearly indestructible. Works well as you suggest for a car in storage or a project that needs to be moved.
My Mini-Lift is like that but with a scissors jack in the middle. It takes longer to get down on my knees and position it than it does to lift and move the car!
Many years ago I bolted a piece of angle iron to the back cross-member of the rear subframe so it is strong enough for single-point jacking. For the front, I have a 1x1 square steel tube that clips onto the front subframe for single-point lifts, similar to the Dooder wooden board. The scissor jack I used is rated at .95 ton. The whole Mini is only .65 ton.
Post by: 94touring on September 24, 2025, 02:22:15 PM
I have some things that bolt to the wheel studs and have heavy duty steel rollers on the bases.  Works great, aside from needing to put wheels on and off.
Post by: MPlayle on September 24, 2025, 03:51:05 PM
A few years back I did the furniture dolly thing under one of my Minis.  It was sharing garage space with a Mazda Miata/MX5 in a 1.5 car garage.  I could easily pirouette the Mini any way I wanted.
Lifting it onto the dollies was also easy as I have a cross beam for my floor jack that lets me do two-point lifts of the front or rear of the Mini.  Lift the front and place two dollies, then lift the rear and place the other dollies, then move the Mini where/how you want.
